Wireless
8324 Discussions
İntel Wireless Bluetooth ve İntel Wireless AC 9462 Bir Sonraki Güncellemeler Ne Zaman Yayınlanır
Emrahylz28
Jose_Intel
Hello @Emrahylz28
Thank you for posting on the Intel️® communities.
Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
We understand you opened another thread with the same question, so we will continue the support only in this thread.
Please answer the following:
·      Did the Intel® Wireless-AC 9462 come preinstalled in your system?
·      Was the performance better before?
·      Have you made any recent software change?
Regarding the driver update, we don’t have an estimated time. We recommend to check the download center and check for updates there: https://www.intel.com/content/www/us/en/products/sku/125192/intel-wirelessac-9462/downloads.html
Also, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Jose B.
Jose_Intel
Hello Emrahylz28
We hope you are doing fine.
Was the information useful for you?
If you still need assistance, please do not forget the report.
Jose B.
Jose_Intel
Hello Emrahylz28
We hope you are having a nice day.
We have not heard back from you. So, we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jose B.
