Wireless
8781 Discussions
AX201/210 5 Ghz connection issue
Tremain
AX210 and AX201 will not connect to ax devices are 5 Ghz. I was asked to spin off my add to another thread by Maria_R_Intel .
Kernel 5.8 won't connect at all while 5.10 and 5.11-rc5 cause the Bluetooth to connect and disconnect very fast causing the Wi-Fi to almost never establish a 5 Ghz connection. 2.4 Ghz works fine, just not 5.
community.intel.com/t5/Wireless/Linux-driver-Wifi-6-AX210-NGW/m-p/1254514#M33970
Sebastian_M_Intel
Hello Tremain,
1. Just to confirm, is this issue happening with 2 different wireless cards (AX201/AX210) in 2 different computers? Are you also having Bluetooth issues with kernel version 5.10 and 5.11? Please explain.
2. Are those the original adapters that came pre-installed on your computer or did you change/install the adapter to this one?
3. Provide the brand and model number of your router/AP.
4. Provide the Intel® System Support Utility for the Linux* Operating System for more details: https://downloadcenter.intel.com/download/26735/Intel-System-Support-Utility-for-the-Linux-Operating...
5. Run the following commands and send us the outcome:
  • modinfo iwlwifi > If there is no output, then the module isn’t installed this is the distribution installation issue.
  • lsmod | grep iwlwifi > If the result is empty, the driver hasn't been loaded. Most likely to be a distribution issue.
  • To verify, please type: dmesg | grep iwlwifi > If the result is empty, the driver wasn’t initialized and this is a distribution issue. If there is a result populated, proceed with the next step.
  • dmesg | grep “no suitable firmware found!” > If the result is not empty, it means you don't have a suitable FW (api mentioned in the dmesg).
  • Please visit here: h ttps://wireless.wiki.kernel.org/en/users/drivers/iwlwifi  for supported FW, or here https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/ for the latest versions.
6. If the above steps don't work, collect the debug data:
Type: dmesg | grep ASSERT
If the output is empty, please follow this wiki: https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi/debugging  to extract dmesg and trace-cmd.
If the output has value, please collect from the wiki FW dump too.
Note: I will send you an e-mail to the e-mail address associated with your community profile. Please reply to the email in order to provide the report(s) in steps 4-6 to avoid exposing sensitive information in the communities.
Sebastian M
Intel Customer Support Technician
Tremain
# SSU Scan Information
Scan Info:
Version:"1.0.0.0"
Scan Date:"2021/02/11"
Scan Time:"13:14:15"
## Scanned Hardware
Computer:
BaseBoard Manufacturer:"Notebook "
Bios Mode:"UEFI"
Bios Version/Date:"1.07.07,06/17/2020"
CD or DVD:"Not Available"
Platform Role:"Linux juno13 5.8.0-41-generic #46~20.04.1-Ubuntu SMP Mon Jan 18 17:52:23 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux"
Processor:"Intel(R) Core(TM) i7-10875H CPU @ 2.30GHz"
Serial Number:"Not Applicable "
SMBIOS Version:"3.2.0"
Sound Cards:"HDA-Intel - HDA Intel PCH"
Sound Cards:"HDA Intel PCH at 0x6014108000 irq 193"
Sound Cards:"HDA-Intel - HDA NVidia"
Sound Cards:"HDA NVidia at 0x88000000 irq 17"
System Manufacturer:"Notebook "
System Model:"PCX0DX "
System Type:"x64-based PC"
- Display
- "Intel Corporation UHD Graphics (rev 05) (prog-if 00 [VGA controller])"
Adapter RAM:"size=256M"
Capabilities:"[40] Vendor Specific Information: Len=0c <?>"
Capabilities:"[70] Express Root Complex Integrated Endpoint, MSI 00"
Capabilities:"[ac] MSI: Enable+ Count=1/1 Maskable- 64bit-"
Capabilities:"[d0] Power Management version 2"
Capabilities:"[100] Process Address Space ID (PASID)"
Capabilities:"[200] Address Translation Service (ATS)"
Capabilities:"[300] Page Request Interface (PRI)"
Caption:"Intel Corporation UHD Graphics (rev 05) (prog-if 00 [VGA controller])"
Device ID:"1558:50d3"
Driver:"i915"
Driver Path:"/lib/modules/5.8.0-41-generic/kernel/drivers/gpu/drm/i915/i915.ko"
Driver Provider:"Intel Corporation"
Driver Provider:"Tungsten Graphics, Inc."
Driver Version:""
Flags:"bus master, fast devsel, latency 0, IRQ 191"
Flags:"bus master, fast devsel, latency 0, IRQ 192"
I/O Ports:"I/O ports at 5000 [size=64]"
I/O Ports:"I/O ports at 4000 [size=128]"
Manufacturer:"NVIDIA Corporation [10DE]"
Manufacturer:"Intel Corporation [8086]"
Power Management Capabilities:"Power Management version 2"
Refresh Rate - Current:"144.00 60.01 59.97 59.96 60.00 59.93 "
Resolution:"1920x1080 60.01 59.97 59.96 60.00 59.93 "
- "NVIDIA Corporation TU106M [GeForce RTX 2060 Mobile] (rev a1) (prog-if 00 [VGA controller])"
Adapter RAM:"size=32M"
Capabilities:"[60] Power Management version 3"
Capabilities:"[68] MSI: Enable+ Count=1/1 Maskable- 64bit+"
Capabilities:"[78] Express Legacy Endpoint, MSI 00"
Capabilities:"[100] Virtual Channel"
Capabilities:"[250] Latency Tolerance Reporting"
Capabilities:"[258] L1 PM Substates"
Capabilities:"[128] Power Budgeting <?>"
Capabilities:"[420] Advanced Error Reporting"
Capabilities:"[600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>"
Capabilities:"[900] Secondary PCI Express"
Capabilities:"[bb0] Resizable BAR <?>"
Caption:"NVIDIA Corporation TU106M [GeForce RTX 2060 Mobile] (rev a1) (prog-if 00 [VGA controller])"
Driver:"i915"
Driver Version:""
Power Management Capabilities:"Power Management version 3"
- Memory
Physical Memory (Available):"58760 MB"
Physical Memory (Installed):"64015 MB"
Physical Memory (Total):"130575 MB"
- "ChannelA-DIMM0"
Capacity:"32 GB"
Configured Clock Speed:"Not Available"
Configured Voltage:"1.2 V"
Data Width:"64 bits"
Form Factor:"SODIMM"
Interleave Position:"First Position"
Locator:"ChannelA-DIMM0"
