Wireless
8718 Discussions
About 9260ac compatibility with TI wl1271
jianhuilu
Hello, guys
I have some problems and ask for help.
When wl1271 is used as SoftAP, there is a problem when using Intel 9260ac / ax200 in Windows 10. The specific performance is that after the connection is successful, as long as the data is sent and received, the connection will be disconnected. But it works well under Linux system.
Esteban_D_Intel
Hello jianhuilu,
Thank you for your response and the information provided.
Were you able to try upgrading your operating system to version 1909?
If so, please let me know if you noticed any improvement.
Esteban D.
Intel Technical Support Technician
Esteban_D_Intel
Hello jianhuilu,
To better assist you, I would appreciate if you could provide the following information:
  • Please provide the steps to replicate this behavior.
  • Are you a developer? Are you working in a customer design?
  • Please provide the build of your operating system?
  • Did you manually integrated these wireless adapters?
  • Please provide the drivers version that you have tried.
Additionally, I would appreciate if you could provide more information about the part: wl1271 how it works, the purpose of the device in your configuration.
Esteban D.
jianhuilu
Thank you for your reply
    I'm an employee of an equipment developer.
  • Are you working in a customer design?
    We design for our customers.
    CPU: i3-2120
    RAM: 16GB
    Version: Windows 10 professional
    Version number: 1903
    OS version: 18362.836
    I bought 9260AC separately and installed it on my computer.
    The current driver version of 9260ac is 21.120.2.1. I also try older then it, but I didn't notice what version it was.
Here is the working environment of the wl1271 module:
CPU: TI AM335x
Memory: 512MB
OS: Linux version 4.19.131
wl1271 driver: integrated into the system
Linux shell:
root@NSC200:/# cat /proc/version
Linux version 4.19.131 (root@Debian-lu) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 r2
852-075090c4d)) #0 SMP Tue Aug 11 15:37:22 2020
root@NSC200:~# ps |grep hostapd
2234 root 1788 S /usr/sbin/hostapd -s -g /var/run/hostapd/global
root@NSC200:~# cat /var/run/hostapd-phy0.conf
driver=nl80211
logger_syslog=127
logger_syslog_level=2
logger_stdout=127
logger_stdout_level=2
country_code=CN
ieee80211d=1
hw_mode=g
beacon_int=100
dtim_period=2
channel=6
chanlist=6
ieee80211n=1
ht_coex=0
ht_capab=[SHORT-GI-20][RX-STBC1]
radio_config_id=ef46fcc8428e59197308fd9ea001d56f
interface=wlan0
ctrl_interface=/var/run/hostapd
ap_isolate=1
bss_load_update_period=60
chan_util_avg_period=600
disassoc_low_ack=1
preamble=1
wmm_enabled=1
ignore_broadcast_ssid=0
uapsd_advertisement_enabled=1
utf8_ssid=1
multi_ap=0
auth_algs=1
wpa=0
ssid=OP_NSC200
bridge=br-lan
config_id=195090fecc4c77a46b6b65e75162a8c6
bssid=f0:b5:d1:79:af:a2
root@NSC200:/# iwinfo
wlan0 ESSID: "OP_NSC200"
Access Point: F0:B5:D1:79:AF:A2
Mode: Master Channel: 6 (2.437 GHz)
Tx-Power: 20 dBm Link Quality: unknown/70
Signal: unknown Noise: unknown
Bit Rate: unknown
Encryption: none
Type: nl80211 HW Mode(s): 802.11abgn
Hardware: unknown [Generic MAC80211]
TX power offset: unknown
Frequency offset: unknown
Supports VAPs: no PHY name: phy0
root@NSC200:/# iw list
Wiphy phy0
max # scan SSIDs: 1
max scan IEs length: 441 bytes
max # sched scan SSIDs: 16
max # match sets: 16
max # scan plans: 1
max scan plan interval: -1
max scan plan iterations: 0
Retry short limit: 7
Retry long limit: 4
Coverage class: 0 (up to 0m)
Device supports AP-side u-APSD.
