- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
Hello.
I have debian 12 with proxmox on my homelab server with asrock b450m pro4 and PCI AX210.
I have good speed link:
iw dev wlp1s0 link
Connected to 78:c5:f8:1e:01:40 (on wlp1s0)
SSID: DevOpsNet
freq: 5220
RX: 1149566028 bytes (31544013 packets)
TX: 2361509534 bytes (31544839 packets)
signal: -49 dBm
rx bitrate: 2161.3 MBit/s 160MHz HE-MCS 10 HE-NSS 2 HE-GI 0 HE-DCM 0
tx bitrate: 1814.8 MBit/s 160MHz HE-MCS 9 HE-NSS 2 HE-GI 1 HE-DCM 0
bss flags: short-preamble short-slot-time
dtim period: 1
beacon int: 100
01:00.0 Network controller [0280]: Intel Corporation Wi-Fi 6 AX210/AX211/AX411 160MHz [8086:2725] (rev 1a)
Subsystem: Intel Corporation Wi-Fi 6 AX210 160MHz [8086:0024]
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
But upload speed to low, see iperf from my PC with cable Eth connection to router and my homelab server with AX210:
But download result is good:
I don't understand what the problem is, since the problem doesn't occur constantly. While I was writing this message, the upload speed was restored:
dmesg | grep 'iwlwifi'
[734332.726351] iwlwifi 0000:01:00.0: Start IWL Error Log Dump:
[734332.726352] iwlwifi 0000:01:00.0: Transport status: 0x0000004A, valid: 7
[734332.726354] iwlwifi 0000:01:00.0: 0x20000070 | NMI_INTERRUPT_LMAC_FATAL
[734332.726356] iwlwifi 0000:01:00.0: 0x00000000 | umac branchlink1
[734332.726358] iwlwifi 0000:01:00.0: 0x8046DE86 | umac branchlink2
[734332.726360] iwlwifi 0000:01:00.0: 0x8048F8A6 | umac interruptlink1
[734332.726361] iwlwifi 0000:01:00.0: 0x8048F8A6 | umac interruptlink2
[734332.726363] iwlwifi 0000:01:00.0: 0x00000002 | umac data1
[734332.726365] iwlwifi 0000:01:00.0: 0x8048F8A6 | umac data2
[734332.726366] iwlwifi 0000:01:00.0: 0x00000000 | umac data3
[734332.726368] iwlwifi 0000:01:00.0: 0x00000056 | umac major
[734332.726370] iwlwifi 0000:01:00.0: 0xFB5C9AEB | umac minor
[734332.726371] iwlwifi 0000:01:00.0: 0x02985078 | frame pointer
[734332.726373] iwlwifi 0000:01:00.0: 0xC0886258 | stack pointer
[734332.726375] iwlwifi 0000:01:00.0: 0x00A5010C | last host cmd
[734332.726376] iwlwifi 0000:01:00.0: 0x00000000 | isr status reg
[734332.726422] iwlwifi 0000:01:00.0: IML/ROM dump:
[734332.726423] iwlwifi 0000:01:00.0: 0x00000B03 | IML/ROM error/state
[734332.726467] iwlwifi 0000:01:00.0: 0x00008020 | IML/ROM data1
[734332.726507] iwlwifi 0000:01:00.0: 0x00000090 | IML/ROM WFPM_AUTH_KEY_0
[734332.726548] iwlwifi 0000:01:00.0: Fseq Registers:
[734332.726569] iwlwifi 0000:01:00.0: 0x60000000 | FSEQ_ERROR_CODE
[734332.726590] iwlwifi 0000:01:00.0: 0x80440007 | FSEQ_TOP_INIT_VERSION
[734332.726611] iwlwifi 0000:01:00.0: 0x00080009 | FSEQ_CNVIO_INIT_VERSION
[734332.726632] iwlwifi 0000:01:00.0: 0x0000A652 | FSEQ_OTP_VERSION
[734332.726653] iwlwifi 0000:01:00.0: 0x00000002 | FSEQ_TOP_CONTENT_VERSION
[734332.726674] iwlwifi 0000:01:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[734332.726695] iwlwifi 0000:01:00.0: 0x00400410 | FSEQ_CNVI_ID
[734332.726715] iwlwifi 0000:01:00.0: 0x00400410 | FSEQ_CNVR_ID
[734332.726736] iwlwifi 0000:01:00.0: 0x00400410 | CNVI_AUX_MISC_CHIP