Manufacturer:"04EF"
Maximum Voltage:"1.5 V"
Minimum Voltage:"1.35 V"
Part Number:"EAMGROUP-SD4-3200"
Serial Number:"02025571"
Type:"Synchronous"
- "ChannelB-DIMM0"
Capacity:"32 GB"
Locator:"ChannelB-DIMM0"
Manufacturer:"04EF"
Serial Number:"02025566"
Type:"Synchronous"
- Motherboard
Product:"PCX0DX "
Version:"Not Applicable "
- Networking
- Interface enp66s0
Auto-Negotiation:"Not Available"
Availability:"enp66s0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500"
Capabilities:"Not Available"
Caption:"Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet "
Default IP Gateway:"Not Available"
DHCP Enabled:"Yes"
DHCP Lease Expires:"Not Available"
DHCP Lease Obtained:"Not Available"
DHCP Server:"Not Available"
Driver:"Not Available"
Driver Path:"Not Available"
Driver Provider:"Not Available"
Driver Version:"Not Available"
Duplex:"Not Available"
Firmware Version:"Not Available"
Interface:"enp66s0"
I/O Ports:"Not Available"
IP Address:"Not Available"
IP Subnet:"Not Available"
MAC Address:"80:fa:5b:85:dd:36"
Manufacturer:"Not Available"
Net Connection ID:"Not Available"
Port:"Not Available"
Power Management:"Not Available"
Supported Link Modes:"Not Available"
Advertised link modes:"Not Available"
Partner advertised link modes:"Not Available"
- Interface tun0
Supports auto-negotiation:"No"
Advertised auto-negotiation:"No"
Auto-negotiation:"off"
Availability:"Not Available"
Default IP Gateway:"10.8.0.1"
DHCP Enabled:"Yes"
Driver:"tun"
Driver Path:"(builtin)"
Driver Provider:"name: tun"
Driver Provider:"(C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>"
Driver Version:""
Duplex:"Full"
Firmware Version:""
Interface:"tun0"
IP Address:"10.8.254.89"
IP Subnet:"255.255.0.0"
MAC Address:"Not Available"
Port:"Twisted Pair"
Speed:"10Mb/s"
Supported link modes:"Not reported, Supported pause frame use: No"
Advertised link modes:"Not reported, Advertised pause frame use: No"
- Interface vmnet1
Availability:"vmnet1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500"
DHCP Enabled:"Yes"
Interface:"vmnet1"
IP Address:"192.168.193.1"
IP Subnet:"255.255.255.0"
MAC Address:"00:50:56:c0:00:01"
- Interface vmnet8
Availability:"vmnet8: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500"
DHCP Enabled:"Yes"
Interface:"vmnet8"
IP Address:"192.168.224.1"
MAC Address:"00:50:56:c0:00:08"
- "Intel Corporation Comet Lake PCH CNVi WiFi"
Availability:"wlp0s20f3: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500"
Capabilities:"[c8] Power Management version 3"
Capabilities:"[d0] MSI: Enable- Count=1/1 Maskable- 64bit+"
Capabilities:"[40] Express Root Complex Integrated Endpoint, MSI 00"
Capabilities:"[80] MSI-X: Enable+ Count=16 Masked-"
Capabilities:"[100] Latency Tolerance Reporting"
Capabilities:"[164] Vendor Specific Information: ID=0010 Rev=0 Len=014 <?>"
Caption:"Not Available"
Default IP Gateway:"10.0.0.1"
DHCP Enabled:"Yes"
Driver:"iwlwifi"
Driver Path:"/lib/modules/5.8.0-41-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko"
Driver Provider:"Intel Corporation <linuxwifi@intel.com>"
Driver Version:""
Firmware Version:"55.d9698065.0 QuZ-a0-hr-b0-55.u"
Interface:"wlp0s20f3"
IP Address:"10.0.0.166"
MAC Address:"f8:ac:65:1f:22:d2"
Manufacturer:"Intel Corporation"
- Operating System
Boot Device:"/dev/nvme0n1p2"
Last Reset:"up 1:01, 1 user, load average: 1.10, 1.24, 1.08"
Locale:"en_US"
OS Manufacturer:"Ubuntu 20.04.2 LTS \n \l"
OS Name:"Ubuntu 20.04.2 LTS \n \l"
Page File:"/swapfile"
Page File Space (Available):"68157436"
Page File Space (Used):"0"
Physical Memory (Available):"58758 MB"
Version:"5.8.0-41-generic GNU/Linux"
Virtual Memory (Available):"68157436"
Virtual Memory (Total):"65552260"
- Processor
- "Intel(R) Core(TM) i7-10875H CPU @ 2.30GHz"
Architecture:"x86_64"
Available:"Offline"
Byte Order:"Little Endian"
Cache Size:"16384 KB"
Caption:"Intel(R) Core(TM) i7-10875H CPU @ 2.30GHz"
- Characteristics
64-bit capable
Enhanced Virtualization
Execute Protection
Hardware Thread
Multi-Core
Power/Performance Control
CPU Speed (Minimum):"2017.711"
CPU Speed (Maximum):"8300 MHz"
Current Voltage:"0.8 V"
External Clock:"100 MHz"
Family:"Core i7"
- Flags
"ACPI (ACPI supported)"
"APIC (On-chip APIC hardware supported)"
"CLFSH (CLFLUSH instruction supported)"
"CMOV (Conditional move instruction supported)"
"CX8 (CMPXCHG8 instruction supported)"
"DE (Debugging extension)"
"DS (Debug store)"
"FPU (Floating-point unit on-chip)"
"FXSR (FXSAVE and FXSTOR instructions supported)"
"HTT (Multi-threading)"
"MCA (Machine check architecture)"
"MCE (Machine check exception)"
"MMX (MMX technology supported)"
"MSR (Model specific registers)"
"MTRR (Memory type range registers)"
"PAE (Physical address extension)"
"PAT (Page attribute table)"
"PBE (Pending break enabled)"
"PGE (Page global enable)"
"PSE-36 (36-bit page size extension)"
"PSE (Page size extension)"
"SEP (Fast system call)"
"SSE2 (Streaming SIMD extensions 2)"
"SSE (Streaming SIMD extensions)"
"SS (Self-snoop)"
"TM (Thermal monitor supported)"
"TSC (Time stamp counter)"
"VME (Virtual mode extension)"
ID:"52 06 0A 00 FF FB EB BF"
Level 1 Cache:"256 KiB
fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb invpcid_single ssbd ibrs ibpb stibp ibrs_enhanced tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid mpx rdseed adx smap clflushopt intel_pt xsaveopt xsavec xgetbv1 xsaves dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp pku ospke md_clear flush_l1d arch_capabilities"
Level 2 Cache:"2 MiB"
Level 3 Cache:"16 MiB"
Load:"load average: 1.10, 1.24, 1.08"
Manufacturer:"Intel(R) Corporation"
Model:"165"
Name:"Intel(R) Core(TM) i7-10875H CPU @ 2.30GHz"
Number of Cores:"8"
Number of Cores - Enabled:"8"
Part Number:"To Be Filled By O.E.M."
