1790 Discussions
How to get L1, L2 and L3 cache misses by reading performance counters using rdpmc instruction?
Shailja_P_
For example, sample code looks like this
long long get_L3_misses( )
  unsigned int a=0, d=0, c;
  c = (1<<30); // what is counter number for L3 cache misses?
  asm volatile(
        "rdpmc"
            : "=a" (a), "=d" (d)
            : "c" (c)
  return ((long long)a) | (((long long)d) << 32);
int main(int argc, char* argv[])
 long long start, stop;
 double result;
  start = get_L3_misses();
  some funtioncall;
  stop = get_L3_misses;
  result = (double) stop - start;
  return 0;
Thank you.
Thomas_W_Intel
Shailja,
the counters need to be programmed first with the event that they should count. Sample code for doing so can be found here:
https://github.com/opcm/pcm/blob/c21fbce6af8fb2435d390a56c7db75191d1df34f/cpucounters.cpp#L1717
The counter is then read later on in this location:
https://github.com/opcm/pcm/blob/c21fbce6af8fb2435d390a56c7db75191d1df34f/cpucounters.cpp#L2991
In case you are not interested in the details but just want to get the number of cache misses, you might consider using the PCM library as is and simply use the high-level functions. An example for calling the library can be found here:
https://software.intel.com/en-us/articles/intel-performance-counter-monitor#calling_pcm
Kind regards
Thomas
Shailja_P_
Thank you Thomas for the reply. Really helpful.
