Software Storage Technologies
Virtual RAID, RSTe, and Memory Drive Technology
Comunicados
Looking for RAID, VROC? You found the forum to ask questions!
351 Discussões
Is it Possible to Make Bootable RAID0 with 3x Samsung 970 EVO Plus with Standard Intel VROC Key? SuperMicro Motherboard
MEhrm
Principiante
3.387 Visualizações
Hello, I want to make raid 0 with 3x samsung 970 evo plus SSDs, and I am very curious about VROC compatibility issues: Can I create such an array with 3 Samsung 970 evo plus SSDs and boot Windows 10 on it without any issue?
My system:
Motherboard: SuperMicro X11DAi-N
CPU: Intel Xeon Platinum 8280L x2
3 Respostas
JosafathB_Intel
Moderador
2.844 Visualizações
Hello MEhrm,
Thank you for contacting Intel® Memory & Storage Support.
As we understand, you need assistance with your Intel® Virtual RAID on CPU (Intel® VROC). If we infer correctly we will appreciate if you can review the following information:
·        Based on the Intel® Virtual RAID on CPU (Intel® VROC) Supported Configurations (https://www.intel.com/content/www/us/en/support/articles/000030310/memory-and-storage/ssd-software.html)
The supported Samsung* drives are the following:
Samsung
SM951*
SM961*
PM953*
PM961*
PM963*
PM983*
Please take into consideration that if you use a not supported SSD we cannot predict the performance and system behavior and unknown issue can appear.
·        We advise you to contact your motherboard OEM(original equipment manufacturer) in your case SuperMicro* to get further information about the tested and compatible hardware that will be compatible with your PC since they personalize and modify their VROC solution on their systems.
·        The compatible Windows* versions are the following:
Windows® 10
Windows 2012 R2*
Windows 2016*
Windows 2019*
There should not be a problem to use Windows® 10. Please consider that your motherboard needs to supports this OS.
We will be looking forward to your reply in case you need further assistance.
Have a nice day.
Josh B.
JosafathB_Intel
Moderador
2.844 Visualizações
Hello MEhrm,
Thank you for having contacted Intel® Memory & Storage Support.
This is just a friendly reminder that your case remains open.
Should you need our technical assistance please do not hesitate to contact us back.
Josh B.
JosafathB_Intel
Moderador
2.844 Visualizações
Hello MEhrm,
Thank you for having contacted Intel® Technical Support.
I was reviewing your community post and we would like to know if you need further assistance or if we can close this case.
We will be looking forward to your reply.
Josh B.
A Contingent Worker at Intel
Responder