Socket Designation:"U3E1"
Status:"Populated, Enabled"
Version:"Intel(R) Core(TM) i7-10875H CPU @ 2.30GHz"
Voltage:"0.8 V"
Virtualization:"Not Available"
- Storage
- "ASM236X_series"
Capabilities:"IORDY not likely"
Capabilities:"Cannot perform double-word IO"
Capabilities:"R/W multiple sector transfer: not supported"
Capabilities:"DMA: not supported"
Capabilities:"PIO: pio0 "
Caption:"/dev/sda"
Cylinders - Total:"0"
Description:"ATA device, with non-removable media"
Firmware:"Not Available"
Heads - Total:"0"
Index:"Not Available"
Interface Type:"ATA"
Model:"Not Available"
Partitions:"Not Available"
Sectors - Per Track:"0"
Serial Number:"Not Available"
Size:"1024*1024: 0 MBytes"
Size:"1000*1000: 0 MBytes"
Size - Available:"Filesystem 1K-blocks Used Available Use% Mounted on"
Size - Available:"/dev/sda1 1921811248 653267656 1170851536 36% /sdb1"
SMART Attributes:""
- "ASM236X_series"
Caption:"/dev/sdb"
Description:"Not Available"
Heads - Total:"0"
Size - Available:"/dev/sdb1 1922206007 994761556 829764682 55% /media/joseph/sda1"
SMART Attributes:""
Tremain
modinfo iwlwifi
filename: /lib/modules/5.8.0-41-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
license: GPL
author: Intel Corporation <linuxwifi@intel.com>
description: Intel(R) Wireless WiFi driver for Linux
firmware: iwlwifi-100-5.ucode
firmware: iwlwifi-1000-5.ucode
firmware: iwlwifi-135-6.ucode
firmware: iwlwifi-105-6.ucode
firmware: iwlwifi-2030-6.ucode
firmware: iwlwifi-2000-6.ucode
firmware: iwlwifi-5150-2.ucode
firmware: iwlwifi-5000-5.ucode
firmware: iwlwifi-6000g2b-6.ucode
firmware: iwlwifi-6000g2a-6.ucode
firmware: iwlwifi-6050-5.ucode
firmware: iwlwifi-6000-6.ucode
firmware: iwlwifi-7265D-29.ucode
firmware: iwlwifi-7265-17.ucode
firmware: iwlwifi-3168-29.ucode
firmware: iwlwifi-3160-17.ucode
firmware: iwlwifi-7260-17.ucode
firmware: iwlwifi-8265-36.ucode
firmware: iwlwifi-8000C-36.ucode
firmware: iwlwifi-9260-th-b0-jf-b0-46.ucode
firmware: iwlwifi-9000-pu-b0-jf-b0-46.ucode
firmware: iwlwifi-SoSnj-a0-gf-a0-56.ucode
firmware: iwlwifi-SoSnj-a0-gf4-a0-56.ucode
firmware: iwlwifi-ty-a0-gf-a0-56.ucode
firmware: iwlwifi-so-a0-gf-a0-56.ucode
firmware: iwlwifi-so-a0-hr-b0-56.ucode
firmware: iwlwifi-so-a0-jf-b0-56.ucode
firmware: iwlwifi-cc-a0-56.ucode
firmware: iwlwifi-QuQnj-b0-jf-b0-56.ucode
firmware: iwlwifi-QuZ-a0-jf-b0-56.ucode
firmware: iwlwifi-QuZ-a0-hr-b0-56.ucode
firmware: iwlwifi-Qu-b0-jf-b0-56.ucode
firmware: iwlwifi-Qu-c0-hr-b0-56.ucode
firmware: iwlwifi-QuQnj-b0-hr-b0-56.ucode
firmware: iwlwifi-Qu-b0-hr-b0-56.ucode
srcversion: 4BEB092F11F7A5F4C35B322
alias: pci:v00008086d00007AF0sv*sd00000A10bc*sc*i*
alias: pci:v00008086d00007AF0sv*sd00000510bc*sc*i*
alias: pci:v00008086d00007AF0sv*sd00000310bc*sc*i*
alias: pci:v00008086d00007AF0sv*sd000000B0bc*sc*i*
alias: pci:v00008086d00007AF0sv*sd00000090bc*sc*i*
alias: pci:v00008086d00007A70sv*sd00000A10bc*sc*i*
alias: pci:v00008086d00007A70sv*sd00000510bc*sc*i*
alias: pci:v00008086d00007A70sv*sd00000310bc*sc*i*
alias: pci:v00008086d00007A70sv*sd000000B0bc*sc*i*
alias: pci:v00008086d00007A70sv*sd00000090bc*sc*i*
alias: pci:v00008086d00002726sv*sd00000510bc*sc*i*
alias: pci:v00008086d00002726sv*sd000000B0bc*sc*i*
alias: pci:v00008086d00002726sv*sd00000090bc*sc*i*
alias: pci:v00008086d00002725sv*sd000000B0bc*sc*i*
alias: pci:v00008086d00002725sv*sd00000A10bc*sc*i*
alias: pci:v00008086d00002725sv*sd00000510bc*sc*i*
alias: pci:v00008086d00002725sv*sd00000310bc*sc*i*
alias: pci:v00008086d00002725sv*sd00000020bc*sc*i*
alias: pci:v00008086d00002725sv*sd00000090bc*sc*i*
alias: pci:v00008086d00002723sv*sd*bc*sc*i*
alias: pci:v00008086d00002720sv*sd*bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd*bc*sc*i*
alias: pci:v00008086d000043F0sv*sd*bc*sc*i*
alias: pci:v00008086d00004DF0sv*sd*bc*sc*i*
alias: pci:v00008086d00003DF0sv*sd*bc*sc*i*
alias: pci:v00008086d000034F0sv*sd*bc*sc*i*
alias: pci:v00008086d000006F0sv*sd*bc*sc*i*
alias: pci:v00008086d000002F0sv*sd*bc*sc*i*
alias: pci:v00008086d0000A370sv*sd*bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd*bc*sc*i*
alias: pci:v00008086d000031DCsv*sd*bc*sc*i*
alias: pci:v00008086d000030DCsv*sd*bc*sc*i*
alias: pci:v00008086d0000271Csv*sd*bc*sc*i*
alias: pci:v00008086d0000271Bsv*sd*bc*sc*i*
alias: pci:v00008086d00002526sv*sd*bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00009074bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000014bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000012bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001012bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00003E01bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00003E02bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001014bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000850bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000950bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000930bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000910bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00008130bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00009110bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000810bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00008010bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00008050bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00008110bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00009010bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000150bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000050bc*sc*i*
alias: pci:v00008086d000024FDsv*sd000010D0bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001010bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000130bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001130bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001110bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000110bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00004010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000000bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000930bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000950bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000850bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000910bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000810bc*sc*i*
alias: pci:v00008086d000024F6sv*sd00000030bc*sc*i*
alias: pci:v00008086d000024F5sv*sd00000010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000044bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000004bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009150bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008150bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009132bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008132bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009130bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008130bc*sc*i*
alias: pci:v00008086d000024F4sv*sd0000D030bc*sc*i*
alias: pci:v00008086d000024F4sv*sd0000C030bc*sc*i*
alias: pci:v00008086d000024F4sv*sd00009030bc*sc*i*
alias: pci:v00008086d000024F4sv*sd00008030bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000B0B0bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000D0B0bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000D050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000C050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000D010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000C110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000C010bc*sc*i*
alias: pci:v00008086d000024F4sv*sd00001030bc*sc*i*
alias: pci:v00008086d000024F4sv*sd00000030bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001150bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000150bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000250bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001012bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000012bc*sc*i*
alias: pci:v00008086d000024F3sv*sd000001F0bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001132bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000132bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001130bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000130bc*sc*i*
alias: pci:v00008086d000024F3sv*sd000010B0bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000010bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009E10bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009400bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009000bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd0000520Abc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005212bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005F10bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005490bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005290bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005590bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005190bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005090bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005420bc*sc*i*
alias: pci:v00008086d0000095Asv*sd0000502Abc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005020bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009410bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00009310bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009510bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00009200bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00009210bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009112bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009110bc*sc*i*
