Wireless
8544 Discussions
Attempted to install D.S.A., but Failed, with Error Message 0x800B0109
Wolfy169
Again, I have bought your Intel AX200, tried to install, via DSA, but ASSISTANT FAILED, with error Code 0x800B0109, But no explanation
David_G_Intel
Hello Wolfy169
Thank you for posting on the Intel️® communities. Please share with us the steps you go through, screenshots and the Intel® System Support Utility (Intel® SSU) results
  • Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows
  • Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  • Click on the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click on "Next", then "Save".
David G
Intel Customer Support Technician
David_G_Intel
David G.
David_G_Intel
David G.
