Software Archive
Read-only legacy content
17060 Discussions
xhttp.status returning 0 on Android
Joao_V_
My Application need to connect to an server, it works on IOS, but on Android not.
On IOS they return code 200, 404 etc
On Android they only return 0, for error, succes, anything!
My code:
     var xhttp = new XMLHttpRequest();
              xhttp.open("GET", HTTP, true);
        xhttp.onreadystatechange = function() {
            alert(xhttp.status);
    if ((xhttp.readyState == 4 && xhttp.status == 200) || (xhttp.readyState == 4 && xhttp.status == 0)) {
      document.getElementById("SIFrame").value = xhttp.responseText;
        TA = TXTIFrame.value;
        lines=TA.split("\n");
        document.getElementById("LineE").innerHTML = lines[LE];
        A1B.innerHTML = lines[R1];
        A2B.innerHTML = lines[R2];
        A3B.innerHTML = lines[R3];
        A4B.innerHTML = lines[R4];
        A5B.innerHTML = lines[R5];
         activate_page("#readerpage");
    } else {
        if(MSG == false && xhttp.status == 404) {
                    alert("Esse arquivo não pode ser encontrado, verifique sua conexão com a internet!")
                    MSG = true;
Thanks for the help!
Hamilton_Tenório_da_
Valued Contributor I
@Joao> maybe this post helps you: https://software.intel.com/en-us/comment/1867247#comment-1867247, thread Paul F. (Intel)  Wed, 04/06/2016 - 08:57
Elroy_A_Intel
I recommend that you add add an * (asterisk) to the network request field and http://* in the intent field on the projects panel. These configuration settings are visible for Cordova projects under the Build settings sections for the desired mobile platform. After you have successfully tested your project, the appropriate domain name (http://my-server.com) to the intent field. If your have more domain names, add them to the field separated by commas.