alias: pci:v00008086d0000095Asv*sd0000900Abc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009012bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009010bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005202bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005102bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005002bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005200bc*sc*i*
alias: pci:v00008086d0000095Asv*sd0000500Abc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005000bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00001010bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005400bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005510bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005410bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005412bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005012bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005C10bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005210bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005302bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005310bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005100bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005110bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005010bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00000000bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00002150bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00002050bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00002110bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00002010bc*sc*i*
alias: pci:v00008086d00003165sv*sd00008110bc*sc*i*
alias: pci:v00008086d00003165sv*sd00008010bc*sc*i*
alias: pci:v00008086d00003166sv*sd00004210bc*sc*i*
alias: pci:v00008086d00003166sv*sd00004310bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004110bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004510bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004410bc*sc*i*
alias: pci:v00008086d00003166sv*sd00004212bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004012bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004010bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00001170bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00001070bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008570bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008470bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00008272bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00008370bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00008270bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008062bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008060bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008172bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008170bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008072bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008070bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00000370bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000472bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000470bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00000272bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00000270bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000062bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000060bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000172bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000170bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000072bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000070bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C420bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C220bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C02Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C020bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C360bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C370bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C560bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C570bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C462bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C460bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C472bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C470bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C262bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C26Abc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C260bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C272bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000CC60bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000CC70bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C270bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C760bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C770bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C162bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C062bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C160bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C06Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C060bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C170bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C072bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C070bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004420bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004220bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000402Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004020bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00005770bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00005170bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00005072bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00005070bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004360bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004370bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004560bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004570bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004A6Cbc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004A6Ebc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004A70bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000486Ebc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004870bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004462bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000446Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004460bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004472bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004470bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004262bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000426Abc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004260bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004272bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004270bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004162bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004062bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004160bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000406Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004060bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004C70bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004C60bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004170bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004072bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004070bc*sc*i*
alias: pci:v00008086d00000892sv*sd00000462bc*sc*i*
alias: pci:v00008086d00000893sv*sd00000262bc*sc*i*
alias: pci:v00008086d00000892sv*sd00000062bc*sc*i*
alias: pci:v00008086d00000894sv*sd00000822bc*sc*i*
alias: pci:v00008086d00000894sv*sd00000422bc*sc*i*
alias: pci:v00008086d00000895sv*sd00000222bc*sc*i*
alias: pci:v00008086d00000894sv*sd00000022bc*sc*i*
alias: pci:v00008086d0000088Fsv*sd00005260bc*sc*i*
alias: pci:v00008086d0000088Esv*sd00004860bc*sc*i*
alias: pci:v00008086d0000088Esv*sd0000446Abc*sc*i*
alias: pci:v00008086d0000088Esv*sd00004460bc*sc*i*
alias: pci:v00008086d0000088Fsv*sd0000426Abc*sc*i*
alias: pci:v00008086d0000088Fsv*sd00004260bc*sc*i*
alias: pci:v00008086d0000088Esv*sd0000406Abc*sc*i*
alias: pci:v00008086d0000088Esv*sd00004060bc*sc*i*
alias: pci:v00008086d00000887sv*sd00004462bc*sc*i*
alias: pci:v00008086d00000888sv*sd00004262bc*sc*i*
alias: pci:v00008086d00000887sv*sd00004062bc*sc*i*
alias: pci:v00008086d00000890sv*sd00004822bc*sc*i*
alias: pci:v00008086d00000890sv*sd00004422bc*sc*i*
alias: pci:v00008086d00000891sv*sd00004222bc*sc*i*
alias: pci:v00008086d00000890sv*sd00004022bc*sc*i*
alias: pci:v00008086d00000896sv*sd00005027bc*sc*i*
alias: pci:v00008086d00000896sv*sd00005025bc*sc*i*
alias: pci:v00008086d00000897sv*sd00005017bc*sc*i*
alias: pci:v00008086d00000897sv*sd00005015bc*sc*i*
alias: pci:v00008086d00000896sv*sd00005007bc*sc*i*
alias: pci:v00008086d00000896sv*sd00005005bc*sc*i*
alias: pci:v00008086d000008AEsv*sd00001027bc*sc*i*
alias: pci:v00008086d000008AEsv*sd00001025bc*sc*i*
alias: pci:v00008086d000008AFsv*sd00001017bc*sc*i*
alias: pci:v00008086d000008AFsv*sd00001015bc*sc*i*
alias: pci:v00008086d000008AEsv*sd00001007bc*sc*i*
alias: pci:v00008086d000008AEsv*sd00001005bc*sc*i*
alias: pci:v00008086d00000084sv*sd00001316bc*sc*i*
