Wireless
8506 Diskussionen
6GHz not working AX211 Kubuntu 23.04
Snowy
Einsteiger
4.021Aufrufe
I have 2 lenovo computers on Kubuntu 23.04 with Intel Wifi6E cards.
With a CA region specific Wifi6E AP :
P360 tiny with AX211 (stock wifi card) - 6GHz is not working
X270 with AX210 - 6GHz is working correctly
Wireless card are detect without issue, and 5GHz is working fine on both.
However the P360 tiny is not able to detect 6GHz, it appears that it is not allowed to use 6GHz.
Reg region is detected correctly as CA.
P360 tiny:~$ iw reg get
global
country 00: DFS-UNSET
(755 - 928 @ 2), (N/A, 20), (N/A), PASSIVE-SCAN
(2402 - 2472 @ 40), (N/A, 20), (N/A)
(2457 - 2482 @ 20), (N/A, 20), (N/A), AUTO-BW, PASSIVE-SCAN
(2474 - 2494 @ 20), (N/A, 20), (N/A), NO-OFDM, PASSIVE-SCAN
(5170 - 5250 @ 80), (N/A, 20), (N/A), AUTO-BW, PASSIVE-SCAN
(5250 - 5330 @ 80), (N/A, 20), (0 ms), DFS, AUTO-BW, PASSIVE-SCAN
(5490 - 5730 @ 160), (N/A, 20), (0 ms), DFS, PASSIVE-SCAN
(5735 - 5835 @ 80), (N/A, 20), (N/A), PASSIVE-SCAN
(57240 - 63720 @ 2160), (N/A, 0), (N/A)
phy#0 (self-managed)
country CA: DFS-UNSET
(2402 - 2437 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-80MHZ, NO-160MHZ
(2422 - 2462 @ 40), (6, 22), (N/A), AUTO-BW, NO-80MHZ, NO-160MHZ
(2447 - 2482 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-80MHZ, NO-160MHZ
(5170 - 5190 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, PASSIVE-SCAN
(5190 - 5210 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, PASSIVE-SCAN
(5210 - 5230 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, PASSIVE-SCAN
(5230 - 5250 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, PASSIVE-SCAN
(5250 - 5270 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
(5270 - 5290 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
(5290 - 5310 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
(5310 - 5330 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
(5490 - 5510 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
(5510 - 5530 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
(5530 - 5550 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
(5550 - 5570 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
(5570 - 5590 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
(5590 - 5610 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
(5610 - 5630 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
(5630 - 5650 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
(5650 - 5670 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, PASSIVE-SCAN
(5670 - 5690 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, PASSIVE-SCAN
(5690 - 5710 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, PASSIVE-SCAN
(5710 - 5730 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, PASSIVE-SCAN
(5735 - 5755 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-160MHZ
(5755 - 5775 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-160MHZ
(5775 - 5795 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-160MHZ
(5795 - 5815 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-160MHZ
(5815 - 5835 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-80MHZ, NO-160MHZ
No error observed in dmesg :
P360 tiny:~$ sudo dmesg | grep iwl
[ 9.295569] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 9.302164] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
[ 9.302177] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.36
[ 9.302562] iwlwifi 0000:00:14.3: loaded firmware version 72.a764baac.0 so-a0-gf-a0-72.ucode op_mode iwlmvm
[ 9.458637] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6E AX211 160MHz, REV=0x430
[ 9.633881] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x3f
[ 9.633914] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 9.633926] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
[ 9.633959] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
[ 9.634450] iwlwifi 0000:00:14.3: loaded PNVM version 181407b3
[ 9.650958] iwlwifi 0000:00:14.3: Detected RF GF, rfid=0x2010d000
[ 9.719505] iwlwifi 0000:00:14.3: base HW address: 08:9d:f4:90:c4:a5
[ 9.738424] iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
[ 10.825875] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x3f
[ 10.825908] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 10.825916] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
[ 10.825925] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
Firmware is the latest available :
P360 tiny:~$ ll /usr/lib/firmware/iwlwifi-ty-a0-gf-a0*
-rw-r--r-- 1 root root 1413868 Oct 2 23:04 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-59.ucode
-rw-r--r-- 1 root root 1481960 Oct 2 23:04 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-66.ucode
-rw-r--r-- 1 root root 1499284 Oct 2 23:04 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-72.ucode
-rw-r--r-- 1 root root 1502900 Oct 2 23:04 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-73.ucode
-rw-r--r-- 1 root root 1533444 Oct 2 23:04 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-74.ucode
-rw-r--r-- 1 root root 1594276 Oct 2 23:04 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-77.ucode
-rw-r--r-- 1 root root 1620004 Oct 2 23:04 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-78.ucode
-rw-r--r-- 1 root root 1620704 Oct 2 23:04 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-79.ucode
-rw-r--r-- 1 root root 1628828 Oct 2 23:04 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-81.ucode
-rw-r--r-- 1 root root 1683076 Oct 2 23:04 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-83.ucode
-rw-r--r-- 1 root root 55484 Oct 2 23:04 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0.pnvm
