Wireless
8654 Discussions
AX200 160mhz on MSI mainboard doesn't work
VincentH
I have a MSI X570 Unify board which has AX200 160MHz embedded. Wifi stopped working after I did a power off when my OS was stuck. Something I noticed in the dmesg log saying OTP is empty and no valid mac address is found. I did a search in the community, but hasn't found any similar posts. Bluetooth seems working fine though.
What can I do to recover from this?
[ 4.052530] iwlwifi 0000:28:00.0: enabling device (0000 -> 0002)
[ 4.084176] iwlwifi 0000:28:00.0: api flags index 2 larger than supported by driver
[ 4.084188] iwlwifi 0000:28:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.37
[ 4.084320] iwlwifi 0000:28:00.0: loaded firmware version 62.49eeb572.0 cc-a0-62.ucode op_mode iwlmvm
[ 4.172879] iwlwifi 0000:28:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[ 4.306388] iwlwifi 0000:28:00.0: OTP is empty
[ 4.306399] iwlwifi 0000:28:00.0: no valid mac address was found
[ 4.306400] iwlwifi 0000:28:00.0: Failed to read NVM: -22
[ 4.306402] iwlwifi 0000:28:00.0: WRT: Collecting data: ini trigger 13 fired.
[ 4.307530] iwlwifi 0000:28:00.0: Start IWL Error Log Dump:
[ 4.307531] iwlwifi 0000:28:00.0: Status: 0x00000040, count: 6
[ 4.307532] iwlwifi 0000:28:00.0: Loaded firmware version: 62.49eeb572.0 cc-a0-62.ucode
David_G_Intel
Hello VincentH
Thank you for posting on the Intel️® communities.
Please share with us more information:
  • Which Linux distro do you use?
  • Is your driver up to date? Where did you download them from?
  • Error Log Dumps
  • Intel® System Support Utility (Intel® SSU) results:
    • Download the Intel SSU https://downloadcenter.intel.com/download/26735/
    • Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
    • Click on the menu where it says "Summary" to change to "Detailed View".
    • To save your scan, click on "Next", then "Save".
David G
Intel Customer Support Technician
David_G_Intel
David G.
VincentH
After a kernel update (5.12.13), issue is recovered. Thanks for the response.
David_G_Intel
We are glad to know you found a solution, thank you for taking the time to share this fix, and hopefully, it may help other community members experiencing similar behavior. Since the thread is now solved, we will proceed to close it.
David G