alias: pci:v00008086d00000084sv*sd00001216bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001326bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001226bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001306bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001206bc*sc*i*
alias: pci:v00008086d00000084sv*sd00001315bc*sc*i*
alias: pci:v00008086d00000084sv*sd00001215bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001325bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001225bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001305bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001205bc*sc*i*
alias: pci:v00008086d00000886sv*sd00001317bc*sc*i*
alias: pci:v00008086d00000886sv*sd00001315bc*sc*i*
alias: pci:v00008086d00000885sv*sd00001327bc*sc*i*
alias: pci:v00008086d00000885sv*sd00001325bc*sc*i*
alias: pci:v00008086d00000885sv*sd00001307bc*sc*i*
alias: pci:v00008086d00000885sv*sd00001305bc*sc*i*
alias: pci:v00008086d00000089sv*sd00001316bc*sc*i*
alias: pci:v00008086d00000089sv*sd00001311bc*sc*i*
alias: pci:v00008086d00000087sv*sd00001326bc*sc*i*
alias: pci:v00008086d00000087sv*sd00001321bc*sc*i*
alias: pci:v00008086d00000087sv*sd00001306bc*sc*i*
alias: pci:v00008086d00000087sv*sd00001301bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005226bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005225bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005221bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005207bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005206bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005205bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005201bc*sc*i*
alias: pci:v00008086d00000090sv*sd00005216bc*sc*i*
alias: pci:v00008086d00000090sv*sd00005215bc*sc*i*
alias: pci:v00008086d00000090sv*sd00005211bc*sc*i*
alias: pci:v00008086d0000008Bsv*sd00005317bc*sc*i*
alias: pci:v00008086d0000008Bsv*sd00005315bc*sc*i*
alias: pci:v00008086d0000008Asv*sd00005327bc*sc*i*
alias: pci:v00008086d0000008Asv*sd00005325bc*sc*i*
alias: pci:v00008086d0000008Asv*sd00005307bc*sc*i*
alias: pci:v00008086d0000008Asv*sd00005305bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001305bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001304bc*sc*i*
alias: pci:v00008086d00000082sv*sd00004820bc*sc*i*
alias: pci:v00008086d00000085sv*sd0000C228bc*sc*i*
alias: pci:v00008086d00000085sv*sd0000C220bc*sc*i*
alias: pci:v00008086d00000082sv*sd0000C020bc*sc*i*
alias: pci:v00008086d00000085sv*sd00001316bc*sc*i*
alias: pci:v00008086d00000085sv*sd00001318bc*sc*i*
alias: pci:v00008086d00000085sv*sd00001311bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001328bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001326bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001321bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001308bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001307bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001306bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001301bc*sc*i*
alias: pci:v00008086d00004239sv*sd00001316bc*sc*i*
alias: pci:v00008086d00004239sv*sd00001311bc*sc*i*
alias: pci:v00008086d00004238sv*sd00001118bc*sc*i*
alias: pci:v00008086d00004238sv*sd00001111bc*sc*i*
alias: pci:v00008086d0000422Csv*sd00001326bc*sc*i*
alias: pci:v00008086d0000422Csv*sd00001321bc*sc*i*
alias: pci:v00008086d0000422Csv*sd00001307bc*sc*i*
alias: pci:v00008086d0000422Csv*sd00001306bc*sc*i*
alias: pci:v00008086d0000422Csv*sd00001301bc*sc*i*
alias: pci:v00008086d0000422Bsv*sd00001128bc*sc*i*
alias: pci:v00008086d0000422Bsv*sd00001121bc*sc*i*
alias: pci:v00008086d0000422Bsv*sd00001108bc*sc*i*
alias: pci:v00008086d0000422Bsv*sd00001101bc*sc*i*
alias: pci:v00008086d0000423Dsv*sd00001316bc*sc*i*
alias: pci:v00008086d0000423Dsv*sd00001216bc*sc*i*
alias: pci:v00008086d0000423Dsv*sd00001311bc*sc*i*
alias: pci:v00008086d0000423Dsv*sd00001211bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001326bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001321bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001221bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001306bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001206bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001301bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001201bc*sc*i*
alias: pci:v00008086d0000423Bsv*sd00001011bc*sc*i*
alias: pci:v00008086d0000423Asv*sd00001021bc*sc*i*
alias: pci:v00008086d0000423Asv*sd00001001bc*sc*i*
alias: pci:v00008086d00004236sv*sd00001114bc*sc*i*
alias: pci:v00008086d00004236sv*sd00001014bc*sc*i*
alias: pci:v00008086d00004236sv*sd00001111bc*sc*i*
alias: pci:v00008086d00004236sv*sd00001011bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001104bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001004bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001101bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001001bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001124bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001024bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001121bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001021bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001316bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001216bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001315bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001215bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001314bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001214bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001311bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001211bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001326bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001226bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001325bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001225bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001324bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001224bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001321bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001221bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001306bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001206bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001305bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001205bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001304bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001204bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001301bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001201bc*sc*i*
depends: cfg80211
retpoline: Y
intree: Y
vermagic: 5.8.0-41-generic SMP mod_unload
sig_id: PKCS#7
signer: Build time autogenerated kernel key
sig_key: 61:D3:65:6A:77:23:F1:D8:8E:8A:BB:48:18:CF:76:EA:2F:09:44:3F
sig_hashalgo: sha512
signature: C4:26:CA:0E:E8:39:18:F9:38:92:09:E7:B1:54:C7:36:F4:2C:20:99:
54:56:8B:13:9E:6C:FF:75:B4:AE:4E:BD:C6:20:BD:F3:77:29:33:DC:
A7:1E:C7:DF:5E:D6:58:AB:82:C8:2F:87:FD:0D:50:BE:3B:08:F8:77:
25:32:10:1D:14:5A:BB:06:D9:B3:B8:82:BE:94:B5:7B:13:C9:24:80:
FC:06:2F:D8:30:84:57:A7:B9:EB:4B:AE:C6:B3:38:D7:BB:2A:1E:A4:
3F:EA:BB:D7:62:66:A6:58:76:12:4A:6C:53:C2:15:A3:6F:0C:4C:E2:
23:1A:0C:0C:BA:13:9A:AE:E8:FC:13:53:DB:C1:5F:90:37:6B:1D:EF:
07:06:B9:DE:31:0D:2F:7E:78:FE:3A:2F:63:11:EE:2A:34:B9:9F:BF:
ED:D4:49:45:28:7D:78:92:36:EF:15:F3:55:75:12:2D:67:50:34:EE:
EC:72:EA:0D:DA:01:E6:83:CA:E7:4F:F9:86:60:36:77:C2:28:91:98:
1F:04:39:4E:A9:6C:72:D1:3B:E1:8E:71:AB:CF:FC:5C:44:9D:3A:F5:
BB:80:E6:78:A8:49:B3:07:47:48:3C:9E:B4:C9:36:86:13:6A:6E:60:
BF:11:AA:07:E1:1F:02:46:15:B6:89:55:79:57:69:19:63:7C:0D:1F:
70:84:EE:00:E7:B0:EA:79:C5:51:73:04:3E:47:D4:30:06:1E:B8:AF:
88:45:87:CE:11:9B:BB:71:2A:16:A3:D9:29:DD:E9:45:FB:BA:B3:F1:
C3:80:3F:D5:61:B3:30:95:4A:4E:03:1C:E4:87:03:79:D7:11:EA:4F:
5D:DB:10:47:CD:78:65:C3:94:14:F7:DF:60:E2:3B:53:A5:E3:1A:5D:
94:52:A3:81:2A:12:CE:6A:75:DE:DD:3F:05:D6:AE:C8:2D:B6:15:24:
B7:02:E9:0C:D2:D7:66:6C:2A:2D:AF:EA:E1:55:99:C2:F3:98:E3:C9:
8C:47:8F:96:D3:E5:BE:13:C8:47:27:76:58:77:1B:69:C8:48:C0:B7:
D0:5F:3D:5E:7A:C5:29:C5:07:C6:F5:32:C8:9B:B4:97:69:BE:5C:49:
BD:2C:5F:F5:FF:D6:E0:D8:32:2F:00:E3:28:8E:8B:42:AC:6E:AB:18:
14:9D:24:0F:D9:95:C2:9F:28:5C:07:7F:C3:95:48:5F:B7:3B:B0:33:
EE:37:A9:5D:29:B7:26:52:5F:47:CF:AA:01:89:0A:59:EF:5E:35:A6:
E6:C5:BA:C2:92:9B:8A:29:32:BA:E7:12:A9:59:35:61:1E:83:37:AE:
F9:0F:29:90:ED:16:97:63:5A:B9:E1:9B
parm: swcrypto:using crypto in software (default 0 [hardware]) (int)
parm: 11n_disable:disable 11n functionality, bitmap: 1: full, 2: disable agg TX, 4: disable agg RX, 8 enable agg TX (uint)
parm: amsdu_size:amsdu size 0: 12K for multi Rx queue devices, 2K for AX210 devices, 4K for other devices 1:4K 2:8K 3:12K 4: 2K (default 0) (int)
parm: fw_restart:restart firmware in case of error (default true) (bool)
parm: nvm_file:NVM file name (charp)
parm: uapsd_disable:disable U-APSD functionality bitmap 1: BSS 2: P2P Client (default: 3) (uint)
parm: enable_ini:Enable debug INI TLV FW debug infrastructure (default: true (bool)
parm: bt_coex_active:enable wifi/bt co-exist (default: enable) (bool)
parm: led_mode:0=system default, 1=On(RF On)/Off(RF Off), 2=blinking, 3=Off (default: 0) (int)
parm: power_save:enable WiFi power management (default: disable) (bool)
parm: power_level:default power save level (range from 1 - 5, default: 1) (int)
parm: disable_11ac:Disable VHT capabilities (default: false) (bool)
parm: remove_when_gone:Remove dev from PCIe bus if it is deemed inaccessible (default: false) (bool)