Kernel version is 6.2
P360 Tiny:~$ uname -a
Linux Pluto 6.2.0-34-generic #34-Ubuntu SMP PREEMPT_DYNAMIC Mon Sep 4 13:06:55 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
In contrast the 6GHz works on the X270, and the iw reg get results shows 6GHz usable :
X270:~$ iw reg get
global
(5170 - 5190 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5190 - 5210 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5210 - 5230 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5230 - 5250 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5250 - 5270 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5270 - 5290 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5290 - 5310 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5310 - 5330 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5490 - 5510 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5510 - 5530 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5530 - 5550 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5550 - 5570 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5570 - 5590 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5590 - 5610 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5610 - 5630 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5630 - 5650 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5650 - 5670 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
(5670 - 5690 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
(5690 - 5710 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
(5710 - 5730 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
(5735 - 5755 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ
(5755 - 5775 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ
(5775 - 5795 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ
(5795 - 5815 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ
(5815 - 5835 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-80MHZ, NO-160MHZ, NO-320MHZ
(5945 - 5965 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5965 - 5985 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5985 - 6005 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6005 - 6025 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6025 - 6045 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6045 - 6065 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6065 - 6085 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6085 - 6105 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6105 - 6125 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6125 - 6145 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6145 - 6165 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6165 - 6185 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6185 - 6205 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6205 - 6225 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6225 - 6245 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6245 - 6265 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6265 - 6285 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6285 - 6305 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6305 - 6325 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6325 - 6345 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6345 - 6365 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6365 - 6385 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6385 - 6405 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6405 - 6425 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6425 - 6445 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6445 - 6465 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6465 - 6485 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6485 - 6505 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6505 - 6525 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6525 - 6545 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6545 - 6565 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6565 - 6585 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6585 - 6605 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6605 - 6625 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6625 - 6645 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6645 - 6665 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6665 - 6685 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6685 - 6705 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6705 - 6725 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6725 - 6745 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6745 - 6765 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6765 - 6785 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6785 - 6805 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6805 - 6825 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6825 - 6845 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6845 - 6865 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6865 - 6885 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6885 - 6905 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6905 - 6925 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6925 - 6945 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6945 - 6965 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6965 - 6985 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6985 - 7005 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(7005 - 7025 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(7025 - 7045 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(7045 - 7065 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(7065 - 7085 @ 40), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-80MHZ, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