[734332.726759] iwlwifi 0000:01:00.0: 0x00400410 | CNVR_AUX_MISC_CHIP
[734332.726782] iwlwifi 0000:01:00.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[734332.726805] iwlwifi 0000:01:00.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[734332.726831] iwlwifi 0000:01:00.0: 0x00080009 | FSEQ_PREV_CNVIO_INIT_VERSION
[734332.726856] iwlwifi 0000:01:00.0: 0x00440007 | FSEQ_WIFI_FSEQ_VERSION
[734332.726877] iwlwifi 0000:01:00.0: 0x00440007 | FSEQ_BT_FSEQ_VERSION
[734332.726898] iwlwifi 0000:01:00.0: 0x000000DC | FSEQ_CLASS_TP_VERSION
[734332.726962] iwlwifi 0000:01:00.0: UMAC CURRENT PC: 0x8048f36c
[734332.726983] iwlwifi 0000:01:00.0: LMAC1 CURRENT PC: 0xd0
[734332.727121] iwlwifi 0000:01:00.0: WRT: Collecting data: ini trigger 4 fired (delay=0ms).
[734333.227775] iwlwifi 0000:01:00.0: WRT: Invalid buffer destination
[734333.380293] iwlwifi 0000:01:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x20
[734333.380331] iwlwifi 0000:01:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[734333.380364] iwlwifi 0000:01:00.0: WFPM_AUTH_KEY_0: 0x90
[734333.380393] iwlwifi 0000:01:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x0
This is my simple map.
My config /etc/network/interface:
auto wlp1s0
iface wlp1s0 inet static
wpa-ssid DevOpsNet
wpa-psk <MY PASSWORD>
auto vmbr0
iface vmbr0 inet static
pre-up iw dev wlp1s0 set 4addr on
address 192.168.3.44/24
gateway 192.168.3.1
bridge-ports wlp1s0
bridge-stp off
bridge-fd 0
I see errors in log, see in file journalctl-wifi.log
Ссылка скопирована
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
My router use:
1) 2.4G channel 6
2) 5G channel 44
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Now i see drop TX bitrate
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello AntonP8O,
Upon reading this information, it is best to coordinate this with our team for further investigation. I will post an update once it's available.
JeanetteC.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello AntonP8O,
Greetings from Intel® Customer Support.
After reviewing the specifications, I have a few clarifications:
1. Could you please provide the make and model of the PCIe card to which the wireless card is connected?
2. Is the wireless connection functioning properly with Windows? According to the motherboard manual, it appears to support only the Windows operating system.
3. When did it start to happen?
4. Do you remember if this issue happened after a new OS update or Wireless driver update?
5. Were you able to have a wireless connection in a normal/expected performance before?
6. Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
I will wait for your reply.
JeanetteC.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
1. My Wi-Fi card AX210 is installed in my Proxmox server and is connected via Wi-Fi to the Huawei XD20 router. In this configuration, I have WDS (4addr) running, and I am experiencing an issue with low outgoing speed from the server. I replaced the Huawei XD20 router with a Xiaomi AX3000T (with OpenWrt firmware). My WDS (4addr) stopped working and the problem with low outgoing speed from the server persisted.
