Wireless
8782 Discussions
replacing my Intel(R) Dual Band Wireless-AC3168 with a new Intel® Killer™ Wi-Fi Series
Boaz83
   I have recently bought a new WiFi 6 router but that doesn`t really help if my computer`s hardware can`t support it. I was trying to look for more information online and see if my motherboard can support a new and better wireless card.
I found a lot of information about Wi-Fi cards and I think; it all comes down to the motherboard and whether it is compatible with the new card or not.
I couldn`t find any information about my motherboard so I am just gonna ask.
can I get the new Killer Wi-Fi 6 card and will it work?
If yes, which one? (picture 4)
hope you can help me soon. thank you Boaz
n_scott_pearson
There are several cards that you could use if Wireless-AC and WiFi 5 capabilities were considered good enough. Since the cards cost roughly the same, however, I recommend upgrading to the latest Wireless-AX and WiFi 6/6e capabilities. To upgrade to the latest Wireless-AX and WiFi 6 support, you need an AX200 module (Killer equivalent is Wi-Fi 6 AX1650 (x/w)). For Wireless-AX and WiFi 6e (which supports the 6GHz band), you need an AX210 module (Killer equivalent is called Wi-Fi 6E AX1675 (x/w)).
Hope this helps,
Boaz83
thank you, Scott.
from your message, though you didn`t actually say it, I understand that the Intel killer Wifi series is not supported by my computer`s Spec but the AX 210 which is good enough is. Thank you for your reply
n_scott_pearson
Actually, the same hardware is used in both cases. The AX200 module is hardware-identical to the AX1650 module; only the id is different. Similarly, the AX210 module is hardware-identical to the AX1675 module; only the id is different. The differing ids cause different firmware - providing the Killer 'goodies' - to be loaded onto and executed by the module.
Bottom line, you can choose whatever you want. I have stuck with the AX200 and AX210 modules myself.
Hope this helps,
Boaz83
I think I get it
I just bought the 210, will update you when it gets here and let you know how it works.
thanks again for taking the time, it does help!