(7085 - 7105 @ 40), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-80MHZ, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
(7105 - 7125 @ 20), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-HT40PLUS, NO-80MHZ, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
X270:~$ sudo dmesg | grep iwl
[ 5.245628] iwlwifi 0000:03:00.0: enabling device (0000 -> 0002)
[ 5.249011] iwlwifi 0000:03:00.0: Detected crf-id 0x400410, cnv-id 0x400410 wfpm id 0x80000000
[ 5.249140] iwlwifi 0000:03:00.0: PCI dev 2725/0020, rev=0x420, rfid=0x10d000
[ 5.271643] iwlwifi 0000:03:00.0: api flags index 2 larger than supported by driver
[ 5.271668] iwlwifi 0000:03:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.41
[ 5.272143] iwlwifi 0000:03:00.0: loaded firmware version 83.e8f84e98.0 ty-a0-gf-a0-83.ucode op_mode iwlmvm
[ 5.497115] iwlwifi 0000:03:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[ 5.514699] iwlwifi 0000:03:00.0: WRT: Invalid buffer destination
[ 5.658657] iwlwifi 0000:03:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x20
[ 5.658684] iwlwifi 0000:03:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 5.658695] iwlwifi 0000:03:00.0: WFPM_AUTH_KEY_0: 0x90
[ 5.658713] iwlwifi 0000:03:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x1
[ 5.660444] iwlwifi 0000:03:00.0: loaded PNVM version 181407b3
[ 5.672219] iwlwifi 0000:03:00.0: Detected RF GF, rfid=0x10d000
[ 5.742379] iwlwifi 0000:03:00.0: base HW address: e8:84:a5:2c:31:57
[ 5.777425] iwlwifi 0000:03:00.0 wlp3s0: renamed from wlan0
[ 11.924946] iwlwifi 0000:03:00.0: WRT: Invalid buffer destination
[ 12.069797] iwlwifi 0000:03:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x20
[ 12.069833] iwlwifi 0000:03:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 12.069852] iwlwifi 0000:03:00.0: WFPM_AUTH_KEY_0: 0x90
[ 12.069876] iwlwifi 0000:03:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x1
[ 12.168041] iwlwifi 0000:03:00.0: Registered PHC clock: iwlwifi-PTP, with index: 1
X270:~$ ll /usr/lib/firmware/iwlwifi-ty-a0-gf-a0*
-rw-r--r-- 1 root root 504272 Sep 22 09:21 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-59.ucode.zst
-rw-r--r-- 1 root root 533796 Sep 22 09:21 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-66.ucode.zst
-rw-r--r-- 1 root root 544119 Sep 22 09:21 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-72.ucode.zst
-rw-r--r-- 1 root root 545410 Sep 22 09:21 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-73.ucode.zst
-rw-r--r-- 1 root root 561263 Sep 22 09:21 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-74.ucode.zst
-rw-r--r-- 1 root root 568930 Sep 22 09:21 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-77.ucode.zst
-rw-r--r-- 1 root root 574893 Sep 22 09:21 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-78.ucode.zst
-rw-r--r-- 1 root root 574867 Sep 22 09:21 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-79.ucode.zst
-rw-r--r-- 1 root root 577400 Sep 22 09:21 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-81.ucode.zst
-rw-r--r-- 1 root root 581973 Sep 22 09:21 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-83.ucode.zst
-rw-r--r-- 1 root root 7304 Sep 22 09:21 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0.pnvm.zst
What can be done to make the 6GHz available on the P360 Tiny ?
10 Antworten
Snowy
Einsteiger
4.011Aufrufe
It does appears that AX211 uses different firmware files as compared to the AX210, but those are still up to date :
P360 tiny:~$ll /usr/lib/firmware/iwlwifi-so-a0-gf-a0*
-rw-r--r-- 1 root root 1560532 Sep 18 16:19 /usr/lib/firmware/iwlwifi-so-a0-gf-a0-72.ucode
-rw-r--r-- 1 root root 1563692 Sep 18 16:19 /usr/lib/firmware/iwlwifi-so-a0-gf-a0-73.ucode
-rw-r--r-- 1 root root 1577460 Sep 18 16:19 /usr/lib/firmware/iwlwifi-so-a0-gf-a0-74.ucode
-rw-r--r-- 1 root root 1641260 Sep 18 16:19 /usr/lib/firmware/iwlwifi-so-a0-gf-a0-77.ucode
-rw-r--r-- 1 root root 1667236 Sep 18 16:19 /usr/lib/firmware/iwlwifi-so-a0-gf-a0-78.ucode
-rw-r--r-- 1 root root 1672988 Sep 18 16:19 /usr/lib/firmware/iwlwifi-so-a0-gf-a0-79.ucode
-rw-r--r-- 1 root root 1682852 Sep 18 16:19 /usr/lib/firmware/iwlwifi-so-a0-gf-a0-81.ucode
-rw-r--r-- 1 root root 1739988 Sep 18 16:19 /usr/lib/firmware/iwlwifi-so-a0-gf-a0-83.ucode
-rw-r--r-- 1 root root 55580 Sep 18 16:19 /usr/lib/firmware/iwlwifi-so-a0-gf-a0.pnvm
Jocelyn_Intel
Mitarbeiter
3.993Aufrufe
Hello, @Snowy
Thank you for posting on the Intel® communities. I will gladly assist you here.
Please, answer these questions to have a better perspective on this issue:
  1. As I understand, the Intel® Wi-Fi 6E AX211 is the pre-installed Wi-Fi card in your laptop, is that correct?
  2. Did you make sure that your Laptop supports this OS with your Laptop manufacturer? These are 2 different models.
  3. Was it working fine before?
  4. Do you have a router compatible with the 6GHz band? Please provide the model.
  5. The other laptop, does it use a 6GHz band without any problems?
  6. Have you run # lspci command to verify the wireless card is recognized?
  7. Make sure that the module is installed properly running # modinfo iwlwifi command.
  8. Type # lsmod | grep iwlwifi to make sure the driver is loaded.
  9. Type # dmesg | grep iwlwifi. If the result is empty, the driver wasn’t initialized.
  10. Type the # dmesg | grep “no suitable firmware found!” command and the result is not empty, that means that you don't have a suitable FW, you need to check here for supported FW or here for latest versions.
