Wireless
8510 Обсуждение
AX200 5Ghz works only with 20Mhz channel width
RAi001
Начинающий
4 561Просмотр.
My network adapter works only with 20Mhz channel width on 5Ghz. When the channel width is set to Auto, I am not able to connect to Internet and the pc is buggy.
I attached the logs of SSU.
Thanks in advance for your help.
0 баллов
6 Ответы
Wanner_G_Intel
Модератор
4 443Просмотр.
Hello RAi001,
Thank you for posting your question on this Intel® Community.
To better assist you, we would like to have more information about your system configuration.
  • Do you know when this issue started to happen? OS or driver update?
  • Is this the original adapter that came pre-installed in your system? Have you changed/installed a new adapter recently?
  • Have you checked if this issue happens on different networks?
  • Has the access point/router or environment changed?
  • What is the model number of your AP/router?
Wanner G.
RAi001
Начинающий
4 443Просмотр.
It is a new device, it has never worked normally.
It is a new PCIe adapter
No
No, and other devices are able to connect to it normally
HOME&LIFE HUB
Wanner_G_Intel
Модератор
4 443Просмотр.
Hello RAi001,
Performing wireless integrations is subject to country-specific legal regulations. Before installing or changing the Intel® Wireless Adapter, you must contact the system manufacturer to obtain approval, step-by-step instructions, and support. It is worth mentioning that the integration may or may not work due to the following reasons:
1. Hardware/software compatibility issues or dependencies.
2. Manufacturer limitations.
3. Driver limitations.
In this scenario, you can try these steps:
Clean Installation of Wireless Drivers
Step 1: Get the latest system-specific driver from your computer manufacturer support.
Step 2: Uninstall your Wi-Fi driver.
Windows* may have an inbox Wi-Fi driver for your wireless adapter. You can't uninstall an inbox driver (you won't see the "Delete the driver software for this device" option). Proceed to the next step if you start seeing the same version of the driver installed automatically after it’s uninstalled.
  1. Go to Device Manager.
  2. Expand the Network Adapters category.
  3. Right-click your Intel Wireless Adapter/Bluetooth and choose to uninstall it.
  4. Make sure to select the option to Delete the driver software for this device.
  5. Restart your computer.
Step 3: Driver installation.
Locate the driver you downloaded back in Step 1. Run as administrator, and follow the wizard to completion.
If the issue persists, please let us know so that we can look into it.
It is worth mentioning that Intel® Wi-Fi 6 AX200 supports 2.4Ghz, 5Ghz (160Mhz), which could mean that the HOME&LIFE HUB is not properly identifying the adapter and the Wi-Fi configuration.
  • Does the AP/router support 802.11ax?
  • Could you please provide us with a specific model number for the HOME&LIFE HUB? We were not able to find additional product specifications with this information.
Wanner G.
Wanner_G_Intel
Модератор
4 443Просмотр.
Hello RAi001,
If you need further assistance, please let us know. We will be glad to help you.
Wanner G.
RAi001
Начинающий
4 443Просмотр.
Thank you for your help, I actually returned the card because it seemed defectious. I replaced it with one that has AC1200 (Archer T4E)
Wanner_G_Intel
Модератор
4 443Просмотр.
Hello RAi001,
Thank you for posting an update.
In this case, we will close the thread. If you need further assistance, please start a new thread. We will be glad to help you.
Wanner G.
Ответить
