Software Storage Technologies
Virtual RAID, RSTe, and Memory Drive Technology
Looking for RAID, VROC? You found the forum to ask questions!
351 Discussions
Updating firmware of SSDs under VMD(VROC)
JShin
I'm making an application to update firmware of NVMe SSDs under VMD(VROC).
Until now I have accessed NVMe SSDs under Intel RST driver using CSMI(Common Storage Management Interface) and NVMe Pass-through in Intel's document "563914-Intel® Rapid Storage Technology Private API Support: NVMe* Pass-through API, Firmware Download API and AER API". But I can't access to NVMe SSDs under VMD using this method.
The document 563914 provides the guide below but these APIs don't work with VMD driver. CSMI IOCTLs return nothing.
6.1.2 Dependencies
• CSMI IOCTLs are needed – CC_CSMI_SAS_GET_DRIVER_INFO, CC_CSMI_SAS_GET_RAID_INFO and CC_CSMI_SAS_GET_RAID_CONFIG (Refer to Intel® RST CSMI IOCTL support) - to use Device Location API for devices that are part of logical volumes. CSMI IOCTLs provide device PTL information.
Please let me know how I can access to NVMe SSDs under VMD(VROC).
Question 1. Is it possible that an application accesses NVMe SSDs under VMD driver and updates firmware of them ?
Question 2. I found a document's name in Intel(R)_RSTe_5_4_ReleaseNotes.pdf - "Please refer to the Intel® VROC IOCTLs 1.3 Document for structure API changes included in this Intel VROC 5.3 release Kit". Can you share this document?
Question 3. Is there any other documentation to guide how to access NVMe SSDs under VMD?
BrusC_Intel
Hello, JShin.
Good day and thank you very much for waiting.
I will contact you privately via the e-mail registered on file regarding your request.
Bruce C.
A Contingent Worker at Intel
BrusC_Intel
Hello, JShin.
Good day,
Thank you for contacting the Intel Community Support.
I checked your details regarding the application you are working on, I will be glad to assist you.
I will need to get some additional details and investigate further Are you working on this around a particular platform or operating system?
About the document you mentioned, is this available in the Intel website? if so, can you provide the link to it?
I hope to hear from you soon.
Bruce C.
JShin
Dear Bruce C,
Thanks for your support.
Here are my test environment.
 - Dell Precision 7920 : https://www.dell.com/en-us/work/shop/cty/pdp/spd/precision-7920-workstation/xctopt7920us_2
 - Intel Xeon Silver 4116
 - Windows 10 Pro 1809
 - VROC(VMD) Driver : https://downloadcenter.intel.com/download/29564/Intel-Virtual-RAID-on-CPU-Intel-VROC-SATA-Intel-Rapid-Storage-Technology-Enterprise-Intel-RSTe-Windows-Driver-for-S1200SP-Family
And documents for development.
- NVMe pass-through : https://cdrdv2.intel.com/v1/dl/getContent/563914?wapkw=563914
- CSMI : https://www.t10.org/cgi-bin/ac.pl?t=d&f=04-284r1.pdf
If you need more information, let me know.
JShin
BrusC_Intel
Hello, JShin.
Thank you for the additional details.
Please allow me to investigate and I will contact you back as soon as possible.
Bruce C.
BrusC_Intel
Hello, JShin.
Bruce C.
BobZ
Hi, I came across this post and we are looking for one of the same documents.  Details of what we are looking for are as follows:
We want a document describing how to detect and interact with NVMe drives attached to an Intel VROC controller.
Looking at available Intel documents we can see references to an Intel® VROC IOCTLs 1.3 Document in relation to "Windows IOCTLs for NVMe Device Information". This document and related documents are not available via our Intel IBL account.
Hoping someone can point us to this documentation.
Thanks!
Mario_luo
Hello Bruce,
We are facing a similar problem as that for the OP of thread titled ‘Updating firmware of SSDs under VMD(VROC)’.
We were able to get expected response with the Get Log Page command with ControlCode=IOCTL_INTEL_NVME_PASS_THROUGH, based on Microsoft’s document for Windows’ IOCTL_SCSI_MINIPORT driver (ntddscsi.h). However, when trying to send Firmware image download or Firmware commit command using ControlCode = IOCTL_INTEL_NVME_PASS_THROUGH will result in a failure. We’d appreciate it very much if you could point us to the direction for correctly accomplishing this task.
Any information in this regard is greatly appreciated.
Mario
Mario_luo
@BrusC_Intel
Can I get your reply as soon as possible?
AndrewMeir
Hi @BrusC_Intel ,
I'm also facing the same problem as @JShin . I'm working on an application to manage non-Intel NVMe SSDs on an Intel RST system, including handling the update of SSD firmware.
From searching on Intel's available documentation, I located "Intel® Virtual RAID on CPU (Intel® VROC) for Windows*
Technical Product Specification for Intel® VROC 9.1 Revision 024 January 2025"
I'm specifically interested in obtaining documentation for the IOCTL that handles this aspect of functionality:
"5.2.7 Intel® VROC (VMD NVMe RAID) Private Device/Member
Info Protocol
The Intel® VROC (VMD NVMe RAID) package will provide a custom interface to provide
information on NVMe devices in pass-thru mode (non-RAID) as well as those NVMe
devices that are part of an Intel® VROC (VMD NVMe RAID) RAID volume when those
devices are managed by Intel® VMD. This interface (or protocol) is installed on each
handle of the Intel® VMD managed pass thru NVMe drives. "
It appears that part of this protocol has already appeared in certain public/open-source projects, e.g.:
https://github.com/hiyohiyo/CrystalDiskInfo/commit/902b40829362e002027f14ef637b94aa000e432f
Are you able to provide any detailed information (i.e. defined structure, payload layouts, lengths, etc.) regarding use of this IOCTL?
Thank you in advance.
Kind regards,
Andrew
