- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
I have purchased a modern laptop, MSI Stealth GS66 12UGS, with which I am having trouble setting up wireless connection. Please consider the following setup information and dmesg log attached.
- Arch linux
- Linux hardware probe: link
$ uname -a
Linux 5.16.14-arch1-1 #1 SMP PREEMPT Fri, 11 Mar 2022 17:40:36 +0000 x86_64 GNU/Linux
$ dmesg
[ 5.623679] Intel(R) Wireless WiFi driver for Linux
[ 5.623759] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 5.625500] iwlwifi: No config found for PCI dev 51f0/1672, rev=0x370, rfid=0x2010d000
[ 5.625509] iwlwifi: probe of 0000:00:14.3 failed with error -22
$ lsmod | grep iwlwifi
iwlwifi 462848 0
cfg80211 1064960 1 iwlwifi
$ lspci -k
00:14.3 Network controller: Intel Corporation Alder Lake-P PCH CNVi WiFi (rev 01)
DeviceName: Onboard - Ethernet
Subsystem: Rivet Networks Device 1672
Kernel modules: iwlwifi
$ ifconfig -a
enp46s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.8.106 netmask 255.255.255.0 broadcast 192.168.8.255
inet6 fdef:e909:52c5:0:624f:f2dd:b734:8001 prefixlen 64 scopeid 0x0<global>
inet6 fdef:e909:52c5::e71 prefixlen 128 scopeid 0x0<global>
inet6 fe80::da42:5fd3:8ee5:31d prefixlen 64 scopeid 0x20<link>
ether d8:bb:c1:b2:50:26 txqueuelen 1000 (Ethernet)
RX packets 50761 bytes 55814926 (53.2 MiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 33771 bytes 3853057 (3.6 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
FM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hello fmagno,
Were you able to check the previous post? Please let me know if you would like to close this thread.
Deivid A.
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hello fmagno,
Thank you for posting on the Intel® communities. I understand you are having issues with your device.
1. Can you provide more details about your issue?
2. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
3. Have you tried Ubuntu's latest version/kernel?
4. Have you checked this issue with MSI?
5. Are you using the Intel® Killer™ Wi-Fi 6E AX1675 (i/s)?
6. Is the issue out of the box or did it use to work?
7. Can you take any pictures of the errors or the issue?
Deivid A.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Deivid,
Thanks for the quick reply. I found few hours ago that the issue is fixed on linux kernel 5.17 (which is, as of today, the linux-mainline package on arch). I expect that in few days a pacman update will sort out the issue for me.
Cheers,
FM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hello fmagno,
I am glad to know that the issue is fixed with kernel 5.17. I recommend you keep an eye on the Linux updates and firmware.
Deivid A.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I am experiencing the same issue with the same network adapter, my linux kernel is version 6.2.0 and it doesn't work still.
Please provide a response.
Thank you,
Pikween.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hello fmagno,
Deivid A.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Dear DeividA_Intel
I have a problem. I recently installed parrot OS on my laptop. My wifi is not working. When I try to connect to the wifi, it doesn't show up any wireless network. I mean I can't turn wifi on. (Network Controller : alder lake-p pch cnvi)
Now what should I do please help me I am literally giving up.
I tried many way to fix it but never been able to connect it to the wireless network.
Please help me DeividA_Intel
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Andrew,
Got exactly the same problem. Could you solve it?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Dear DeividA_Intel
I tried many way to fix it but never been able to connect it to the wireless network. .
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi, same problem as Andrew_Tate. My laptop model is Katana 15 B13V. with Parrot home edition 6.1.0-1parrot1-amd64
probe
https://linux-hardware.org/?probe=e92e058288
dmesg
firmware: failed to load iwlwifi-so-a0-hr-b0-43.ucode (-2)
intel ssu attached
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
