Software Archive
Read-only legacy content
17061 Discussions
when restarted XDK gone all Apps I had... how recover Apps...?
Leonidas_S_
My XDK crashed during testing of server down by make jQ ajax request to non-existed url...
when restarted XDK gone all Apps I had... how recover these Apps...?
Leonidas_S_
well , can recover??? also I backup whole PC prior one month,.. can recover apps???
Giselle_G_Intel
Hi Leonidas,
Just to clarify, XDK crashed and when you reopened XDK all your apps were gone from the menu?
If this is the case, you should still be able to re-upload those apps by:
  1. Go to Projects tab in upper left corner
  2. Click on Open An Intel XDK Project (bottom left corner)
  3. Navigate to the folder in which you've saved all of your apps and click on the .xdk file for that project
  4. Repeat for all apps
It may be a bit tedious but if you've saved them onto your computer they are still recoverable.
Leonidas_S_
OK but if have backup copy of hdd can recover an xdk "system" file and All apps get recovered?
note : some apps Not remember their location in hdd...differ from default location.
Leonidas_S_
I (went) upgrade xdk but now when open says
"Cannot Extract Package, ... "   see screenshot attached...
PaulF_IntelCorp
Leonidas -- try downloading the installer directly from http://xdk.intel.com and running that, instead. Remember to exit the XDK before attempting to run the installer. Let me know if that fixes the issue.
Leonidas_S_
soon to do
About the recovery of Apps -- may forgotten where are in disk, so can recovered by substitute a xdk system file... i have whole hdd backup from September 2016....?
PaulF_IntelCorp
Leonidas -- search for files named *.xdk to find your old projects. For example, on Windows:
> dir /s *.xdk
and on Mac or Linux:
$ find / -name *.xdk
Leonidas_S_
you mean there is no file xdk (to copy from backup) for projects be like was(all recovered at once)?
where projects saved in xdk?
about Android & iOS certs saved when login in intel account?
Leonidas_S_
needed reinstall first?
PaulF_IntelCorp
The XDK does not "save" your projects anywhere, it simply references the projects as folders on your hard drive, we do not manage where you locate your projects or how you back them up. Those projects that are pushed for a build or for use with the Test tab contain only the source of your project, not the XDK file, and are stored only temporarily on the build system. If you have a copy of your built app (for example, the APK file) you can open that to get the same sources, it is a ZIP file and can be unzipped on your hard drive.
Reinstalling the XDK has no impact on the location or state of your projects. As indicated above, the XDK just references folders on your hard disk, it does not store or manage your projects, that is your responsibility.
