Wireless
8528 Discusiones
Another AX201 drops 5GHz connection, Linux Mint 20.1
Rimling
Principiante
5.926 Vistas
Hi.
Have new Dell Precision 5550 laptop with Linux Mint 20.1
At 5GHz, Wi-Fi often drops the connection for 5 to 30 seconds, but the iwconfig shows it as connected.
Trying to fix the issue, updated the kernel from 5.4 to 5.10.
Power management off
Explicit country / region setting
Checked that Wi Fi is configured with WPA2, AES
Disable 802.11ax by
sudo modprobe iwlwifi disable_11ax=1
Tried changing NetworkManager to WICD
Install latest firmware, FW59.
None of this helps.
My router - Mikrotik Hap AC.
As I read in other people's posts, there is no working solution other than buying a WiFi 6 router.
Is any chance to fixing this problem?
In attach info from SSU script.
0 kudos
12 Respuestas
David_G_Intel
Moderador
5.892 Vistas
Hello Rimling
Thank you for posting on the Intel️® communities. To investigate this request, please share with us the following:
  • When the connection drops, does it restore itself automatically? or do you have to change the settings to get it back?
  • Do you have the opportunity to use a WiFi 6 router just for testing?
  • Did you check that the routers firmware is up to date and configured correctly?
  • Do you also get Bluetooth issues?
  • Was it always like this or did it start recently?
  • Is this issue happening at home, office environment or both?
  • Is this the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
  • Can you test different networks?
David G
Intel Customer Support Technician
Rimling
Principiante
5.876 Vistas
    • Yes, restore automatically
    • I will try with WiFi 6 router, but not now
    • Yes, while troubleshooting, also update firmware
    • Not use mouse, can't say. Trying to disable BT, nothing changed
    • It was from start, in April
At home. In office was just first day with this laptop, can't remember, if any issues with WiFi. And OS was pure Ubuntu
    • Original
    • At next week will try in office
I installed a second WiFi5 router a few days ago, because an additional problem was a weak signal in the place where I use the laptop.
After which the situation is almost good.
The monitor script that constantly pings the router shows lost ping for 1-3 seconds. No wifi or kernel related messages in dmesg
Previously, this time was a more serious and visible impact, during the video conference, the connection was often lost, or I could not listen or speak normally.
And Cisco Anyconnect reconnected.
Now I don't see any problems with the conference or Anyconnect. Ping periodically disappears, but usage is not affected.
The connection speed before to be 26 Mbps on average, now 390 Mbps. Perhaps this was the main problem.
Although the previous laptop worked flawlessly in the same conditions.
It is suspected that the Precision 5550 has antenna problems due to design.
I can say that everything is fine now, if you do not take into account that monitoring shows problems with ping
David_G_Intel
Moderador
5.854 Vistas
Thank you for the information provided, we will continue to work on this request. If you test different troubleshooting steps, please let us know.
David G
David_G_Intel
Moderador
5.819 Vistas
To continue, please provide the dmesg logs:
Once you retrieve the files, please share them with us.
David G
Rimling
Principiante
5.808 Vistas
Thanks for attention!
The "dmesg | grep ASSERT" return nothing​.
Attached
- # dmesg > dmesg.log
- # sudo trace-cmd record -e iwlwifi -e mac80211 -e cfg80211 -e iwlwifi_msg
- ping.txt
About ping.txt. It Contains results of my monitor script. Its run in loop
# timeout 0.5 ping 192.168.1.254
and writes to the log result.  The 192.168.1.254 is IP of my router. If result empty, execute and log
# iwconfig
Into ping.txt I pasted two problem period, [2021-06-15 12:59:02, 2021-06-15 12:59:06] and [2021-06-15 13:00:32, 2021-06-15 13:00:34].
In trace.dat captured both periods.
Additional, I had a video conference during the capture, did not notice any problems with video or sound. Why ping sometimes disappears, I don't understand
PS.
firmware-version: 59.601f3a66.0 QuZ-a0-hr-b0-59.u
Rimling
Principiante
5.796 Vistas
FW dump can't collect, I don't understand, what is X in wiki
echo 1 > /sys/kernel/debug/iwlwifi/0000\:0X\:00.0/iwlmvm/fw_dbg_collectI
Found, what is X. But cannot enable this. Trying to run under root
# echo 1 > /sys/kernel/debug/iwlwifi/0000\:00\:14.3/iwlmvm/fw_dbg_collect
bash: /sys/kernel/debug/iwlwifi/0000:00:14.3/iwlmvm/fw_dbg_collect: Operation not permitted
# ls -l /sys/kernel/debug/iwlwifi/0000:00:14.3/iwlmvm/fw_dbg_collect
--w------- 1 root root 0 Jun 16 10:30 /sys/kernel/debug/iwlwifi/0000:00:14.3/iwlmvm/fw_dbg_collect
 Reboot, check
# dmesg | grep FW_DBG_PRESET
nothing. And directory
/sys/devices/virtual/devcoredump
does not exists
David_G_Intel
Moderador
5.769 Vistas
Thank you for the information provided, we are working on this request the updates will be posted on the thread.
David G
David_G_Intel
Moderador
5.731 Vistas
After further investigating this request, this issue seems related to the router itself. We recommend checking with the router manufacturer to get the best settings for it or any additional configuration needed.
Please keep in mind that this thread will no longer be monitored by Intel. Thank you for your understanding.
David G
vmsh0
Principiante
5.355 Vistas
I have the same issue and the same router. Did you find a solution?
Rimling
Principiante
5.346 Vistas
Hi.
The settings did not help, I solved the problem by putting another Mikrotik closer to the laptop.
Rimling
Principiante
5.330 Vistas
In general, the impression is that the failures are related more to the quality of the signal than to the drivers and settings. Poor signal reception may also be due to the poor location of the WiFi antennas on my Dell Precision 5550 laptop, the case is all-metal. They are located on the edges of the keyboard where the speakers are. If you cover the speakers at the same time with your hands, the signal drops significantly by 10-12dBm.
vmsh0
Principiante
5.324 Vistas
In my case, SNR is pretty good, and I'm just a few meters from the router. In no case the Wi-Fi gets "spotty" - it either works at full capacity or it doesn't (but it doesn not disconnect! it just stops forwarding packets from the PC to the router, while the opposite seems to keep working until all the TCP connections drop for lack of ACKs).
I made a script that automatically reconnects when the issue happens, as soon as the script detects the issue it triggers the reconnect and the connection comes back at full rate.
I don't think any of this is coherent with a signal problem, so I think we might be having different issues after all
Responder
