Wireless
8678 Discussions
[AMT] Is that possible using meshcommander to power up system when connecting by WLAN?
SWistron_cindy
I connect the host and client by WLAN and use meshcommander to control the client system.
I would like to know if it is possible to power down the client and then power up by meshcommander?
I can power down the client system by meshcommander but once the system shutdown, these two system seem to disconnect. If I push "Refresh" button, meshcommander show "Time out" after awhile.
But if I connect by wired LAN, the client system can be powered on by meshcommander.
IsaacQ_Intel
Hello SWistron_cindy
1.      Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
2.    Please download and scan your system using our tool, Intel® System Support Utility so we can help check your system info first. Once finished downloading, open the tool, click on scan 'Everything', click next, then save the system information to a .txt file. Please provide the .txt file.
This document will be necessary to check your entire system, in order to find possible errors or incompatibilities.
Isaac Q.
IsaacQ_Intel
Hello SWistron_cindy,
We hope you are doing fine.
Isaac Q.
IsaacQ_Intel
Best regards.
Isaac Q.
