Wireless
8533 ディスカッション
AC 9560 will not connect if .11r is enabled.
DustinA
初心者
1,538件の閲覧回数
Got an issue we are trying to figure out. We have a lot of Dell towers that have Intel AC 9560 wireless chips. If we enable .11r on the wireless the computers are unable to connect. Everything I find says it is supported and I've tried the current drivers.
Looking for any suggestions.
Site that verifies .11r support
https://www.intel.com/content/www/us/en/support/articles/000021562/wireless.html
ラベル(1)
0 件の賞賛
10 返答(返信)
JedG_Intel
モデレーター
1,468件の閲覧回数
Hello DustinA,
I understand that you are having issues with enabling fast roaming 802.11r. Please share the information below for me to address this properly.
1. Are you able to connect when the 802.r is disabled?
2. Was this working fine before?
3. Are there any recent changes to the system?
4. How many units are affected?
Please also generate SSU report for me to check your system configuration and components.
Jed G.
DustinA
初心者
1,437件の閲覧回数
      Yes
    Unknown. Not usually used wirelessly.
    No
     50-75 wireless. ~500+ wired.
JedG_Intel
モデレーター
1,407件の閲覧回数
Hi DustinA,
Thank you for sharing this information.
I will investigate this matter and I will give you an update as soon as possible.
Jed G.
JedG_Intel
モデレーター
1,375件の閲覧回数
Hello DustinA,
I'm following up on the investigation that I had conducted. Please try IEEE11nMode:802.11n/ac Wireless Mode:"2. 802.11n (1)" change to 802.11ac for AC 9560 settings.
Should you encounter the same issue, please let me know.
Jed G.
JedG_Intel
モデレーター
1,276件の閲覧回数
Hello DustinA,
I wanted to check if you had the chance to try the recommendation I posted. Please let me about the outcome so we can get this matter resolved.
Jed G.
DustinA
初心者
1,254件の閲覧回数
Sorry, been on other stuff also.
No, switching to N or AC does not allow it to connect.
JedG_Intel
モデレーター
1,236件の閲覧回数
Hello DustinA,
I appreciate your efforts in trying the recommendation. I will conduct a thorough investigation to resolve this issue and provide you with an update as soon as possible.
Jed G.
JedG_Intel
モデレーター
1,165件の閲覧回数
Hello DustinA,
As an additional recommendation, please try: MIMOPowerSaveMode:MIMO Power Save Mode:"Auto SMPS (0)" to NO SMPS. Also, Beside AP setting of .11r issue, is 11ac or 11ax working well for AC 9560 to connect?
Jed G.
DustinA
初心者
1,145件の閲覧回数
No luck, and yes with .11r off it works fine ac or ax
JedG_Intel
モデレーター
1,093件の閲覧回数
Hello DustinA,
Given that the provided recommendations did not resolve the issue, I would like to conduct an in-depth investigation. I have sent you an email to facilitate further support. Please check your inbox at your earliest convenience.
Jed G.
返信
