";" is missing in CSV output of pcm.x
Hidekatsu_Imura
It seems ";" is missing after core L2CLK value in csv output.
Could you check below?
------- pcm.cpp-------
        for (uint32 i = 0; i < m->getNumCores(); ++i)
            if (cpu_model != PCM::ATOM)
                    cout << getExecUsage(cstates1, cstates2) <<
                    ';' << getIPC(cstates1, cstates2) <<
                    ';' << getRelativeFrequency(cstates1, cstates2) <<
                    ';' << getActiveRelativeFrequency(cstates1, cstates2) <<
                    ';' << float_format(getL3CacheMisses(cstates1, cstates2)) <<
                    ';' << float_format(getL2CacheMisses(cstates1, cstates2)) <<
                    ';' << getL3CacheHitRatio(cstates1, cstates2) <<
                    ';' << getL2CacheHitRatio(cstates1, cstates2) <<
                    ';' << getCyclesLostDueL3CacheMisses(cstates1, cstates2) <<
                    ';' << getCyclesLostDueL2CacheMisses(cstates1, cstates2) ;
        // <---- "<<;" is missing here
                    if (m->L3CacheOccupancyMetricAvailable())
                        cout << ';' << l3cache_occ_format(getL3CacheOccupancy(cstates2)) ;
Otto_B_Intel
Sounds plausible, i would probably put the cout << ":" at the end of the loop to avoid the same issue for the L3CacheOccupancy.
Otto_B_Intel
It looks likes it is already fixed in the internal version, but i don't know when there will be a release with this fix included. Thanks for the report!
