Win7 Pro x64 identifies it properly as Intel(R) Dual Band Wireless-AC 7260 but 'properties' show no AC details or functionality. I've tried HT and VHT both - no AC connection.
NETSH also does not show "AC" band...
netsh>wlan show driver
Interface name: Wireless Network Connection
Driver : Intel(R) Dual Band Wireless-AC 7260
Vendor : Intel Corporation
Provider : Intel
Date : 10/14/2013
Version : 16.6.0.8
INF file : C:\Windows\INF\oem54.inf
Files : 3 total
C:\Windows\system32\DRIVERS\NETwsw02.sys
C:\Windows\system32\DRIVERS\Netwfw02.dat
C:\Windows\system32\drivers\vwifibus.sys
Type : Native Wi-Fi Driver
Radio types supported : 802.11b 802.11g 802.11n 802.11a
FIPS 140-2 mode supported : Yes
Hosted network supported : Yes
Authentication and cipher supported in infrastructure mode:
Open None
Open WEP-40bit
Open WEP-104bit
Open WEP
Shared WEP-40bit
Shared WEP-104bit
Shared WEP
WPA-Enterprise TKIP
WPA-Enterprise CCMP
WPA-Personal TKIP
WPA-Personal CCMP
WPA2-Enterprise TKIP
WPA2-Enterprise CCMP
WPA2-Personal TKIP
WPA2-Personal CCMP
Open Vendor defined
Authentication and cipher supported in ad-hoc mode:
Open None
Open WEP-40bit
Open WEP-104bit
Open WEP
Shared WEP-40bit
Shared WEP-104bit
Shared WEP
WPA2-Personal CCMP
IHV service present : Yes
IHV adapter OUI : [00 80 86], type: [00]
IHV extensibility DLL path: C:\Windows\System32\IWMSSvc.dll
IHV UI extensibility ClSID: {1bf6cb2d-2ae0-4879-a7aa-a75834fbd0e3}
IHV diagnostics CLSID : {00000000-0000-0000-0000-000000000000}
netsh>?
- « Previous
- Next »
It's more likely that the signal to noise ratio is lower. To obtain the higher 702 to 866.7 Mbps speed, get a line of sight range within the router and 7260. Then you should get at least more than 50 MB/s network transfer rate based on my experience. My speed also drops to 585 Mbps or lower if I'm two walls between the router but it can still transfer all of my 100 Mbps internet without issues. I also get about 35-40 MB/s network transfer speed at those scenarios.
Just got mine working as well. It started to show 802.11ac after updating my driver to 17.13.11.5 (shows as 17.14.0 in the intel website) onto my Windows 8.1 64-bit machine. That driver was released on 26/01/2015, its pretty new, and am glad my laptop recognises it now.
- « Previous
- Next »