parm: disable_11ax:Disable HE capabilities (default: false) (bool)
Tremain
iwlwifi 352256 1 iwlmvm
cfg80211 778240 3 iwlmvm,iwlwifi,mac80211
Tremain
[ 4592.350821] iwlwifi 0000:00:14.3: Got NSS = 4 - trimming to 2
[ 4602.419575] iwlwifi 0000:00:14.3: Queue 5 is stuck 0 42
[ 4602.419618] iwlwifi 0000:00:14.3: Queue 4 is stuck 0 4
[ 4602.419773] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[ 4602.419854] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 4602.419858] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 6
[ 4602.419861] iwlwifi 0000:00:14.3: Loaded firmware version: 55.d9698065.0 QuZ-a0-hr-b0-55.ucode
[ 4602.419865] iwlwifi 0000:00:14.3: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[ 4602.419867] iwlwifi 0000:00:14.3: 0x0000A2F0 | trm_hw_status0
[ 4602.419870] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 4602.419872] iwlwifi 0000:00:14.3: 0x004CA3DE | branchlink2
[ 4602.419874] iwlwifi 0000:00:14.3: 0x004B4C10 | interruptlink1
[ 4602.419877] iwlwifi 0000:00:14.3: 0x004B4C10 | interruptlink2
[ 4602.419879] iwlwifi 0000:00:14.3: 0x00016504 | data1
[ 4602.419881] iwlwifi 0000:00:14.3: 0xFF000000 | data2
[ 4602.419883] iwlwifi 0000:00:14.3: 0x00000000 | data3
[ 4602.419886] iwlwifi 0000:00:14.3: 0x1880E614 | beacon time
[ 4602.419888] iwlwifi 0000:00:14.3: 0x933D89C0 | tsf low
[ 4602.419890] iwlwifi 0000:00:14.3: 0x000000BD | tsf hi
[ 4602.419893] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 4602.419895] iwlwifi 0000:00:14.3: 0x11D97E83 | time gp2
[ 4602.419897] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
[ 4602.419899] iwlwifi 0000:00:14.3: 0x00000037 | uCode version major
[ 4602.419902] iwlwifi 0000:00:14.3: 0xD9698065 | uCode version minor
[ 4602.419904] iwlwifi 0000:00:14.3: 0x00000351 | hw version
[ 4602.419906] iwlwifi 0000:00:14.3: 0x00C89004 | board version
[ 4602.419909] iwlwifi 0000:00:14.3: 0x8063FD25 | hcmd
[ 4602.419911] iwlwifi 0000:00:14.3: 0x20028000 | isr0
[ 4602.419913] iwlwifi 0000:00:14.3: 0x00000000 | isr1
[ 4602.419915] iwlwifi 0000:00:14.3: 0x08F00002 | isr2
[ 4602.419918] iwlwifi 0000:00:14.3: 0x00C33608 | isr3
[ 4602.419920] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 4602.419922] iwlwifi 0000:00:14.3: 0x0025019C | last cmd Id
[ 4602.419924] iwlwifi 0000:00:14.3: 0x00016504 | wait_event
[ 4602.419927] iwlwifi 0000:00:14.3: 0x00000080 | l2p_control
[ 4602.419929] iwlwifi 0000:00:14.3: 0x00000000 | l2p_duration
[ 4602.419931] iwlwifi 0000:00:14.3: 0x0000003F | l2p_mhvalid
[ 4602.419934] iwlwifi 0000:00:14.3: 0x00000080 | l2p_addr_match
[ 4602.419936] iwlwifi 0000:00:14.3: 0x00000009 | lmpm_pmg_sel
[ 4602.419938] iwlwifi 0000:00:14.3: 0x00000000 | timestamp
[ 4602.419940] iwlwifi 0000:00:14.3: 0x000088D0 | flow_handler
[ 4602.419977] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 4602.419979] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 7
[ 4602.419982] iwlwifi 0000:00:14.3: 0x20000066 | NMI_INTERRUPT_HOST
[ 4602.419984] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 4602.419986] iwlwifi 0000:00:14.3: 0x80465D2E | umac branchlink2
[ 4602.419989] iwlwifi 0000:00:14.3: 0x80480EC8 | umac interruptlink1
[ 4602.419991] iwlwifi 0000:00:14.3: 0x80480EC8 | umac interruptlink2
[ 4602.419993] iwlwifi 0000:00:14.3: 0x01000000 | umac data1
[ 4602.419995] iwlwifi 0000:00:14.3: 0x80480EC8 | umac data2
[ 4602.419998] iwlwifi 0000:00:14.3: 0x00000000 | umac data3
[ 4602.420000] iwlwifi 0000:00:14.3: 0x00000037 | umac major
[ 4602.420002] iwlwifi 0000:00:14.3: 0xD9698065 | umac minor
[ 4602.420004] iwlwifi 0000:00:14.3: 0x11D97E7E | frame pointer
[ 4602.420006] iwlwifi 0000:00:14.3: 0xC0886270 | stack pointer
[ 4602.420009] iwlwifi 0000:00:14.3: 0x0027010C | last host cmd
[ 4602.420011] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 4602.420029] iwlwifi 0000:00:14.3: Fseq Registers:
[ 4602.420050] iwlwifi 0000:00:14.3: 0x60000000 | FSEQ_ERROR_CODE
[ 4602.420054] iwlwifi 0000:00:14.3: 0x80290033 | FSEQ_TOP_INIT_VERSION
[ 4602.420074] iwlwifi 0000:00:14.3: 0x00090006 | FSEQ_CNVIO_INIT_VERSION
[ 4602.420078] iwlwifi 0000:00:14.3: 0x0000A482 | FSEQ_OTP_VERSION
[ 4602.420098] iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
[ 4602.420102] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 4602.420121] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
[ 4602.420125] iwlwifi 0000:00:14.3: 0x01300504 | FSEQ_CNVR_ID
[ 4602.420146] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[ 4602.420152] iwlwifi 0000:00:14.3: 0x01300504 | CNVR_AUX_MISC_CHIP
[ 4602.420174] iwlwifi 0000:00:14.3: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 4602.420196] iwlwifi 0000:00:14.3: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 4602.420307] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 4 fired.
[ 4602.951313] iwlwifi 0000:00:14.3: Failed to get the temperature (err=-5)
[ 4603.159508] iwlwifi 0000:00:14.3: Got NSS = 4 - trimming to 2
[ 4603.159761] iwlwifi 0000:00:14.3: Got NSS = 4 - trimming to 2
[ 4614.195677] iwlwifi 0000:00:14.3: Queue 2 is stuck 0 17
[ 4614.195853] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[ 4614.195935] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 4614.195939] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 6
[ 4614.195942] iwlwifi 0000:00:14.3: Loaded firmware version: 55.d9698065.0 QuZ-a0-hr-b0-55.ucode
[ 4614.195945] iwlwifi 0000:00:14.3: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[ 4614.195948] iwlwifi 0000:00:14.3: 0x00003EF7 | trm_hw_status0
[ 4614.195950] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 4614.195953] iwlwifi 0000:00:14.3: 0x004CA3DE | branchlink2
[ 4614.195955] iwlwifi 0000:00:14.3: 0x004C9C66 | interruptlink1
[ 4614.195958] iwlwifi 0000:00:14.3: 0x004C9C66 | interruptlink2
[ 4614.195960] iwlwifi 0000:00:14.3: 0x004BB074 | data1
[ 4614.195962] iwlwifi 0000:00:14.3: 0xFF000000 | data2
[ 4614.195965] iwlwifi 0000:00:14.3: 0x00000000 | data3
[ 4614.195967] iwlwifi 0000:00:14.3: 0x1B00E5A3 | beacon time
[ 4614.195969] iwlwifi 0000:00:14.3: 0x93F13A32 | tsf low
[ 4614.195971] iwlwifi 0000:00:14.3: 0x000000BD | tsf hi
[ 4614.195974] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 4614.195976] iwlwifi 0000:00:14.3: 0x00AB2183 | time gp2
[ 4614.195979] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
[ 4614.195981] iwlwifi 0000:00:14.3: 0x00000037 | uCode version major
[ 4614.195983] iwlwifi 0000:00:14.3: 0xD9698065 | uCode version minor
[ 4614.195986] iwlwifi 0000:00:14.3: 0x00000351 | hw version
[ 4614.195988] iwlwifi 0000:00:14.3: 0x00C89004 | board version
[ 4614.195990] iwlwifi 0000:00:14.3: 0x80F1FD25 | hcmd
[ 4614.195993] iwlwifi 0000:00:14.3: 0xE3F20400 | isr0
[ 4614.195995] iwlwifi 0000:00:14.3: 0x00000000 | isr1
[ 4614.195997] iwlwifi 0000:00:14.3: 0x08F00002 | isr2
[ 4614.195999] iwlwifi 0000:00:14.3: 0x04C37FDC | isr3
[ 4614.196001] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 4614.196004] iwlwifi 0000:00:14.3: 0x0066019C | last cmd Id
[ 4614.196006] iwlwifi 0000:00:14.3: 0x004BB074 | wait_event
[ 4614.196008] iwlwifi 0000:00:14.3: 0x00000080 | l2p_control
[ 4614.196011] iwlwifi 0000:00:14.3: 0x00003C20 | l2p_duration
[ 4614.196013] iwlwifi 0000:00:14.3: 0x0000003F | l2p_mhvalid
[ 4614.196015] iwlwifi 0000:00:14.3: 0x00000080 | l2p_addr_match
[ 4614.196017] iwlwifi 0000:00:14.3: 0x00000009 | lmpm_pmg_sel
[ 4614.196020] iwlwifi 0000:00:14.3: 0x00000000 | timestamp
[ 4614.196022] iwlwifi 0000:00:14.3: 0x00007040 | flow_handler
[ 4614.196064] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 4614.196066] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 7
[ 4614.196069] iwlwifi 0000:00:14.3: 0x20000066 | NMI_INTERRUPT_HOST
[ 4614.196071] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 4614.196074] iwlwifi 0000:00:14.3: 0x80465D2E | umac branchlink2
[ 4614.196076] iwlwifi 0000:00:14.3: 0x80480EC8 | umac interruptlink1
[ 4614.196078] iwlwifi 0000:00:14.3: 0x80480EC8 | umac interruptlink2
[ 4614.196080] iwlwifi 0000:00:14.3: 0x01000000 | umac data1
[ 4614.196082] iwlwifi 0000:00:14.3: 0x80480EC8 | umac data2
[ 4614.196085] iwlwifi 0000:00:14.3: 0x00000000 | umac data3
[ 4614.196087] iwlwifi 0000:00:14.3: 0x00000037 | umac major
[ 4614.196089] iwlwifi 0000:00:14.3: 0xD9698065 | umac minor
[ 4614.196091] iwlwifi 0000:00:14.3: 0x00AB217F | frame pointer
[ 4614.196094] iwlwifi 0000:00:14.3: 0xC0886270 | stack pointer
[ 4614.196096] iwlwifi 0000:00:14.3: 0x0066019C | last host cmd
[ 4614.196098] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 4614.196117] iwlwifi 0000:00:14.3: Fseq Registers:
[ 4614.196137] iwlwifi 0000:00:14.3: 0x60000000 | FSEQ_ERROR_CODE
[ 4614.196142] iwlwifi 0000:00:14.3: 0x80290033 | FSEQ_TOP_INIT_VERSION
[ 4614.196162] iwlwifi 0000:00:14.3: 0x00090006 | FSEQ_CNVIO_INIT_VERSION
[ 4614.196167] iwlwifi 0000:00:14.3: 0x0000A482 | FSEQ_OTP_VERSION
[ 4614.196188] iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
[ 4614.196192] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 4614.196211] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
[ 4614.196216] iwlwifi 0000:00:14.3: 0x01300504 | FSEQ_CNVR_ID
[ 4614.196236] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[ 4614.196259] iwlwifi 0000:00:14.3: 0x01300504 | CNVR_AUX_MISC_CHIP
[ 4614.196282] iwlwifi 0000:00:14.3: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 4614.196304] iwlwifi 0000:00:14.3: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 4614.196499] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 4 fired.
