Software Archive
Read-only legacy content
17060 Discussions
why this simple offload give Segmentation fault error
yongbei_ma_
this simple test code is this(testclass.cpp):
#include <iostream>
class TEST{
public:
    double *A;
public:
    TEST(double * _A){A = _A;}
    void run(){
        A[1] = 0;
        // double *B = A;
        std::cout<<A[1]<<std::endl;
        #pragma offload target (mic) inout(A:length(2*3))
            A[1] = 1;
int main()
    double *A = (double*)_mm_malloc(sizeof(double)*2*3,64);
    TEST test(A);
    test.run();
after complile and run ,this give me this error:
[root@localhost yb]# icpc testclass.cpp
[root@localhost yb]# ./a.out
0
Segmentation fault (core dumped)
thanks.
Kevin_D_Intel
It relates to the underlying "this" pointer. I need to check with someone more knowledgeable about the requirements for offload within the CLASS, but for now add the additional nocopy clause as shown below to create an instance of the underlying "this" pointer.
        #pragma offload target (mic) nocopy(this : alloc_if(1) free_if(0)) inout(A:length(2*3))
