Wireless
8700 Discussions
AX210 cannot connect WiFi sometimes (Jetson Orin, JP5.1.2, Ubuntu20.04)
Teddy_B
I am using AX210 in Jetson Orin Board.
My system is
CPU : Jetson Orin NX
OS : Jetpack 5.1.2 (Ubuntu 20.04)
At first, I cannot use AX210 but I found AX210 patch in this site.
After patch, I can connect WiFi with AX210 well.
But, I moved other place with My board.
I tried to connect WiFi but failed.
Look at attached iamge.
image 1 : wifi was detected well and signal is very good.
image 2 : I tried to connect wifi but failed with this log.
image 3 : After fail, wifi is not detected any more before restart Network Manager.
Could I get your advice for this?
Ernesto_C_Intel1
Hi Teddy_B,
I would like to further understand the issue you've encountered:
1. What is the kernel version installed with your operating system?
2. May I know the output of the following commands
  • # lspci​
  • # modinfo iwlwifi​
  • # lsmod | grep iwlwifi​
  • # dmesg | grep “no suitable firmware found!”​
Ernesto C.
RandyT_Intel
Hi Teddy_B,
I wanted to follow up regarding the questions and information we shared with you recently. Have you had a chance to review them? Your feedback is invaluable in helping us determine the next best course of action.
Please let me know if you have any thoughts or if there's anything else you need from us.
Looking forward to your response!
Randy T.
RandyT_Intel
Hi Teddy_B
Since I have not received any response from you, I will proceed with closing this ticket. Please note that this case will no longer be monitored.
If you have any new questions or inquiries, kindly submit another ticket, and we will be happy to assist you.
Randy T.
