Wireless
8510 討論
AX201 - Openwrt - Failed to start RT ucode: -110
bruce1066
初學者
2,118 檢視
I've been struggling to get the embedded AX201 on my computer to become functional - after testing out many scenarios with different builds and different firmware the only time I have managed to get firmware to load is shown below.
The computer is running Openwrt, it's an i3-n305, 32Gb. I've tried to run from nvme, emmc, usb. I've tried disabling various bios switches such as bluetooth, trusted computing, etc. I've tried downloading latest drivers from github. I was previously getting the message about no suitable firmware found - error 2. I tried amny different firmware files until I found the one referenced below that seems to get 99% there.
This with the latest and prior stable releases of Openwrt. I have gone back 4 stable releases, same issue. I'm not trying to use the wifi in AP mode, just client mode. My logic says there is something going on in bios - since AX201 has had working code in Openwrt for several years or...... there is a fault with the device.
[ 8.057505] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <email removed>. All Rights Reserved.
[ 10.150725] iwlwifi 0000:00:11.2: WFPM_UMAC_PD_NOTIFICATION: 0x1f
[ 10.151525] iwlwifi 0000:00:11.2: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 10.152198] iwlwifi 0000:00:11.2: WFPM_AUTH_KEY_0: 0x90
[ 10.152790] iwlwifi 0000:00:11.2: CNVI_SCU_SEQ_DATA_DW9: 0x10
[ 10.153445] iwlwifi 0000:00:11.2: SecBoot CPU1 Status: 0x51af, CPU2 Status: 0xb03
[ 10.154177] iwlwifi 0000:00:11.2: WFPM_LMAC1_PD_NOTIFICATION: 0x0
[ 10.154806] iwlwifi 0000:00:11.2: HPM_SECONDARY_DEVICE_STATE: 0x42
[ 10.155455] iwlwifi 0000:00:11.2: WFPM_MAC_OTP_CFG7_ADDR: 0x0
[ 10.156068] iwlwifi 0000:00:11.2: WFPM_MAC_OTP_CFG7_DATA: 0x0
[ 10.156645] iwlwifi 0000:00:11.2: UMAC CURRENT PC: 0xd05c18
[ 10.157213] iwlwifi 0000:00:11.2: LMAC1 CURRENT PC: 0xd05c1c
[ 10.157791] iwlwifi 0000:00:11.2: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 10.158692] iwlwifi 0000:00:11.2: Start IWL Error Log Dump:
[ 10.159276] iwlwifi 0000:00:11.2: Transport status: 0x00000042, valid: 6
[ 10.159931] iwlwifi 0000:00:11.2: Loaded firmware version: 89.1a492d28.0 so-a0-hr-b0-89.ucode
[ 10.160726] iwlwifi 0000:00:11.2: 0x00000034 | NMI_INTERRUPT_WDG
[ 10.161403] iwlwifi 0000:00:11.2: 0x000002F0 | trm_hw_status0
[ 10.161991] iwlwifi 0000:00:11.2: 0x00000000 | trm_hw_status1
[ 10.162586] iwlwifi 0000:00:11.2: 0x004D7374 | branchlink2
[ 10.163155] iwlwifi 0000:00:11.2: 0x000154D0 | interruptlink1
[ 10.163751] iwlwifi 0000:00:11.2: 0x000154D0 | interruptlink2
[ 10.164334] iwlwifi 0000:00:11.2: 0x00015092 | data1
[ 10.164858] iwlwifi 0000:00:11.2: 0x00001005 | data2
[ 10.165375] iwlwifi 0000:00:11.2: 0x00000000 | data3
[ 10.165896] iwlwifi 0000:00:11.2: 0x00000000 | beacon time
[ 10.166446] iwlwifi 0000:00:11.2: 0x00000000 | tsf low
[ 10.166976] iwlwifi 0000:00:11.2: 0x00000000 | tsf hi
[ 10.167493] iwlwifi 0000:00:11.2: 0x00000000 | time gp1
[ 10.168022] iwlwifi 0000:00:11.2: 0x0003DCF5 | time gp2
[ 10.168546] iwlwifi 0000:00:11.2: 0x00000001 | uCode revision type
[ 10.169132] iwlwifi 0000:00:11.2: 0x00000059 | uCode version major
