Wireless
8570 Discussions
[AX210] How to capture 11ax trigger-based packets with AID
SOLGIL
Hi
As of now, I am able to capture 11ax SU packets (including full data packets) with the AX210 on Ubuntu 20.04 (kernel 5.15).
Going one step further, I am checking how to capture 11ax MU Trigger-based packets for the target Association ID. Could you let me know how to set the target AID to iwlmvm ?
I have read some post that the target AID can be set with the command below:
  $ sudo echo <AID>  <AP/BSS MAC>   >    /sys/kernel/debug/iwlwifi/*/iwlmvm/he_sniffer_params
Unfortunately, when I try this command on my Ubuntu 20.04 machine,
it showed "Permission denied" error message even though the command was excuted by root.
Did I miss something or do we have another way to give target AID information to iwlmvm ?
Jose_Intel
Hello @SOLGIL
Thank you for posting on the Intel️® communities.
I understand you want to capture 11ax MU Trigger-based packets, and I’ll be more than happy to help you.
Let us check the issue internally, as soon as we have an update, we will post it here.
Jose B.
Jose_Intel
Hello SOLGIL
Thanks for patiently waiting for a response.
I will reach out to you privately with further details about your issue.
Jose B.
