Wireless
8510 Discussions
AC-3160 disconnects on Win7 64
eKarl
i got a new Laptop, MSI GP70 2PE with the Intel Dual Band Wireless-AC 3160. I have installed Win 7 pro 64bit, (Original!)
Intel Dual Band Wireless-AC 3160 Driver
Driver Date: 18.06.2014
Driver Version: 17.0.5.8
The Router TL-WR1043ND newest FW (3.13.15 Build 140319 Rel.41339n) WPA
The Issue:
The Laptop disconnect the WLAN without reasons. The only way to get it back is the automatic Windows-troubleshooting, after this the connection will work for ~ 2 minutes. This happens in the last 2 hours approx 40 times!!11
There are 2 other WLAN Devices, iPhone and Android they work without problems when the Laptop lost the connection.
I tried too update the Driver with this Software: https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24578 Intel® Download Center http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/24578/eng/Wireless_17.13.11_s64.exe&Lang=deu&Dwnldid=24578 Wireless_17.13.11_s64.exe & http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/24578/eng/Wireless_17.13.11_Ds64.exe&Lang=deu&Dwnldid=24578 Wireless_17.13.11_Ds64.exe doesnt work.
If i install this Driver there is no connection possible! i click on connect and windows just say "no connection possible"
I would need a tool where i can see the WLAN logs from the AC-3160 or something else....
could you please support your product!? Thank you
Jose_H_Intel1
Check the security encryption settings in both the computer wireless profile and the router. Does it work if you use WPA2-AES (CCMP)? You may also test with no security at all just for troubleshooting purposes.
http://www.intel.com/support/wireless/wlan/sb/CS-025807.htm Intel® Wi-Fi Products — Intel® Wireless Event Viewer
http://www.intel.com/support/wireless/wlan/sb/CS-032726.htm Intel® Wi-Fi Products — Driver Wireless Event Viewer Logging
