Software Archive
Read-only legacy content
17060 Discussions
user defined vector function
Intel_C_Intel
I try to write a function which returns a vector like
rlogsig = 1/(1+exp(-x)), where x is a vector, and rlogsig should be a vector.
My code is like
program main
real x(2), r(2)
x(1) = 1.0; x(2) = 2.0
r = rlogsig(x)
print *, r
end program main
function rlogsig(x)
end function rlogsig
But, it does not work! Anyone can help
Intel_C_Intel
! You are making 3 fundamental mistakes here,
! any one of which will cause your program
! to fail
module all_my_functions
   implicit none
   contains
      function rlogsig(x)
! (1) x is an array and so must be declared as such
! in the called function.  I use an assumed-shape
! array so that your calling program need not pass
! an additional parameter indicating the size of x.
         real, intent(in) :: x(:)
! (2) Since rlogsig returns an array-valued result,
! it must be declared with the appropriate shape
         real rlogsig(size(x))
end module all_my_functions
program main
! (3) The interface to rlogsig must be explicit in
! all programs which call it because it has an
! assumed-shape dummy argument and also because it
! it returns an array-valued result.  Modules are
! the most common way to create this explicit
! interface.
   use all_my_functions
   implicit none
   real x(2), r(2)
   x = (/1.0, 2.0/)
   r = rlogsig(x)
   print *, r
end program main
Intel_C_Intel
Another type:
module points
implicit none
type:: point
real:: x,y
end type point
contains
function rlogsig(c) result
type (point), intent(in)::c
type (point):: r
r%x = 1/(1+exp(-c%x))
r%y = 1/(1+exp(-c%y))
end module points
program example
use points
implicit none
type (point)::c
c%x=1.0; c%y=2.0
print*, 'rlogsig', rlogsig(c)
end program example
Intel_C_Intel
! It occurred to me that you may also want to use
! an elemental function in this context
module other_functions
   implicit none
   contains
      elemental function rlogsig(x)
         real rlogsig
end module other_functions
program main
! Note that the interface to an elemental function
! must be explicit in the caller
   use other_functions
   implicit none
   real x, y(2), z(2,2)
   real r, s(size(y)), t(size(z,1),size(z,2))
   x = 1.0
   r = rlogsig(x)
   write(*,'(f9.7)') r
   y = (/2.0,3.0/)
   s = rlogsig(y)
   write(*,'(/2(f9.7:1x))') s
   z = reshape((/4.0, 5.0, &
                 6.0, 7.0/), &
               (/2,2/),order=(/2,1/))
   t = rlogsig(z)
   write(*,'(/2(f9.7:1x))') transpose(t)
end program main
Intel_C_Intel
James,
Thanks a lot. Both functions are what I am looking for
