Wireless
8650 Discussions
After updating drivers, Intel DSA opens my web browser on every boot?
MacrossMike
There doesn't seem to be a community section for problems with the Intel Driver & Support Assistant, so I'm posting this in the section relating to the drivers that the DSA installed before it started behaving madly.
Earlier today, the Intel DSA v.19.4.18.9 ran an automatic check to see if my laptop had any drivers that needed updating, detected updates needed to my Wireless-AC 9260 and Bluetooth, and prompted me to download them both and install them. I did so and encountered no errors with the updates to the 21.10.1.2 wireless driver and 21.10.1.1 Bluetooth driver. It then prompted me to reboot my computer, which I dutifully did.
After the reboot, the Intel DSA client has started forcing my browser to open and run a check for updates every time my laptop boots up. The setting was set to check weekly (in the background as it usually did up until today), but now it comes up first thing on every boot cycle and if the wireless doesn't come up fast enough it'll open another tab in an effort to run the check after the first one fails. I've tried uninstalling the DSA tool using the Intel-provided removal tool and reinstalling it from the latest installer package, but the problem never goes away.
The DSA application is a useful tool but having it force my web browser to open and run multiple check sessions every time my laptop starts up is driving me a bit crazy. Any guidance anyone can offer on how to get the DSA tool to stop trying to run a check on boot would be great.
APols1
actually I'm too scared. Not having any more issues right now except that I know the app is not working right.
Hopefully someone else will 1st. maybe over weekend I MIGHT try it on one machine.
BTW do I do an uninstall 1st>>>
APols1
I see FPlaz says NO issues. OK then over weekend I will try too.
Wanner_G_Intel
Hello APols1,
You might follow these steps:
  1. Run the Intel® Driver & Support Assistant Uninstaller
  2. Restart your computer and run the Intel® Driver & Support Assistant.
Wanner G.
Under Contract to Intel Corporation
APols1
OK thxs. Will try over weekend. Pray to the heavens Andy🤞🤞 apppro[Sunglasses]
AlHill
"Pray to the heavens".
A bit melodramatic, isn't it? It is only a "driver update" update. It is not like the world is going to end, or your device is going to disintegrate, or anything like that.
Doc
APols1
Have 2 almost identical hp laptops. as I explained before I was having the exact same issues on both machines.
this morning I tried the new app. followed all uninstall - restart - etc directions posted here.
after installation and running the app on "launch" I restarted again. no issues so I shut it down and then rebooted. The app did NOT pop up. great - you would think. so I checked the icons on task bar and the icon was NOT there just like before. Uh Oh! So I checked the System Config and well it was exactly like before - NOT checked but marked running. Funny it still said 5/24/2019 Disabled. Weird. (See above for examples I posted earlier).
OK so I clicked "ENABLE ALL" and did a restart. App did not run (note never did on restart). I checked System Config and it was all checked. Icon was in Icon tray on Task Bar.
OK so I shut the machine down again. on restart the APP did not run but the Icon is not in task bar menu. We'll see.
waiting to here back before I try the other machine.
FPlaz
And as i said, i can confirm the update is working with no issues. Problem fixed, at least for me. Go ahead and try it.
APols1
Thxs – I noted that to you earlier. Thxs for letting us know. Will do so on weekend. apppro
FPlaz
Both services checked and running. No issues.
APols1
Wanner_G_Intel
Hello APols1,
Are you still experiencing the issue reported?
Wanner G.
APols1
No, I got the programmed installed - though I did have the unchecked issue in System Config as I documented. Now everything seems OK andy apppro😎
