- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Dears,
I have two devices with AX issues :
1)I have desktop with installed TP-Link Archer TX3000E wifi ax adapter with AX200 and yes,I live in Russia .
It is not a laptop, but the latest Bios update is installed.
There are no WiFi6 settings in the bios.
I updated the WiFi driver to version 22.70, but that didn't help, I still can't use 802.11 AX.
I can also say that I've tried different drivers from 22.40 to 22.70, but I still can't connect with AX.
2)Also i have laptop Lenovo T14s with Intel AX201 adapter with the same problem.
Latest Bios update is installed.
I tried different drivers from 22.40 to 22.70, but that didn't help, I still can't use 802.11 AX.
This is actually a horrible situation and I can't understand or justify the vendor's inaction in this situation in any way. It turns out that you are cheating your customers from Russia in the current conditions it is maximal AC adapters but not AX.
Perhaps in the future when choosing equipment you should consider more responsible and more loyal to their customers manufacturers.
However, I still hope, that your support in this matter will change this opinion.
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello neverdrim,
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
· Download the Intel® SSU and save the application on your computer (report from both machines): https://www.intel.com/content/www/us/en/download/18377/25293/intel-system-support-utility-for-windows.html?v=t
· Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
· To save your scan, click Next and click Save.
2. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one? (report from both machines).
3. What is the model name of your router?
Deivid A.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Dear Deivid A.,
Thank you for you response
1) At this moment i have access only to laptop and i add information from laptop to attachment. I send info from my desktop little bit later.
2) It's preinstalled adapter for laptop. And for my desktop computer it was recently added by myself
3) I used TP-Link Archer AX73
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
In this message I attach info file from SSU about my desktop.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello neverdrim,
Based on the information from the reports, please try the following:
- LENOVO ThinkPad T14s Gen 1:
1. Update your Windows version.
2. Update your BIOS version. Check with Lenovo for instructions.
3. Follow the steps from the link below:
- https://www.intel.com/content/www/us/en/support/articles/000058359/wireless.html
- Gigabyte B150M-D3H:
1. I recommend you to check with Gigabyte since this is not an adapter that came preinstalled with the motherboard. Your wireless adapter may not work properly since it may need a BIOS update and the option to be available at the BIOS, the manufacturer may validate your adapter as compatible and supported and provide you with the appropriate steps to enable the "AX" options.
Deivid A.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Dear Delvid A.,
As I wrote earlier, I have already updated everything including drivers and BIOS but no new item and did not appear and AX and does not work.
I have already updated everything including drivers and BIOS too but have the same result. Do yo have some system requirements for this adapter or maaybe it' s worked only with some specific motherboards?
If that's the case, why don't you warn your customers about it? Or are you doing it on purpose to mislead us and sell an inappropriate product?
But my guess is that you simply did not configure this adapter correctly in Intel® Dynamic Regulatory Solution / Location Aware Regulatory (Intel LAR/DRS)
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello neverdrim,
I do understand the situation, allow me to check this issue internally in order to provide you accurate information. A soon as I have any details I will let you know.
Deivid A.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Dear Delvid A,
Thank you in advance.
I look forward to this information.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello neverdrim,
Based on the research performed, please try the following:
1. Update the Wireless driver including the related firmware changes.
2. Update the BIOS provided by the system manufacturer.
3. Enable Wi-Fi 6 in BIOS (check the exact feature name with your system manufacturer).
If the steps did not work, I recommend you to check with the Laptop/motherboard manufacturer, since they may place a restriction or block on their products for the "AX" technology.
Deivid A.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Dear Deivid A.
I don't see the difference between your previous recommendations and this one, nor do I see the results of any of the research. Maybe you just don't want to or can't help me.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello neverdrim,
I am sorry if you feel like we do not want to help you, that was not our intention. In this case, the previous steps are the official solution to this issue.
The option should be part of the BIOS, and that is why we advise updating the BIOS version and this work for the units that came with the wireless adapter pre-installed.
Please try to contact the manufacturer of the laptop/motherboard and let us know the outcome on the manufacturer and we will continue with the support if needed.
Deivid A.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello neverdrim,
Were you able to check the previous post and were you able to get in contact with the manufacturer of the laptop/motherboard? Please let me know if you need more assistance.
Deivid A.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello neverdrim,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
