Software Storage Technologies
Virtual RAID, RSTe, and Memory Drive Technology
Looking for RAID, VROC? You found the forum to ask questions!
351 Discussions
Windows is Unable to install. Error: 0x80300024
SThom79
Windows, will not install.... It will give me the error message
Windows is unable to install to the selected location. Error: 0x80300024
DCart9
Do you have a normal hard drive as well as the SSD? If so it's simply easier if you disconnect the HDD and just leave the SSD attached. Once you installed you can then attach the HD.
Solution 1: Remove Any Unnecessary Hard Drives
[Admin removed third-party link due to possible risk alert]
AlHill
Install what?
Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file (using the paperclip under the toolbar).
Doc
SThom79
I was trying to Install windows.
DCart9
SThom79
Yes, sure. I will do this. Thank you very much.
SThom79
I did it, very cool, work better. Thank you so much.
AlHill
Glad you have working. In 14 minutes, you posted, got a response, corrected some hardware issue, and installed Windows. Amazing.
Doc
DCart9
I've been in this situation before. By the way, thanks.