[ 10.169727] iwlwifi 0000:00:11.2: 0x1A492D28 | uCode version minor
[ 10.170311] iwlwifi 0000:00:11.2: 0x00000370 | hw version
[ 10.170848] iwlwifi 0000:00:11.2: 0x18C80002 | board version
[ 10.171356] iwlwifi 0000:00:11.2: 0x00000000 | hcmd
[ 10.171830] iwlwifi 0000:00:11.2: 0x00020000 | isr0
[ 10.172284] iwlwifi 0000:00:11.2: 0x00000000 | isr1
[ 10.172741] iwlwifi 0000:00:11.2: 0x48B00002 | isr2
[ 10.173193] iwlwifi 0000:00:11.2: 0x00C0001C | isr3
[ 10.173647] iwlwifi 0000:00:11.2: 0x00000000 | isr4
[ 10.174096] iwlwifi 0000:00:11.2: 0x00000000 | last cmd Id
[ 10.174568] iwlwifi 0000:00:11.2: 0x00015092 | wait_event
[ 10.175044] iwlwifi 0000:00:11.2: 0x00000000 | l2p_control
[ 10.175511] iwlwifi 0000:00:11.2: 0x00000000 | l2p_duration
[ 10.176000] iwlwifi 0000:00:11.2: 0x00000000 | l2p_mhvalid
[ 10.176487] iwlwifi 0000:00:11.2: 0x00000000 | l2p_addr_match
[ 10.176998] iwlwifi 0000:00:11.2: 0x0000001B | lmpm_pmg_sel
[ 10.177484] iwlwifi 0000:00:11.2: 0x00000000 | timestamp
[ 10.177965] iwlwifi 0000:00:11.2: 0x0000F81C | flow_handler
[ 10.178489] iwlwifi 0000:00:11.2: Start IWL Error Log Dump:
[ 10.178967] iwlwifi 0000:00:11.2: Transport status: 0x00000042, valid: 7
[ 10.179484] iwlwifi 0000:00:11.2: 0x20000070 | NMI_INTERRUPT_LMAC_FATAL
[ 10.180008] iwlwifi 0000:00:11.2: 0x00000000 | umac branchlink1
[ 10.180478] iwlwifi 0000:00:11.2: 0x804824F0 | umac branchlink2
[ 10.180986] iwlwifi 0000:00:11.2: 0x804A27F2 | umac interruptlink1
[ 10.181469] iwlwifi 0000:00:11.2: 0x80496FD0 | umac interruptlink2
[ 10.181962] iwlwifi 0000:00:11.2: 0x00000002 | umac data1
[ 10.182395] iwlwifi 0000:00:11.2: 0x80496FD0 | umac data2
[ 10.182852] iwlwifi 0000:00:11.2: 0x00000000 | umac data3
[ 10.183285] iwlwifi 0000:00:11.2: 0x00000059 | umac major
[ 10.183716] iwlwifi 0000:00:11.2: 0x1A492D28 | umac minor
[ 10.184147] iwlwifi 0000:00:11.2: 0x0003DD71 | frame pointer
[ 10.184590] iwlwifi 0000:00:11.2: 0xC0887EA4 | stack pointer
[ 10.185052] iwlwifi 0000:00:11.2: 0x00000000 | last host cmd
[ 10.185491] iwlwifi 0000:00:11.2: 0x00200040 | isr status reg
[ 10.185984] iwlwifi 0000:00:11.2: IML/ROM dump:
[ 10.186351] iwlwifi 0000:00:11.2: 0x00000B03 | IML/ROM error/state
[ 10.186870] iwlwifi 0000:00:11.2: 0x000051AF | IML/ROM data1
[ 10.187340] iwlwifi 0000:00:11.2: 0x00000090 | IML/ROM WFPM_AUTH_KEY_0
[ 10.187876] iwlwifi 0000:00:11.2: Fseq Registers:
[ 10.188286] iwlwifi 0000:00:11.2: 0x20000021 | FSEQ_ERROR_CODE
[ 10.188759] iwlwifi 0000:00:11.2: 0x80350002 | FSEQ_TOP_INIT_VERSION
[ 10.189275] iwlwifi 0000:00:11.2: 0x00150002 | FSEQ_CNVIO_INIT_VERSION
[ 10.189795] iwlwifi 0000:00:11.2: 0x0000A481 | FSEQ_OTP_VERSION
[ 10.190284] iwlwifi 0000:00:11.2: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
[ 10.190843] iwlwifi 0000:00:11.2: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 10.191357] iwlwifi 0000:00:11.2: 0x00080400 | FSEQ_CNVI_ID
[ 10.191862] iwlwifi 0000:00:11.2: 0x01300504 | FSEQ_CNVR_ID
[ 10.192354] iwlwifi 0000:00:11.2: 0x00080400 | CNVI_AUX_MISC_CHIP
[ 10.192896] iwlwifi 0000:00:11.2: 0x01300504 | CNVR_AUX_MISC_CHIP
[ 10.193422] iwlwifi 0000:00:11.2: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 10.194065] iwlwifi 0000:00:11.2: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 10.194692] iwlwifi 0000:00:11.2: 0x00000000 | FSEQ_PREV_CNVIO_INIT_VERSION
