Wireless
8875 Discusiones
AX200 with only one antenna (Blueooth issues)
freedawifi
Principiante
6.888 Vistas
Sadly my laptop only has a single antenna.  Should the antenna hooked up to to the main or aux jack? Asking as I noticed that while the wifi side works for the most part (can be sometimes slow to initially connect), the Bluetooth part is just about completely death. I assumed that the main jack would be the one to use, but I read something about Bluetooth being on the aux jack. Thought I would ask before dissembling the laptop a third time to try it.
0 kudos
1 Solución
n_scott_pearson
Superusuario
6.864 Vistas
It should be connected to the Main pin (are the pin and connector even compatible? I would think not). Bluetooth will be useless unless you add another antenna wire yourself.
Ver la solución en mensaje original publicado
4 Respuestas
n_scott_pearson
Superusuario
6.865 Vistas
freedawifi
Principiante
6.858 Vistas
Thanks for the solution. That's a bit annoying, but I'll take the much increased speed over the original 802.11n card that it replaced.
n_scott_pearson
Superusuario
6.811 Vistas
You can always purchase an antenna wire and add it to the laptop...
AndrewG_Intel
Empleados
6.835 Vistas
Hello @freedawifi
We hope that the information provided by the community has been helpful to clarify your concern. Since the thread has been marked as "Solved" we will proceed to close this inquiry now. If you need any additional information from Intel, please submit a new question as this thread will no longer be monitored.
Andrew G.
Responder
