- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
Hi Team,
We are using kernel's 6.1.36 Intel Ax210 wifi driver, we configured the device in Access point (hostapd-2g attached) mode with 2.4 GHz band and WIFI 6 protocol and when we tried to connect this AP device to STA, we observed the crash in iwlwifi /iwlmvm (driver crashlog attached).
[ 5451.469516] Workqueue: events iwl_mvm_tcm_work [iwlmvm]
[ 5451.474821] Call trace:
[ 5451.477268] dump_backtrace.part.0+0xe0/0xf0
[ 5451.481551] show_stack+0x18/0x30
[ 5451.484872] dump_stack_lvl+0x64/0x80
[ 5451.488541] dump_stack+0x18/0x34
[ 5451.491863] iwl_trans_txq_send_hcmd+0x444/0x450 [iwlwifi]
[ 5451.497440] iwl_trans_send_cmd+0x64/0x120 [iwlwifi]
[ 5451.502477] iwl_mvm_send_cmd+0x1c/0x50 [iwlmvm]
[ 5451.507153] iwl_mvm_config_scan+0xcc/0x170 [iwlmvm]
[ 5451.512175] iwl_mvm_recalc_tcm+0x3a0/0x5b0 [iwlmvm]
[ 5451.517196] iwl_mvm_tcm_work+0x18/0x24 [iwlmvm]
[ 5451.521871] process_one_work+0x1d4/0x330
[ 5451.525887] worker_thread+0x6c/0x430
[ 5451.529553] kthread+0x108/0x10c
[ 5451.532787] ret_from_fork+0x10/0x20
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hello @Avinash1992
We sincerely regret you are experiencing issues with your Intel® Wi-Fi 6E AX210 (Gig+), we will be more than happy to assist you.
Please keep in mind that Linux drivers are part of the upstream Linux* kernel. They're available through the regular channels, distributions, or the Linux* kernel archives. We highly recommend updating it, please let us know.
Jose B.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Jose,
Can we use 6.6.8 kernel version driver for AX210, version is stable. also, do we also need cfg80211 module, in order to enable wifi 6 capabilities?
Avi
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hello Avinash1992
Thank you for your reply.
That is ok, you can use the version 6.6.8, since that is a stable version.
Regarding cfg80211, yes, you will need it.
Jose B.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hello Avinash1992,
I am getting back to you because I would like to know if you were able to update your Linux firmware/kernel to version 6.6.8. I will wait for an update on this matter.
Deivid A.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hello Avinash1992
We hope you are having a nice day.
We have not heard back from you. So, we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jose B.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Jose,
Does Intel AX210 radio support access point mode configuration ?
Avinash
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
