Good morning at all.
, I have a question please. My laptop is a Samsung NP450R5G.
Today I received an internal SSD disk Kingston Sa400s37/480g 480gb
and I don't know if it can be installed together with the original HDD disk present in the machine, or if this SSD can only replace the original HDD present, therefore having to remove it to make room for the SSD.
The dimensions of the two disks are the same.
Many thanks in advance
So, you have a samsung laptop and a kingston disk, and you want intel to answer your question regarding compatibility and coexistence?
This is not an Intel question or problem. Why do you not open up the laptop and see if there is a spot for a second drive? If yes, you have your answer. If no, you cannot. How to use the kingston? Contact Microsoft regarding disk replacement/cloning.
Hello Serdeste54,
Kindly note that your question is not about an Intel product and related to OEM manufacturer, we are recommend you checking with the system manufacturer for further assistance.
We will proceed to close this case and the thread will no longer be monitored.
Irwan_Intel