[ 4614.799064] iwlwifi 0000:00:14.3: Got NSS = 4 - trimming to 2
[ 4614.799259] iwlwifi 0000:00:14.3: Got NSS = 4 - trimming to 2
[ 4625.203701] iwlwifi 0000:00:14.3: Queue 2 is stuck 0 24
[ 4625.203855] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[ 4625.203936] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 4625.203940] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 6
[ 4625.203943] iwlwifi 0000:00:14.3: Loaded firmware version: 55.d9698065.0 QuZ-a0-hr-b0-55.ucode
[ 4625.203947] iwlwifi 0000:00:14.3: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[ 4625.203949] iwlwifi 0000:00:14.3: 0x00803EF4 | trm_hw_status0
[ 4625.203951] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 4625.203953] iwlwifi 0000:00:14.3: 0x004CA3DE | branchlink2
[ 4625.203955] iwlwifi 0000:00:14.3: 0x004B4C10 | interruptlink1
[ 4625.203956] iwlwifi 0000:00:14.3: 0x004B4C10 | interruptlink2
[ 4625.203958] iwlwifi 0000:00:14.3: 0x000079A0 | data1
[ 4625.203960] iwlwifi 0000:00:14.3: 0xFF000000 | data2
[ 4625.203962] iwlwifi 0000:00:14.3: 0x00000000 | data3
[ 4625.203964] iwlwifi 0000:00:14.3: 0x19801D8C | beacon time
[ 4625.203966] iwlwifi 0000:00:14.3: 0x94993245 | tsf low
[ 4625.203967] iwlwifi 0000:00:14.3: 0x000000BD | tsf hi
[ 4625.203969] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 4625.203971] iwlwifi 0000:00:14.3: 0x00A1961D | time gp2
[ 4625.203973] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
[ 4625.203975] iwlwifi 0000:00:14.3: 0x00000037 | uCode version major
[ 4625.203977] iwlwifi 0000:00:14.3: 0xD9698065 | uCode version minor
[ 4625.203978] iwlwifi 0000:00:14.3: 0x00000351 | hw version
[ 4625.203980] iwlwifi 0000:00:14.3: 0x00C89004 | board version
[ 4625.203982] iwlwifi 0000:00:14.3: 0x0200001C | hcmd
[ 4625.203984] iwlwifi 0000:00:14.3: 0x80020000 | isr0
[ 4625.203986] iwlwifi 0000:00:14.3: 0x00000000 | isr1
[ 4625.203988] iwlwifi 0000:00:14.3: 0x08F00002 | isr2
[ 4625.203989] iwlwifi 0000:00:14.3: 0x00C377CC | isr3
[ 4625.203991] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 4625.203993] iwlwifi 0000:00:14.3: 0x0054019C | last cmd Id
[ 4625.203995] iwlwifi 0000:00:14.3: 0x000079A0 | wait_event
[ 4625.203997] iwlwifi 0000:00:14.3: 0x000000D4 | l2p_control
[ 4625.203998] iwlwifi 0000:00:14.3: 0x00002020 | l2p_duration
[ 4625.204000] iwlwifi 0000:00:14.3: 0x00000007 | l2p_mhvalid
[ 4625.204002] iwlwifi 0000:00:14.3: 0x00000081 | l2p_addr_match
[ 4625.204004] iwlwifi 0000:00:14.3: 0x00000009 | lmpm_pmg_sel
[ 4625.204006] iwlwifi 0000:00:14.3: 0x00000000 | timestamp
[ 4625.204007] iwlwifi 0000:00:14.3: 0x000060B4 | flow_handler
[ 4625.204042] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 4625.204044] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 7
[ 4625.204046] iwlwifi 0000:00:14.3: 0x20000066 | NMI_INTERRUPT_HOST
[ 4625.204048] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 4625.204050] iwlwifi 0000:00:14.3: 0x80465D2E | umac branchlink2
[ 4625.204052] iwlwifi 0000:00:14.3: 0x80480EC8 | umac interruptlink1
[ 4625.204053] iwlwifi 0000:00:14.3: 0x80480EC8 | umac interruptlink2
[ 4625.204055] iwlwifi 0000:00:14.3: 0x01000000 | umac data1
[ 4625.204057] iwlwifi 0000:00:14.3: 0x80480EC8 | umac data2
[ 4625.204059] iwlwifi 0000:00:14.3: 0x00000000 | umac data3
[ 4625.204061] iwlwifi 0000:00:14.3: 0x00000037 | umac major
[ 4625.204062] iwlwifi 0000:00:14.3: 0xD9698065 | umac minor
[ 4625.204064] iwlwifi 0000:00:14.3: 0x00A19619 | frame pointer
[ 4625.204066] iwlwifi 0000:00:14.3: 0xC0886270 | stack pointer
[ 4625.204068] iwlwifi 0000:00:14.3: 0x0054019C | last host cmd
[ 4625.204070] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 4625.204087] iwlwifi 0000:00:14.3: Fseq Registers:
[ 4625.204108] iwlwifi 0000:00:14.3: 0x60000000 | FSEQ_ERROR_CODE
[ 4625.204111] iwlwifi 0000:00:14.3: 0x80290033 | FSEQ_TOP_INIT_VERSION
[ 4625.204132] iwlwifi 0000:00:14.3: 0x00090006 | FSEQ_CNVIO_INIT_VERSION
[ 4625.204135] iwlwifi 0000:00:14.3: 0x0000A482 | FSEQ_OTP_VERSION
[ 4625.204155] iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
[ 4625.204158] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 4625.204178] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
[ 4625.204182] iwlwifi 0000:00:14.3: 0x01300504 | FSEQ_CNVR_ID
[ 4625.204201] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[ 4625.204207] iwlwifi 0000:00:14.3: 0x01300504 | CNVR_AUX_MISC_CHIP
[ 4625.204229] iwlwifi 0000:00:14.3: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 4625.204251] iwlwifi 0000:00:14.3: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 4625.204357] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 4 fired.
