Software Archive
Read-only legacy content
[xdk 2496] undefined is not a function error on CLI update to 5.1.1
Roi_D_
After the update I opened one of my projects and chose CLI 5.1.1. in the update dialog I chose to update CLI and plugins and got an error message box.
screenshot: http://prntscr.com/8k2iag
Roi_D_
In case someone else encounter this then going through the plugins one by one and choosing the newer version worked for me.
Pamela_H_Intel
Roi - I am glad you got it working. And thank you for the information. I will pass it on to engineering.
Pamela_H_Intel
Roi,
There are a couple of scenarios that could have caused your problem. Please provide the following information so that we can trace the problem to provide a better error message.
For each plugin you are using,
  • which plugin
  • which old version
  • which new version
Thanks!
Roi_D_
the plugins are device and InAppBrowser.
old versions were:
device - 0.2.13
inappbrowser - 0.5.4
new versions are:
device - 1.0.1
inappbrowser - 1.0.1
Pamela_H_Intel
Thank you, Roi!
Pamela_H_Intel
Roi, the developer in charge of fixing the plugin issue thinks he has it resolved but we are still verifying before releasing the fix. It would be great if you could provide us with your project.xdk file or xdk.log file and the last UI actions that you made before the error, if you remember.
Thanks!
Roi_D_
the project.xdk is available here
https://github.com/roidayan/redmine.js/blob/master/Redminejs.xdk
as for xdk log i dont have it anymore. as from my report of another issue that xdk is always freezing on startup i was suggested multiple times to delete the folder, do full uninstall, etc. so the xdk.log does not exists anymore.
