Software Storage Technologies
Virtual RAID, RSTe, and Memory Drive Technology
Looking for RAID, VROC? You found the forum to ask questions!
351 Discussions
How to force USB 3.0 port controller to work in USB 2.0 mode [combo hub]?
RShan
I am using Intel chip Denverton [Intel(R) Atom(TM) CPU C3758 @ 2.20GHz] running in Wind River Linux 7.0.0.2.
It can recognize USB 3.0 storage device correctly and I want to force this device to work in USB 2.0 mode ,i.e. USB 2.0 root hub at run time. How I can do this ?,Is it possible ?
USB information is given below,&# 8232;
[host:~]$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 007: ID 0781:5581 SanDisk Corp.
Bus 002 Device 006: ID 0781:5581 SanDisk Corp.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
[host:~]$ lsusb -t
/: Bus 02.Port 1: Dev 1, class="root_hub", Driver=xhci_hcd/4p, 5000M
|__ Port 2: Dev 2, If 0, class="Mass" Storage, Driver=usb-storage, 5000M
|__ Port 3: Dev 3, If 0, class="Mass" Storage, Driver=usb-storage, 5000M
/: Bus 01.Port 1: Dev 1, class="root_hub", Driver=xhci_hcd/4p, 480M
[host:~]$
[host:~]$ lspci -nn | grep USB
00:15.0 USB controller [0c03]: Intel Corporation Device [8086:19d0] (rev 11)
[host:~]$
Thanks for contacting the Intel support. According with you question seems that the Intel® Rapid Storage Technology enterprise (Intel® RSTe) is not the product you are having issues with . In order to route this to the correct department can you please respond the following :
what is the mother board information brand and model ?
RShan
Denverton [Intel(R) Atom(TM) CPU C3758 @ 2.20GHz] CPU.
[host:~]$ cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 95
model name : Intel(R) Atom(TM) CPU C3758 @ 2.20GHz
stepping : 1
microcode : 0x1c
cpu MHz : 2200.000
cache size : 2048 KB
physical id : 0
siblings : 8
core id : 0
cpu cores : 8
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 21
wp : yes
Hi the information Denverton [Intel(R) Atom(TM) CPU C3758 @ 2.20GHz] CPU , is not related with the mother board information , in linux please use the following command in order to get that information: $ sudo dmidecode --string baseboard-product-name .
Please respond with the result you get .