Jocelyn M.
Snowy
Einsteiger
3.986Aufrufe
    Yes, however it is not a laptop, it is a small desktop.
    P360 tiny is a small desktop and it does supports Ubuntu linux officially.
    It was and still is working for 5GHz & 2.4GHz.
    I just got a 6GHz AP so 6GHz was not tested previously.
    I am using a standalone AP Sophos AP6 840E, but this should not matter, since the wifi card itself shows that it is not using 6GHz band, from iw reg get output.
    Yes, the SSID was configured for 6GHz only for the test.
    Yes, and this is expected given 5GHz & 2.4GHz works fine :
    00:14.3 Network controller: Intel Corporation Alder Lake-S PCH CNVi WiFi (rev 11)
    I can see the following and no error observed. The output is long, and if you want specific information let me know.
    filename: /lib/modules/6.2.0-34-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
    description: Intel(R) Wireless WiFi driver for Linux
    firmware: iwlwifi-so-a0-gf-a0-72.ucode
    It is, see below :
    iwlwifi 569344 1 iwlmvm
    cfg80211 1241088 3 iwlmvm,iwlwifi,mac80211
    This was included in the initial post, included here again :
    [ 3.835070] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
    [ 3.841652] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
    [ 3.841682] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.36
    [ 3.843212] iwlwifi 0000:00:14.3: loaded firmware version 72.a764baac.0 so-a0-gf-a0-72.ucode op_mode iwlmvm
    [ 4.036668] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6E AX211 160MHz, REV=0x430
    [ 4.211670] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x3f
    [ 4.211701] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
    [ 4.211709] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
    [ 4.211717] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
    [ 4.212070] iwlwifi 0000:00:14.3: loaded PNVM version 181407b3
    [ 4.228728] iwlwifi 0000:00:14.3: Detected RF GF, rfid=0x2010d000
    [ 4.297404] iwlwifi 0000:00:14.3: base HW address: 08:9d:f4:90:c4:a5
    [ 4.312411] iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
    [ 5.304919] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x3f
    [ 5.304930] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
    [ 5.304938] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
    [ 5.304999] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
    Empty result
Jocelyn_Intel
Mitarbeiter
3.983Aufrufe
Hello, @Snowy
Thank you for the information provided.
In order to investigate this issue, please run with # dmesg | grep ASSERT and attach the output in a txt. file. If the output is empty, please follow this wiki to extract dmesg and trace-cmd.
Also, please provide us the dmesg logs running the command # dmesg > dmesg.log along with your system configuration in general, except for your laptop model, OS kernel version, and router (Which I was able to gather previously thanks to your info).
Jocelyn M.
Snowy
Einsteiger
3.958Aufrufe
dmesg | grep ASSERT returns empty output
The wiki was not specific about any action that needs to be carried out with dmesg & trace-cmd, but I have attached a trace-cmd & full dmesg.log.
Intel i7-12700T with 16GB ram & 512GB SSD
Kubuntu 23.04 installed (not upgraded from older versions), firmware was updated manually using
linux-firmware-20230919.tar.gz and reboot has been performed.
Let me know if you need further information or clarification.
Jocelyn_Intel
Mitarbeiter
3.946Aufrufe
Hello, @Snowy
Thank you for the information and the logs provided.
In that case, please provide us an Intel SSU report to have more information so we can investigate, this is for Linux Operating systems. Please run it in the system that cannot connect to 6GHz.
Jocelyn M.
Snowy
Einsteiger
3.917Aufrufe
Please see attached as requested.
Jocelyn_Intel
Mitarbeiter
3.910Aufrufe
Hello, @Snowy
Thank you very much for the reports provided.
Please allow me some time to do some research on this. As soon as I have updates, I will let you know.
Jocelyn M.
Jocelyn_Intel
Mitarbeiter
3.806Aufrufe
Hello, @Snowy
I hope you are doing great. Thank you for your time.
The 6GHz might not be enabled on the platform by the System Manufacturer. We suggest you work with the Lenovo support team to check if they support and unlock the 6GHz usage in BIOS. This is also recommended in the article about this subject: How to Enable Wi-Fi 6E/ 6GHz Band Using Intel® Wi-Fi 6E (Gig+) products
Jocelyn M.
Jocelyn_Intel
Mitarbeiter
3.713Aufrufe
Hello, @Snowy
As we have not heard back from you, we will proceed to close this thread now. I hope you could see my last post.
If you need any further assistance with other matters, please feel free to contact us back and submit a new question as this thread will no longer be monitored.
Jocelyn M.
Antworten
