We purchased AX210 to used in out robots(Ubuntu 20.04 ARM64). They works fine in China. See picture in attachment.
But when the exported to Taiwan. AX210 sets itself to US and stops working(can't scan or connect).
Region Info shows itself in US
$ iw reg get
global
country 00: DFS-UNSET
phy#0 (self-managed)
country US: DFS-UNSET
After googling, I found it uses WIFI beacon packages to determine its region and limits its signal power and prohibit certain bands.
But why it stop working completely when in US?
$ wpa_cli
wpa_cli v2.9
Copyright (c) 2004-2019, Jouni Malinen <j@w1.fi> and contributors
This software may be distributed under the terms of the BSD license.
See README for more details.
Selected interface 'wlP2p33s0'
Interactive mode
> scan
<3>CTRL-EVENT-SCAN-FAILED ret=-2
Can't scan:
$ sudo iw dev wlP2p33s0 scan
command failed: Invalid argument (-22)
Firmware and Platform
$ ls /lib/firmware/*.ucode -lha
-rw-rw-r-- 1 root root 1.3M Jul 17 2023 iwlwifi-cc-a0-59.ucode
-rw-rw-r-- 1 root root 1.4M Jul 17 2023 iwlwifi-ty-a0-gf-a0-59.ucode
$ uname -a
Linux B755408903728Y8 5.10.160-rockchip-rk3588 #1.0.8 SMP Fri Nov 10 17:58:32 CST 2023 aarch64 aarch64 aarch64 GNU/Linux
Hi FengZhaolin,
I will further investigate on this internally and provide an update on this thread as soon as possible.
Hi FengZhaolin,
Thank you for patiently waiting.
Upon checking, It's crucial to remember that different areas have varied wireless device laws, and using a device that isn't compatible can cause issues. Usually, you may check the product specs or get in touch with the computer maker to confirm this.
To further check into this, may I know the details to the following:
- My I know the make and model of your system?
- What current wireless driver version do you have?
You can also check these links for further information:
- How to Enable 6 GHz Band Using Intel® Wi-Fi 6E or Wi-Fi 7 Products
- Intel® Wi-Fi 6E AX210 Adapter Cannot Connect to a 6 GHz Band
Earl E.
Hi FengZhaolin,
Earl E.
Hi FengZhaolin,
Earl E.
