1792 Discussions
How to generate the Performance monitoring interrupt after every "N" retired instructions?
Sanjeev_D_
I want to configure the performance counter to generate performance monitoring interrupt (PMI) after N retired instructions. My current set up is: msr pmc0 (0xc1) = -1000, set IA32_PERFEVTSEL0 (0x186)= 0x005100C0, IA32_PERF_GLOBAL_CTRL MSR (0x38F) = 1. Here, N=1000 instructions.
However, I found that the interrupt was generated only once. I expect to get PMI interrupt after each N retired instructions. I also clear the overflow after first interrupt (IA32_PERF_GLOBAL_OVF_CTRL(0x390) = 1).
Could you please let me know how can I generate the interrupt after every N instructions. Any help will be highly appreciated.
Following is my code:
    //set -10000 as a overflow counter
        xor edx, edx
        mov eax, 0xFFFFD8F0
        mov ecx, 0xc1
        wrmsr
    // set up the event
        xor edx, edx
        mov eax, 0x005100C0
        mov ecx, 0x186
        wrmsr
    //IA32_PERF_GLOBAL_CTRL MSR address    0x38F
        mov edx, 0x00000000
        mov eax, 0x00000001
        mov ecx, 0x38F
        wrmsr
    //Once the interrupt is encountered, we clear the overflow
    //IA32_PERF_GLOBAL_OVF_CTRL MSR
    mov edx, 0x00000000
    mov eax, 0x00000001
    mov ecx, 0x390
    wrmsr
Tokponnon__Parfait
Hello Sanjeev D.
Have you succeeded in solving this problem?
I am having exactly the same problem now, I receive the first interrupt, reset the counter to the initial count, clear the overflow flag but none of the following overflow interrupt are received...
Ilya_Verbin
Didn't you forget to ack the interrupt in APIC PMI LVT?
Tokponnon__Parfait
Verbin, Ilya wrote:
Hello Verbin,
What do you mean by "ack - acknowledge"? Can you be more explict?
Are you talking about eoi? if so, my answer is yes
Ilya_Verbin
Parfait T. wrote:
Quote:
Yes, when performance monitoring interrupt (PMI) happens, it sets bit #16 in APIC PMI LVT, which means that no other PMI can occur until this bit is 1. So you should set it to 0 at the end of the interrupt handler (in other words: to acknowledge it / to unmask it).
Please look at Figure 10-8. Local Vector Table (LVT) in Intel software developer’s manual.
Interrupt mask: (0) enables reception of the interrupt and (1) inhibits reception of the interrupt. When the local APIC handles a performance-monitoring counters interrupt, it automatically sets the mask flag in the LVT performance counter register. This flag is set to 1 on reset. It can be cleared only by software.
