Wireless
8622 Discussions
Windows 11 Intel WiFi AX411 issue
Rufat
When performing "cold boot" or enabling ERP mode for the Asus Rog Maximus Z790 Extreme (with factory preinstalled Intel Wi-Fi AX411) getting "code 10" from Windows device manager. The only solution which helps is to Disabling/Enabling Wireless/Bluetooth adapter from BIOS. Tried different versions of drivers from manufacture itself (including latest available 22.190.0.4) and from Intel (22.240.0).
Windows Event Manager reports the following errors:
1.
000008000100000000000000921300C00000000000000000000000000000000000000000000000005744525622420000 : The network adapter has returned an invalid value to the driver.
2.
00001C000100000000000000891300C0000000000000000000000000000000000000000000000000494E4954900300000400BE16E22B4F9A00000000B015D49E00000000 : Could not allocate the resources necessary for operation.
3.
0000240001000000000000008A1300C0000000000000000000000000000000000000000000000000100300000000000000000000000000000000000000000000000000000000000000000000 : Has determined that the network adapter is not functioning properly.
n_scott_pearson
I would suggest that the first thing you try is a clean install. That is, with Internet access disabled (unplug Ethernet cable if present),
  1. uninstall the current driver,
  2. Reboot, keeping Internet access disabled.
  3. Install the Manufacturer-supplied version of the driver
  4. Enable Internet access.
  5. Reboot.
  6. Test.
If this is successful, you could try installing a later, Intel-generic version of the driver; that's up to you...
Rufat
Hi Scott. Just tested the approach you provided. No results. Issue still persist.
Andres_Intel
Hello Rufat,
Thank you for posting on the Intel communities. I see that you are having error code issues with your Intel® Wi-Fi 6E AX411, I will be happy to help you.
To have a better understanding of the situation, please answer the following questions:
Andres P.
Rufat
Hi Andres. It's not working from first day. SSU results attached.
Andres_Intel
Hello Rufat,
Thank you for your response, all the information provided has been really helpful.
Please follow the steps below and let me know the results:
  • Reset BIOS to defaults. You can contact the motherboard manufacturer for guidance.
  • I see that you mentioned that you tested Asus drivers and Intel drivers and the issue persists. This time let's do it with a clean installation to version 22.190.0.4, to check if the behavior changes. For guidance, Clean Installation of Intel® Graphics Drivers in Windows. If the issue persists, repeat the steps but this time by downloading the driver version 22.240.0.2.
Andres P.
Rufat
Hi Andres,
BIOS reset and clean installation methods didn't helped.
Andres_Intel
Hello Rufat,
Thank you for your answer and for completing the steps.
I will start with an investigation to provide you with the next steps, as soon I have further information I will let you know.
Andres P.
Rufat
Thanks Andres.
Will wait for your response.
Andres_Intel
Hello Rufat,
Thank you for your time.
I have been working on the investigation, as per all the troubleshooting steps we have followed this could be related to hardware issues, so I recommend you contact the laptop manufacturer for further assistance.
For now, I will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
