Wireless
8781 Discussions
AX210 - Wi-Fi 6E and Wireshark
mistermultipath
Does anyone have a procedure for using Wireshark or a developmental version of Wireshark to capture packets on 6 GHz using an Intel AX210 radio?
DeividA_Intel
Hello mistermultipath,
I would like to let you know that we do not have documentation to confirm if you can use Wireshark to capture packets on the 6GHz band, however, the best action to take would be to check with Wireshark for further instructions and make sure if that is possible under your system configuration.
You may find information about this matter in the following links:
1. https://ask.wireshark.org/questions/21422/revisions/
2. https://ask.wireshark.org/question/21649/80211-w-airmon-ng-monitor-mode-channel-setting-for-6-ghz/
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
Vegan
Network monitoring tools will need to be updated to handle 6 GHz which should not take long
