Wireless
8782 Discussions
8265 ngw/g2w
AVolo2
Hello Eugenio,
I am considering to order 8265ngw as it is reported to be compatible with my hardware. [ may I know what is its power consumption in watts?]
But it is not confirmed if d2w will be compatible, as it seems to me.
However, I am wondering if 8625d2w provides LTE, as it is marked with LTE coexistence tag in the specification.
Thank you.
Andrei
Hello, Andrey_nsk. Thank you for your question.
I will perform a deeper research into this. I will be back to you soon.
Antony S.
Hello, Andrey_nsk. Thank you for your patience.
Let me share with you that the Power Consumption data is not publicly available. You may want to create an account in https://www.intel.com/content/www/us/en/design/resource-design-center.html?_ga=2.43762087.362178576.1537300409-287806581.1519233852&elq_cid=905680 Intel® Design and Design Center so you can have access to design documents.
Furthermore, the Intel® Dual Band Wireless AC 8265 (all SKUs) do not include LTE. Basically, when the adapter is used with a compatible LTE module can support LTE coexistence.
It is worth mentioning that the 8265D2W is soldered down so, it can only be installed on a system that is designed for it in a factory.
Antony S.
AVolo2
May be you could advise what antennas to use with that card?
After I have procured the card without antennas it turned out that it can not connect to anywhere. Though it can detect a nearest wifi point but with very low level of signal.
Moreover, I am just wondering if Intel at all provides LTE solutions, LTE or 3/4G solutions in that form factor, or lte/3/4g solutions with sim card slot.
Thank you
Hello Andrey_nsk,
We will do further research about antenna diversity.
Regarding the LTE solutions, please refer to the following support link for more information.
https://www.intel.com/content/www/us/en/mobile/modem-solutions.html Intel® Mobile Modem Solutions
Wanner G.
Under Contract to Intel Corporation
Hello Andrey_nsk,
I hope you found the information about the LTE solutions helpful.
If you still need any assistance, we will be glad to help you.
Wanner G.
AVolo2
Thank you fir the information,
I glanced to the document and it emerged even more questions that I have ever had on the subject.
Trying to formulate clear : could you point out to some modem solution that will fit the same m.2 slot that intel 8265 wifi card does and that will have simcard slot attached in a way that it will wont prevent the card from be installed into generic m.2 wifi/lte slot?
Hello Andrey_nsk,
To get more information about any LTE solutions available, please refer to the support web link provided above. If you have a desktop system, our recommendation is that you purchase the Intel® Dual Band Wireless-AC 8265 Desktop Kit, which includes two antennas.
If you have a mobile platform, then you may need to contact your system manufacturer due to country-specific legal regulations.
Wanner G.