2. I have not tested it on Windows.
3. The problem appeared after installing this Wi-Fi card.
4. No.
5. No.
6. There are no built-in Wi-Fi adapters on the motherboard. I purchased it and installed it in a PCI x16 slot. For testing, I disabled WDS on the Proxmox server and the problem remained.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
PCIe Wireless card carrier designs, regardless of the actual Wireless card used, are notorious for not working properly when plugged into anything other than a PCIe x1 connector. I suggest that you try moving it to your board's x1 connector and see if this alleviates the problem.
Hope this helps,
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello AntonP8O,
I apologize for the delay in response.
Have you tried the troubleshooting suggested by n_scott_pearson? If yes and if the issue persists, please share the logs of the following command output for analysis:
- $ hostnamectl > hostname.txt
- # lspci > lspci.txt
- # modinfo iwlwifi > iwlwifi.txt
- # lsmod | grep iwlwifi > lsmod.txt
JeanetteC.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Ok i test this on 09.22.2024 and reply.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello AntonP8O,
Currently, my colleague is away as such I will be as handling the thread for now. There are just some following questions that I would like to ask. Can you tell me if you have installed the wireless driver when you install the wifi card on the server? If you haven't installed the wireless driver please try to install the drive by following this link: Linux* Support for Intel® Wireless Adapters and Intel® Wireless Wi-Fi Drivers for Linux* Also, can you share to me what kernel version you are currently using?
Dhanniel M.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello AntonP8O,
We're still waiting for an update regarding the recommendations we shared to fix this issue. We will wait for your reply to know if you need more further assistance.
JeanetteC.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello AntonP8O,
I was waiting for your feedback about the recommendations shared by my colleague and I have not received any response in the past few days.
In case the issue persists, I highly recommend contacting your motherboard manufacturer support for a possible OS compatibility issue.
I will now proceed to close this thread.
Sincerely,
JeanetteC.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
If you're experiencing intermittent low upload speeds with your Intel AX210, here are some quick troubleshooting steps:
Check for Interference: Switch to the 5 GHz band if you're using 2.4 GHz, or reduce network congestion by disconnecting unnecessary devices.
Update Drivers: Ensure you're using the latest drivers for your AX210 from Intel or your device manufacturer.
Router Settings: Make sure your router supports Wi-Fi 6, use auto channel selection, and check if QoS settings are limiting your upload speed.
Test Wired Connection: Try a wired Ethernet connection to see if the issue is specific to Wi-Fi.
Adjust Power Settings: Set your PC to "High performance" power mode and disable power-saving options on the AX210.
Close Background Apps: Ensure no apps are using up bandwidth in the background.
Advanced Wi-Fi Settings: Adjust settings like "Roaming Aggressiveness" or "Transmit Power" for better performance.
Test Different Upload Services: Check if the issue persists across various upload platforms.
Firmware & Software: Update your router firmware and temporarily disable security software or VPNs that might interfere. These steps should help identify and resolve the issue
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
@miketrever Chatgpt answer are very lame.
[Fear and the desire for control are primary motivators for shadow dwellers. ]
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
If you're experiencing inconsistent upload speeds with your Intel AX210, try these troubleshooting steps:
Check for Interference: If you're using the 2.4 GHz band, switch to 5 GHz for less congestion, or reduce network load by disconnecting unneeded devices.
Update Drivers: Ensure your AX210 drivers are up to date from Intel's website or your device manufacturer.
Router Settings: Confirm that your router supports Wi-Fi 6, enable auto channel selection, and check if QoS settings are limiting upload speeds.
Test Wired Connection: Try connecting via Ethernet to see if the issue is related to Wi-Fi.
Adjust Power Settings: Set your PC to "High performance" and disable any power-saving options on the AX210.
Close Background Apps: Ensure no apps are consuming bandwidth in the background.
Advanced Wi-Fi Settings: Tweak settings like "Roaming Aggressiveness" or "Transmit Power" to improve performance.
Test Different Upload Services: See if the issue occurs across various upload platforms.
Firmware & Software: Update your router firmware and temporarily disable security software or VPNs that may be interfering.
These steps should help you pinpoint and fix the problem.
- Теги:
- AX210
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
