Wireless
8607 Discussions
AX101 Ubuntu 22.04 or 22.10 driver
EugeneSt
As was suggested here , I started a new thread.
I have troubles with wifi and bluetooth
# dmesg | grep iwlwifi
[ 2.573402] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 2.586226] iwlwifi: No config found for PCI dev 54f0/0244, rev=0x370, rfid=0x10c000
[ 2.586247] iwlwifi: probe of 0000:00:14.3 failed with error -22
# uname -r
6.2.7-060207-generic
# rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
# lspci -kvnn | sed -n '/Network/,/^$/ p'
00:14.3 Network controller [0280]: Intel Corporation Device [8086:54f0]
DeviceName: Onboard - Ethernet
Subsystem: Intel Corporation Device [8086:0244]
Flags: fast devsel, IRQ 16
Memory at 6001114000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [c8] Power Management version 3
Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [40] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [80] MSI-X: Enable- Count=16 Masked-
Capabilities: [100] Latency Tolerance Reporting
Capabilities: [164] Vendor Specific Information: ID=0010 Rev=0 Len=014 <?>
Kernel modules: iwlwifi
help of community  provided: github.com/torvalds/linux/commit/… that looks like need a revert/fix.
This issue is blocking me with usage of my new PC((
Please, help me asap.
Thanks in advance!
Eugene.
metasoft
Thanks @caz.
I used the mainline installer to install any of the later kernel version in Ubuntu or Linux Mint distros.
There are many posts on the mainline installer, here is 1:
https://www.linuxcapable.com/how-to-install-ubuntu-mainline-kernel-installer-on-ubuntu-linux/
Beware installer a newer kernel version can introduce other problems Caveat Emptor.
The next Linux kernel LTS version is 6.6 or so that's the version I would recommend over my initial reply above, which is 6.4.3, for which I had installed and verify AX101, both Bluetooth and Wifi, is working on my Beelink Mini S12 Pro mini PC with the N100 processor with AX101 wifi and bluetooth.
caz
@metasoft , the mainline installer is a much better idea. Thank you for letting me know it.
Meanwhile, I keep updating/upgrading because I already have 24.04. It seems I have tendency to fix by manual operation instead of googling because I worked for a Linux driver of a not-yet-released Intel devices.