[ 10.195256] iwlwifi 0000:00:11.2: 0x00350002 | FSEQ_WIFI_FSEQ_VERSION
[ 10.195778] iwlwifi 0000:00:11.2: 0xE03C9221 | FSEQ_BT_FSEQ_VERSION
[ 10.196298] iwlwifi 0000:00:11.2: 0x00000082 | FSEQ_CLASS_TP_VERSION
[ 10.196826] iwlwifi 0000:00:11.2: UMAC CURRENT PC: 0x804a22b8
[ 10.197311] iwlwifi 0000:00:11.2: LMAC1 CURRENT PC: 0xd0
[ 10.197772] iwlwifi 0000:00:11.2: Failed to start RT ucode: -110
[ 10.198262] iwlwifi 0000:00:11.2: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 11.393361] iwlwifi 0000:00:11.2: Failed to run INIT ucode: -110
[ 11.407516] iwlwifi 0000:00:11.2: retry init count 0
...then repeats this loop for a couple more retries before the code gives up.
Any pointers?
0 積分
7 回應
JedG_Intel
主席
2,056 檢視
Hello bruce1066,
I understand that you' re having issues with your AX201. Rest assured that I will do my best to help you. Please share the information below to help with my investigation.
1. What is the Linux distribution are you using?
2. What is the kernel of your OS?
3. Are you having issues on WiFi or Bluetooth or both?
4. Do you remember if this issue happened after a new OS update or Wireless driver update?
5. Is this a laptop or desktop system?
6. Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
Jed G.
bruce1066
初學者
2,043 檢視
Hi Jed,
This is Openwrt. I believe the kernel version is 6.6.73
I also tried 3 other earlier versions - same problem
I'm only trying to use wifi - it's a network router. However, I did check to see if there were errors if I loaded Windows 11. I wanted to isolate if it was a hardware or bios or s/w issue. After downloading the latest Win11 drivers from the Intel website I was getting errors for both Wifi and bluetooth. Yellow triangle, and if I remember right the error messages were something about the device not turning on or powering up. So both Linux and windows with similar problems.
The hardware is a computer with the wifi embedded on the motherboard. It's a Gowin r86s - N305 processor.
Because of the Win11 fails, my logic says this is more likely to be a hardware or a bios issue, vs software/firmware. The hardware is being found, but something prevents it from initializing. I've tried various things like disabling fast boot, disabling secure boot. I'm trying to get an updated bios - if it exists, but want to avoid putting a new variable in the mix - maybe there is a combination of settings - the bios has a LOT of options available - I'm using defaults.
JedG_Intel
主席
2,010 檢視
Hello bruce1066,
Thank you for sharing all this information.
You mentioned that you also encountered errors for both Wi-Fi and Bluetooth when attempting this on Windows. Could you please share those error messages?
Jed G.
bruce1066
初學者
1,981 檢視
Hi Jed,
Sorry, I didn't keep a note of the error message, I only did a quick install to check if the device was being recognized in a different OS. Seems in both openwrt and windows the device is being identified as an ax201. But in both cases the device is failing to start which makes me think it's either a hardware issue or a bios problem. I have tried the latest and the previous release of openwrt. Same error message.
