Rank Margin Tool
shiv_a_
Does anyone know what the Rank Margin Tool is?
Bernard
Valued Contributor I
Is that tool related to DRAM?
wc6653
Bernard,
Did you get answer of your question?  I am looking for the same.   Is this this RMT tool for system level test or memory device (DRAM) evaluation?
Wen
shiv_a_
Apparently so. Dont know what it is though.
Bernard
Try this article(actually a patent)
http://www.freepatentsonline.com/7689879.html
Book_J_
What is  DQ UI (ps)?
Rank Margin Table Equations
RX Timing Margin (each step = 1/64 * DQ UI (ps))
RX timing setup = RxDqLeft
RX timing hold = RxDqRight
TX Timing Margin (each step = 1/64 * DQ UI (ps))
Huynh__Son
Hi everyone,
I'm getting Mixed Memory Speed warning after getting the Margin Tool to analyze the data.
Where do I go from here?
Do I check with the bios settings?
all four DIMMs are the same model and same vendor.
I'm looking for answer why I'm getting mixed speed.
Can someone help?
wc6653
Hi, Shiv_a,   did you get answer of your question?   I am looking for the same.   Thanks
