Hi All
We used AX200 on our Linux (Ubuntu) , when we connect bluetooth device , the device will disconnect after connect for some seconds later. Even we re-connect again, the device also disconnect for few seconds. Could you help to share some suggestion ?
- Tags:
- Bluetooth
Hi All
We got solution we found
Thanks all
hi @SamM11
Due to we use platform not sure if same with you.
You can refer below link for update USB BT driver
https://gitlab.azka.li/l4t-community/kernel/t194/kernel-5.10
and
to rebuild package
Hi @JustinWang ,
Thanks a lot !!
We use the Nvidia Orin NX for our platform.
So I think this way you provided should be work on our platform too.