Available Antennas: TX 0 RX 0
Supported interface modes:
* managed
* AP
* AP/VLAN
* monitor
* mesh point
* P2P-client
* P2P-GO
* P2P-device
Band 1:
Capabilities: 0x13c
HT20
SM Power Save disabled
RX Greenfield
RX HT20 SGI
RX STBC 1-stream
Max AMSDU length: 3839 bytes
No DSSS/CCK HT40
Maximum RX AMPDU length 8191 bytes (exponent: 0x000)
Minimum RX AMPDU time spacing: 8 usec (0x06)
HT Max RX data rate: 72 Mbps
HT TX/RX MCS rate indexes supported: 0-7
Frequencies:
* 2412 MHz [1] (25.0 dBm)
* 2417 MHz [2] (25.0 dBm)
* 2422 MHz [3] (25.0 dBm)
* 2427 MHz [4] (25.0 dBm)
* 2432 MHz [5] (25.0 dBm)
* 2437 MHz [6] (25.0 dBm)
* 2442 MHz [7] (25.0 dBm)
* 2447 MHz [8] (25.0 dBm)
* 2452 MHz [9] (25.0 dBm)
* 2457 MHz [10] (25.0 dBm)
* 2462 MHz [11] (25.0 dBm)
* 2467 MHz [12] (25.0 dBm)
* 2472 MHz [13] (25.0 dBm)
* 2484 MHz [14] (disabled)
Band 2:
Capabilities: 0x13c
HT20
RX Greenfield
RX HT20 SGI
RX STBC 1-stream
No DSSS/CCK HT40
Frequencies:
* 5040 MHz [8] (disabled)
* 5060 MHz [12] (disabled)
* 5080 MHz [16] (disabled)
* 5170 MHz [34] (disabled)
* 5180 MHz [36] (25.0 dBm)
* 5190 MHz [38] (25.0 dBm)
* 5200 MHz [40] (25.0 dBm)
* 5210 MHz [42] (25.0 dBm)
* 5220 MHz [44] (25.0 dBm)
* 5230 MHz [46] (25.0 dBm)
* 5240 MHz [48] (25.0 dBm)
* 5260 MHz [52] (25.0 dBm)
* 5280 MHz [56] (25.0 dBm)
* 5300 MHz [60] (25.0 dBm)
* 5320 MHz [64] (25.0 dBm)
* 5500 MHz [100] (disabled)
* 5520 MHz [104] (disabled)
* 5540 MHz [108] (disabled)
* 5560 MHz [112] (disabled)
* 5580 MHz [116] (disabled)
* 5600 MHz [120] (disabled)
* 5620 MHz [124] (disabled)
* 5640 MHz [128] (disabled)
* 5660 MHz [132] (disabled)
* 5680 MHz [136] (disabled)
* 5700 MHz [140] (disabled)
* 5745 MHz [149] (25.0 dBm)
* 5765 MHz [153] (25.0 dBm)
* 5785 MHz [157] (25.0 dBm)
* 5805 MHz [161] (25.0 dBm)
* 5825 MHz [165] (25.0 dBm)
valid interface combinations:
* #{ managed } <= 3, #{ AP, P2P-client, P2P-GO } <= 1,
total <= 3, #channels <= 1
HT Capability overrides:
* MCS: ff ff ff ff ff ff ff ff ff ff
* maximum A-MSDU length
* supported channel width
* short GI for 40 MHz
* max A-MPDU length exponent
* min MPDU start spacing
Supported extended features:
* [ RRM ]: RRM
* [ CONTROL_PORT_OVER_NL80211 ]: control port over nl80211
Esteban_D_Intel
Hello jianhuilu,
I would like to thank you for all the information provided.
Based on the design that you are doing and as this is an integration I would like to share with you the following:
As you may know performing wireless integrations is subject to country-specific legal regulations. Before installing or changing the Intel® Wireless Adapter, Intel recommends that you contact the system manufacturer to obtain approval, step-by-step instructions,support or compatibility information for both devices.
 It is worth mentioning that the integration may or may not work due to the following reasons:
1. Hardware/software compatibility issues or dependencies.
2. Manufacturer limitations.
3. Driver limitations.
In case you would like to confirm that information please check the support article: Regulatory Information Regarding Wireless Hardware Installation or Upgrade
Additionally, you can try upgrading your operating system to version 1909 and test the latest drivers for the wireless adapters that you can find here:
Intel® Wireless-AC 9260
Intel® Wi-Fi 6 AX200
I would appreciate if you could provide the following report, along with screenshots or any error message related with the wireless adapter in Windows*:
Please run the following tool and attach the reports generated.
Intel® System Support Utility (Intel® SSU) Download link
1.       Open the application and click on "Scan" to see the system and device information.
2.      By default, Intel® SSU will take you to the "Summary View".
3.       Click on the menu where it says "Summary" to change to "Detailed View".
4.       To save your scan, click on "Next", then "Save".
Esteban D.
jianhuilu
Sorry to reply so late,here is the SSU.EXE log file.
Esteban_D_Intel
Hello jianhuilu,
Esteban D.
Esteban_D_Intel
Hello jianhuilu,
Were you able to follow the recommendations provided?
Please let me know if you noticed an improvement after the upgrade of the operating system.
Esteban D.
Esteban_D_Intel
Hello jianhuilu,
We have not heard back from you.
If you need any additional information, please submit a new question as this thread will no longer being monitored
Esteban D.
