Wireless
8506 Discussions
BE200 broken in 23.140.0.3 driver - requires downgrade to previous installed version
Cássio
Intel Corporation - Extension - 31.0.101.5445 installed via Windows Update brought Wi-Fi 7 BE200 320MHz version 23.140.0.3 which broken the adapter.
## Affected Hardware
- Adapter: Intel Wi-Fi 7 BE200
- Hardware ID: PCI\VEN_8086&DEV_7A70&SUBSYS_00008086
- Faulty Driver: 23.140.0.3 (released May 2025)
## Symptoms
- Driver install causes complete adapter disappearance from system
- Device Manager shows "Network Controller" with Code 28 error
- Only solution is reverting to previous 23.10.0.8 via manual driver selection
## Reproduction Steps
1. Clean install Windows 11 23H2
2. Install driver 23.140.0.3
3. Observe adapter failure
Mike_Intel
Hello Cássio,
For me to further investigate this issue, please help provide the following details:
  1. What is the brand and model of your system?
  2. How did you update the driver?
  3. Can you share screenshots of the error in the device manager?
  4. Did you manually install/upgrade the BE200 to your system or is it embedded in your system?
Michael L.
Mike_Intel
Hello Cássio,
Michael L.
Mike_Intel
Hello Cássio,
I am sending another follow up on the information that I requested.
Michael L.
