We have frequent wifi disconnections from our computer (with AX201) to our access point (AVM FritzBox 7490) in 5 GHz. Other wifi devices work well at this location.
It seems that other wifi devices nearby also disconnect, if the AX201 disconnects.
Any ideas about?
Hello ThiloLangbein
Thank you for posting on the Intel️® communities. Please share with us the following information:
- What wireless card do the other systems have?
- Does it also have Bluetooth problems?
- When did it start to happen?
- Do you remember if this issue happened after a new OS update or Wireless driver update?
- Is this a laptop or desktop system?
- Is this issue happening at home, office environment or both?
- Is this a new computer?
- What OS version are you using?
- Is this the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
- Did you check if this problem occurs on different networks?
- What steps do you take to reproduce your issue?
- Were you able to have you wireless connection in a normal/expected performance before?
- Have you installed any recent software or hardware in your system?
- Did you test different driver versions for testing?
- Did you reboot your access-point already?
David G
It has bluetooth as well, but it's currently not use.
It's a Lenovo ThinkCentre M70q with a fresh 20H2 installation. I have only one wifi network available for usage.
I updated intel wifi driver to the latest version.
If I restrict WIFI to version 5 only, connection is stable.
Please provide the Intel® System Support Utility (Intel® SSU) report
- Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
- Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
David G
David G.
Thank you for the information. The report doesn't include all the information needed, please run it again and make sure to check the "Everything" box on Step one.
David G
Thank you for the update. After checking the reports and the information provided, this seems to indicate an issue your router. The AVM FritzBox 7490 is an AC router, therefore users cannot expect to get the advantage of the Wifi-6 AX of the Wireless card AX201. Please check the recommended configurations, specs and capabilities with the manufacturer.
David G
AX201 device drops frequently the WIFI connection with the router. While other devices do not.
AX201 should use WiFI 5 while connecting my router. But this seems not to work flawlessly with intel AX201.
What are the options?
![](/skins/images/7B0AB6865064EAE32B30EC9A4E94B48A/responsive_peak/images/icon_anonymous_message.png)