[ 4625.595012] iwlwifi 0000:00:14.3: Failed to get the temperature (err=-5)
[ 4625.797537] iwlwifi 0000:00:14.3: Got NSS = 4 - trimming to 2
[ 4625.797730] iwlwifi 0000:00:14.3: Got NSS = 4 - trimming to 2
[ 4636.467849] iwlwifi 0000:00:14.3: Queue 2 is stuck 0 32
[ 4636.468007] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[ 4636.468086] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 4636.468089] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 6
[ 4636.468091] iwlwifi 0000:00:14.3: Loaded firmware version: 55.d9698065.0 QuZ-a0-hr-b0-55.ucode
[ 4636.468093] iwlwifi 0000:00:14.3: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[ 4636.468095] iwlwifi 0000:00:14.3: 0x00803EF4 | trm_hw_status0
[ 4636.468097] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 4636.468098] iwlwifi 0000:00:14.3: 0x004CA3DE | branchlink2
[ 4636.468100] iwlwifi 0000:00:14.3: 0x000147C0 | interruptlink1
[ 4636.468102] iwlwifi 0000:00:14.3: 0x000147C0 | interruptlink2
[ 4636.468103] iwlwifi 0000:00:14.3: 0x000079A0 | data1
[ 4636.468105] iwlwifi 0000:00:14.3: 0xFF000000 | data2
[ 4636.468107] iwlwifi 0000:00:14.3: 0x00000000 | data3
[ 4636.468108] iwlwifi 0000:00:14.3: 0x1A001CF4 | beacon time
[ 4636.468110] iwlwifi 0000:00:14.3: 0x954512DE | tsf low
[ 4636.468111] iwlwifi 0000:00:14.3: 0x000000BD | tsf hi
[ 4636.468113] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 4636.468115] iwlwifi 0000:00:14.3: 0x00A57977 | time gp2
[ 4636.468116] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
[ 4636.468118] iwlwifi 0000:00:14.3: 0x00000037 | uCode version major
[ 4636.468119] iwlwifi 0000:00:14.3: 0xD9698065 | uCode version minor
[ 4636.468121] iwlwifi 0000:00:14.3: 0x00000351 | hw version
[ 4636.468123] iwlwifi 0000:00:14.3: 0x00C89004 | board version
[ 4636.468124] iwlwifi 0000:00:14.3: 0x0300001C | hcmd
[ 4636.468126] iwlwifi 0000:00:14.3: 0x80020000 | isr0
[ 4636.468128] iwlwifi 0000:00:14.3: 0x00000000 | isr1
[ 4636.468129] iwlwifi 0000:00:14.3: 0x08F00002 | isr2
[ 4636.468131] iwlwifi 0000:00:14.3: 0x00C3380D | isr3
[ 4636.468132] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 4636.468134] iwlwifi 0000:00:14.3: 0x0050019C | last cmd Id
[ 4636.468136] iwlwifi 0000:00:14.3: 0x000079A0 | wait_event
[ 4636.468137] iwlwifi 0000:00:14.3: 0x000000D4 | l2p_control
[ 4636.468139] iwlwifi 0000:00:14.3: 0x00002020 | l2p_duration
[ 4636.468140] iwlwifi 0000:00:14.3: 0x00000007 | l2p_mhvalid
[ 4636.468142] iwlwifi 0000:00:14.3: 0x00000081 | l2p_addr_match
[ 4636.468144] iwlwifi 0000:00:14.3: 0x00000009 | lmpm_pmg_sel
[ 4636.468145] iwlwifi 0000:00:14.3: 0x00000000 | timestamp
[ 4636.468147] iwlwifi 0000:00:14.3: 0x000058B4 | flow_handler
[ 4636.468181] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 4636.468183] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 7
[ 4636.468185] iwlwifi 0000:00:14.3: 0x20000066 | NMI_INTERRUPT_HOST
[ 4636.468186] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 4636.468188] iwlwifi 0000:00:14.3: 0x80465D2E | umac branchlink2
[ 4636.468190] iwlwifi 0000:00:14.3: 0x80480EC8 | umac interruptlink1
[ 4636.468191] iwlwifi 0000:00:14.3: 0x80480EC8 | umac interruptlink2
[ 4636.468193] iwlwifi 0000:00:14.3: 0x01000000 | umac data1
[ 4636.468194] iwlwifi 0000:00:14.3: 0x80480EC8 | umac data2
[ 4636.468196] iwlwifi 0000:00:14.3: 0x00000000 | umac data3
[ 4636.468198] iwlwifi 0000:00:14.3: 0x00000037 | umac major
[ 4636.468199] iwlwifi 0000:00:14.3: 0xD9698065 | umac minor
[ 4636.468201] iwlwifi 0000:00:14.3: 0x00A57973 | frame pointer
[ 4636.468202] iwlwifi 0000:00:14.3: 0xC0886270 | stack pointer
[ 4636.468204] iwlwifi 0000:00:14.3: 0x0050019C | last host cmd
[ 4636.468206] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 4636.468223] iwlwifi 0000:00:14.3: Fseq Registers:
[ 4636.468226] iwlwifi 0000:00:14.3: 0x60000000 | FSEQ_ERROR_CODE
[ 4636.468246] iwlwifi 0000:00:14.3: 0x80290033 | FSEQ_TOP_INIT_VERSION
[ 4636.468249] iwlwifi 0000:00:14.3: 0x00090006 | FSEQ_CNVIO_INIT_VERSION
[ 4636.468269] iwlwifi 0000:00:14.3: 0x0000A482 | FSEQ_OTP_VERSION
[ 4636.468272] iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
[ 4636.468275] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 4636.468278] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
[ 4636.468282] iwlwifi 0000:00:14.3: 0x01300504 | FSEQ_CNVR_ID
[ 4636.468285] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[ 4636.468290] iwlwifi 0000:00:14.3: 0x01300504 | CNVR_AUX_MISC_CHIP
[ 4636.468296] iwlwifi 0000:00:14.3: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 4636.468318] iwlwifi 0000:00:14.3: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 4636.468422] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 4 fired.
[ 4636.849506] iwlwifi 0000:00:14.3: Failed to get the temperature (err=-5)
[ 4637.068407] iwlwifi 0000:00:14.3: Got NSS = 4 - trimming to 2
[ 4637.068649] iwlwifi 0000:00:14.3: Got NSS = 4 - trimming to 2
Tremain
ethtool -i wlp0s20f3
driver: iwlwifi
version: 5.8.0-41-generic
firmware-version: 55.d9698065.0 QuZ-a0-hr-b0-55.u
expansion-rom-version:
bus-info: 0000:00:14.3
supports-statistics: yes
supports-test: no
supports-eeprom-access: no
supports-register-dump: no
supports-priv-flags: no
Sebastian_M_Intel
Hello Tremain,
Thank you for your reply.
We will check this information internally, please kindly wait for a response.
Once we have an update we will post it on this thread.
Sebastian M
Sebastian_M_Intel
Hello Tremain,
Thank you for waiting.
Just so you know, you are reporting issues on AX201 and AX210. You provided logs of AX201 on Kernel 5.8. So we will focus on AX201 for now.
We will send you another e-mail to request some logs that may contain sensitive information, please reply to that e-mail with the requested reports.
Sebastian M
David_G_Intel
Hello Tremain
As a friendly reminder, there is some information that we need via email and we are waiting for your response. Please update provide the information when you have time.
David G
David_G_Intel
Hello Tremain
We have not heard back from you, so we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Best regards,
David G.
raknerak
Dear David;
You're requesting more logs from the end users everytime as an Intel support however, this issue is a standard case that every users have. I am also using ubuntu 22.04 w/ kernel 6.2.0-37 and my product is hp zbook which uses AX201 chipset and I have the same issue w/ . Actually, this should be very easy to reproduce your end and no need for any random product users.
lspci | grep "Network controller"
00:14.3 Network controller: Intel Corporation Wi-Fi 6 AX201 (rev 20)
