With the summary; “Ant tool” with BE200 network adapter parameters please. (2023 or 2024 version)
“ANT tool, Version 22.2000.0.0-05160 (C) 2007-2020 Intel corporation” is outdated, so unfortunately hardware ;
The parameters in the Ant.exe and HwDetection.xml files say “Detected hardware: Intel(R) Wi-Fi 7 BE200 320MHz". cannot be found.
With parameter information for the Intel(R) Wi-Fi 7 BE200 320MHz network adapter;
I cannot find Intel's new “ANT tool” version for 2023 or 2024. help please.
windows 11, 24H2, Intel Wireless WiFi 23.60.0.10
In the tests performed ;
“C:\ANT>ANT.exe --QueryMCC
(C) 2007-2020 Intel company / OEM Tools group. All rights reserved.
Detected hardware: (???? ---none.)
or any network adapter defined as crf_id=“0x0f” in the HwDetection.xml file;
for example:<Device name=“TYPHOON” crf_id=“0x0f” rf_type=“0x010D” />
C:\ANT>ANT.exe -QueryMCC
Error: The read command fails with the following condition: , 256 (error.
In short, for Intel(R) Wi-Fi 7 BE200 320MHz, with the following or Intel's “ANT Tool 2023 or 2024” actual information
<Device name=“GALE2” should contain crf_id=“0x0f” rf_type=“ 0x0F08” but this parameter
“Ant tool” that contains these parameters. please.
best regards
“Nart”
According to the given rf_type codes: 0x010C, 0x010A, 0x010A, 0x010A, 0x010D, 0x010D, 0x0F08 indicate the respective Wi-Fi technologies and frequency ranges. For example
802.11n :0x0105
802.11a : 0x0101 (5 GHz frequency)
802.11ac (Wi-Fi 5): 0x0108 (Thunder ac9260 /Jefferson - ac9460, 9461
802.11ax (Wi-Fi 6): 0x010C, 0x010A, 0x010D (Typhoon - ax210, ax1675, Garfield -ax211, ax411, ax1690
802.11be (Wi-Fi 7): x0F08 (Gale Peak) 2)
[code]<NVM_METADATA>
<Devices>
<Device name="GALE2" device_id="0x272B" /> OR
<Device name="GALE2" crf_id="0x0f" rf_type="0x0F08" /> cdb="0x01"/>
</Devices>
<Macs>
<MAC name="GALE2" mac_type="0x00??" />
</Macs>
</NVM_METADATA>
[/code]
