Software Archive
Read-only legacy content
vector undefined symbol
Hummel_M_
I am porting a code to Xeon Phi (using manual offload) and I am experimenting some trouble to compile/execute code with STL vectors on MIC. I isolated a small test case which reproduces the problem (see attached files).
Using classical compilation generates the executable but execution fails :
$ icpc  -fPIC -fopenmp  ../Code/DATA/RegionF.cxx -I ../Code/DATA
$ ./a.out
On the remote process, dlopen() failed. The error message sent back from the sink is /tmp/coi_procs/1/192143/load_lib/icpcoutAoy76m: undefined symbol: _ZNSt6vectorIiSaIiEEC1IiEET_S3_RKS0_
On the sink, dlopen() returned NULL. The result of dlerror() is "/tmp/coi_procs/1/192143/load_lib/icpcoutAoy76m: undefined symbol: _ZNSt6vectorIiSaIiEEC1IiEET_S3_RKS0_"
offload error: cannot load library to the device 0 (error code 20)
$ c++filt _ZNSt6vectorIiSaIiEEC1IiEET_S3_RKS0_
std::vector<int, std::allocator<int> >::vector<int>(int, int, std::allocator<int> const&)
There is a missing symbol concerning std::vector on the MIC side.
If I compile using verification option, it gives me details on the error :
$ icpc  -fPIC -fopenmp -offload-option,mic,compiler,"-z defs"  ../Code/DATA/RegionF.cxx -I ../Code/DATA
/tmp/pbs.1698391.tu-adm01/icpckl957f.o: In function `data::Region::isInside(data::Region const&) const':
../Code/DATA/RegionF.cxx:(.text+0xda): undefined reference to `std::allocator<int>::allocator()'
../Code/DATA/RegionF.cxx:(.text+0xed): undefined reference to `std::vector<int, std::allocator<int> >::vector<int>(int, int, std::allocator<int> const&)'
../Code/DATA/RegionF.cxx:(.text+0xf7): undefined reference to `std::allocator<int>::~allocator()'
../Code/DATA/RegionF.cxx:(.text+0x101): undefined reference to `std::vector<int, std::allocator<int> >::~vector()'
../Code/DATA/RegionF.cxx:(.text+0x116): undefined reference to `std::allocator<int>::~allocator()'
May be I missed something, I tryed to include the #include <vector> into the #pragma offload_attribute(push,target(mic))
region but it's giving me another error.
Is someone can help me to make this small code to work ?
Hummel_M_
Oups adding ALL includes into to #pragma offload_attribute solve the issue.
Jun
I actually found the real problem is ....don't #define<iostream>
Frances_R_Intel
Jun,
Can I take it you mean #include <iostream>?
You don't want to include iostream in a _Cilk_shared offload region, but you do need to include it in the offload. You need to tell the compiler that it needs to include both processor and coprocessor versions of the member functions but the objects themselves can't be in shared memory - or at least I know of know way to do this.
In any event, Hummel's solution is correct.
Jun
Hi Frances
     Thanks for you explain. One thing I still not able to understand is that if I put #define<some header > in both outside and inside offload attribute target(mic) region. I will get runtime error. In this example if I have already put #define<iostream> in the offload region, and I put #define<iostream> in regionF.h/regionF.cxx(one of them gives me error...) outside offload region, I get runtime error.  I tried same thing for Cilk , runtime error happens.
