Wireless
8380 Discussions
AX200NGW vs AX210NGW for Asus TUF FA50611
Overlord
Hi Everyone,
Wanted to replace my Asus TUF FA50611's faulty wifi card. A Youtuber who experienced the same problem with this Asus unit suggested AX200NGW as it works with an AMD processor. However, I've seen this AX210NGW available. would this be better to use this since it's WIFI 6e? (though I don't think I need it right now, but it would be nice to have.) or should I stick with buying AX200NGW? Also, not sure about compatibility with my machine.
Thank you in advance
David_G_Intel
Hello Overlord
Thank you for posting on the Intel️® communities. Before you change the wireless card for one the same model or a different model, you have to check compatibility with the motherboard manufacturer. They will also provide instructions on how to integrate the wireless card if this is possible. For more information please check our article:
You can get the wireless card specifications in our website:
David G
Overlord
Thank you so much @David_G_Intel  for your reply and to @AndrewG_Intel for replying to my question on the other thread regarding this wifi card. Will check all of your suggestion out. Currently, the Intel® Wi-Fi 6E AX210NGW I ordered was already shipped and might take two weeks or so to arrive. I will definitely update this thread and hopefully won't encounter any issues *fingers crossed*.
All the best,
Overlord
uaflyer
Can you advise how it worked out ?
David_G_Intel
We're glad to know the information helped. Hopefully, it will help other community members. Since the thread is now solved, we will close it. If you need any additional information, please submit a new question as this thread will no longer be monitored.
David G
