Wireless
8975 Discussions
AX201
JMSCommServ
My Asus laptop uses the Intel Wi-Fi 6 AX201 160MHz running Windows 11. Recently when I use Teams for conference calls the Wi-Fi driver stops working and cannot be reset. I have to uninstall and reinstall the driver (sometimes more than once) to get WiFi connectivity back. It is only the use of Teams that causes this problem. I now use an Ethernet cable when using Teams but this is sometimes not practical. Any suggestions?
Steven_Intel
Hello JMSCommServ,
In order to better assist you, please provide the following information:
  • When the issue happens, is there any error code in Device Manager under Network Adapters?
  • Did the error start to happen after any hardware upgrade or driver/OS update?
  • Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
  • Is there any issue with Bluetooth as well?
Steven G.
JMSCommServ
Hi, apologies for slow reply. Not been able to log in.
Device Manager shows a warning triangle and shows just device has a problem. I have to uninstall and reinstall the driver to fix. It's the original adapter that worked fine for 15 months with frequent use of Teams. I feel it must be something to do with software update.
Steven_Intel
Steven G.
JMSCommServ
DeividA_Intel
Hello JMSCommServ,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
JMSCommServ
JMSCommServ
Apologies, not been able to log in. The problem still exists.