[ 14.629475] iwlwifi 0000:00:14.3: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE _VDIG_MIRROR
[ 14.632243] iwlwifi 0000:00:14.3: Failed to start RT ucode: -110
[ 14.634342] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 15.784754] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110
[ 15.799352] iwlwifi 0000:00:14.3: retry init count 1
[ 15.809988] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV =0x370
[ 15.812659] thermal thermal_zone2: failed to read out thermal zone (-61)
[ 16.866705] iwlwifi 0000:00:14.3: SecBoot CPU1 Status: 0x4fb1, CPU2 Status: 0 xb03
[ 16.870145] iwlwifi 0000:00:14.3: WFPM_LMAC1_PD_NOTIFICATION: 0x0
[ 16.872366] iwlwifi 0000:00:14.3: HPM_SECONDARY_DEVICE_STATE: 0x42
[ 16.874531] iwlwifi 0000:00:14.3: WFPM_MAC_OTP_CFG7_ADDR: 0x0
[ 16.876579] iwlwifi 0000:00:14.3: WFPM_MAC_OTP_CFG7_DATA: 0x0
[ 16.878664] iwlwifi 0000:00:14.3: UMAC PC: 0xc00818ee
[ 16.880512] iwlwifi 0000:00:14.3: LMAC PC: 0x153b0
[ 16.882250] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 16.886134] iwlwifi 0000:00:14.3: Loaded firmware version: 72.daa05125.0 so-a 0-hr-b0-72.ucode
[ 16.889024] iwlwifi 0000:00:14.3: 0x00000000 | ADVANCED_SYSASSERT
[ 16.891466] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status0
[ 16.893541] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 16.895618] iwlwifi 0000:00:14.3: 0x00000000 | branchlink2
[ 16.897580] iwlwifi 0000:00:14.3: 0x00000000 | interruptlink1
[ 16.899621] iwlwifi 0000:00:14.3: 0x00000000 | interruptlink2
[ 16.901661] iwlwifi 0000:00:14.3: 0x00000000 | data1
[ 16.903460] iwlwifi 0000:00:14.3: 0x00000000 | data2
[ 16.905260] iwlwifi 0000:00:14.3: 0x00000000 | data3
[ 16.907052] iwlwifi 0000:00:14.3: 0x00000000 | beacon time
[ 16.909002] iwlwifi 0000:00:14.3: 0x00000000 | tsf low
[ 16.910847] iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
[ 16.912659] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 16.914556] iwlwifi 0000:00:14.3: 0x00000000 | time gp2
[ 16.916447] iwlwifi 0000:00:14.3: 0x00000000 | uCode revision type
[ 16.918627] iwlwifi 0000:00:14.3: 0x00000000 | uCode version major
[ 16.920801] iwlwifi 0000:00:14.3: 0x00000000 | uCode version minor
[ 16.922946] iwlwifi 0000:00:14.3: 0x00000000 | hw version
[ 16.924855] iwlwifi 0000:00:14.3: 0x00000000 | board version
[ 16.926858] iwlwifi 0000:00:14.3: 0x00000000 | hcmd
[ 16.928604] iwlwifi 0000:00:14.3: 0x00000000 | isr0
[ 16.930348] iwlwifi 0000:00:14.3: 0x00000000 | isr1
[ 16.932088] iwlwifi 0000:00:14.3: 0x00000000 | isr2
[ 16.933821] iwlwifi 0000:00:14.3: 0x00000000 | isr3
[ 16.935547] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 16.937273] iwlwifi 0000:00:14.3: 0x00000000 | last cmd Id
[ 16.939173] iwlwifi 0000:00:14.3: 0x00000000 | wait_event
[ 16.941070] iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
[ 16.942982] iwlwifi 0000:00:14.3: 0x00000000 | l2p_duration
[ 16.944964] iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid
[ 16.946878] iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
[ 16.948857] iwlwifi 0000:00:14.3: 0x00000000 | lmpm_pmg_sel
[ 16.950790] iwlwifi 0000:00:14.3: 0x00000000 | timestamp
[ 16.952639] iwlwifi 0000:00:14.3: 0x00000000 | flow_handler
[ 16.954615] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 16.956538] iwlwifi 0000:00:14.3: Transport status: 0x00000042, valid: 7
[ 16.958773] iwlwifi 0000:00:14.3: 0x20000066 | NMI_INTERRUPT_HOST
[ 16.960810] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 16.962798] iwlwifi 0000:00:14.3: 0x8045E934 | umac branchlink2
[ 16.964785] iwlwifi 0000:00:14.3: 0x8047CC62 | umac interruptlink1
[ 16.966856] iwlwifi 0000:00:14.3: 0xC0082252 | umac interruptlink2
[ 16.968961] iwlwifi 0000:00:14.3: 0x01000000 | umac data1
[ 16.970830] iwlwifi 0000:00:14.3: 0xC0082252 | umac data2
[ 16.972698] iwlwifi 0000:00:14.3: 0x00000000 | umac data3
[ 16.974567] iwlwifi 0000:00:14.3: 0x00000048 | umac major
[ 16.976438] iwlwifi 0000:00:14.3: 0xDAA05125 | umac minor
[ 16.978359] iwlwifi 0000:00:14.3: 0x00103B30 | frame pointer
[ 16.980309] iwlwifi 0000:00:14.3: 0xC0887EF4 | stack pointer
[ 16.982261] iwlwifi 0000:00:14.3: 0x00000000 | last host cmd
[ 16.984217] iwlwifi 0000:00:14.3: 0x00000404 | isr status reg
[ 16.986231] iwlwifi 0000:00:14.3: IML/ROM dump:
[ 16.987816] iwlwifi 0000:00:14.3: 0x00000B03 | IML/ROM error/state
[ 16.989930] iwlwifi 0000:00:14.3: 0x00004FB1 | IML/ROM data1
[ 16.991887] iwlwifi 0000:00:14.3: 0x00000090 | IML/ROM WFPM_AUTH_KEY_0
[ 16.994103] iwlwifi 0000:00:14.3: Fseq Registers:
[ 16.995766] iwlwifi 0000:00:14.3: 0x60000000 | FSEQ_ERROR_CODE
[ 16.997781] iwlwifi 0000:00:14.3: 0x80350002 | FSEQ_TOP_INIT_VERSION
[ 16.999950] iwlwifi 0000:00:14.3: 0x00150000 | FSEQ_CNVIO_INIT_VERSION
[ 17.002174] iwlwifi 0000:00:14.3: 0x0000A481 | FSEQ_OTP_VERSION
[ 17.004216] iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
[ 17.006506] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 17.008592] iwlwifi 0000:00:14.3: 0x00080400 | FSEQ_CNVI_ID
[ 17.010572] iwlwifi 0000:00:14.3: 0x01300504 | FSEQ_CNVR_ID
[ 17.012545] iwlwifi 0000:00:14.3: 0x00080400 | CNVI_AUX_MISC_CHIP
[ 17.014686] iwlwifi 0000:00:14.3: 0x01300504 | CNVR_AUX_MISC_CHIP
[ 17.016838] iwlwifi 0000:00:14.3: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DC DC_VTRIM
[ 17.019506] iwlwifi 0000:00:14.3: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE _VDIG_MIRROR
[ 17.022241] iwlwifi 0000:00:14.3: Failed to start RT ucode: -110
[ 17.024309] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 18.174521] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110
[ 18.189158] iwlwifi 0000:00:14.3: retry init count 2
JedG_Intel
主席
1,978 檢視
Hi bruce1066,
I appreciate your insights. I'll be conducting an investigation with regards to this matter and I'll give you an update as soon as possible.
Jed G.
bruce1066
初學者
1,943 檢視
I just did  a clean Debian (bookworm) install. Almost identical error messages. Log attached with errors highlighted. So we have 3 different openwrt builds, 1 Debian build and 1 Windows11 build all failing to start the AX201. The drivers being loaded for Openwrt and Debian are different depending on the version of O/S being loaded. For the Openwrt builds I tried downloading and installing the drivers from github. They loaded, detected the hardware, but same problem. So by a process of elimination I think it's reasonable to assume it's not O/S dependant and it's highly unlikely to be a driver issue - for Windows I did download the Intel driver application and install the latest from Intel.
That brings me back to hardware or bios. Things I have tried so far in bios:
Turning off off fast boot
Disabled bluetooth
Disable sata
Reset to defaults
Set CPU to max non-turbo power
Happy to try other settings, there are many cpu and options open in my AMI bios version.
JedG_Intel
主席
1,897 檢視
Hello bruce1066,
Thank you so much for your efforts and for sharing as much information as you could. I sent you an email to continue the support. Please check your inbox at your earliest convenience.
Jed G.
回覆
