Wireless
8789 Discussions
BE200 roaming with 11kv takes too long
Zack1991
Hi Developers,
I am using BE200 on ubuntu 24.04 OS to test roaming between two APs, and it took too long to roam from one AP to another, so I captured the wireless packet during the roaming, the interesting part is BE200 does support 11k and 11v as you can see,  but I didn't see the Neighbor Report frames except Radio Measurement frames for 11k, and one more thing is BE200 always responded "Refused" in Radio Measurement Report frame, which doesn't make any sense.
11K and 11V both are enabled on APs, and I tested other Station, they don't have such issue, so I think it might be related to the driver, could you please help to check this and get back to me? Thank you~~~
JedG_Intel
Hello Zack1991,
For me to assist you effectively, please share the information below.
1. Were you able to have wireless connection in a normal/expected performance before?
2. Is this a laptop or desktop system?
3. Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
4. Is this issue happening at home, office environment or both?
5. What firmware version are you using?
Jed G.
Zack1991
Hi Jed,
1. Wireless connection is always normal.
2. Neither of all, it's a N100 hardware.
3. It's the original adapter that came pre-installed from OS.
4. I am using be200 to test roaming, so I would say the issue is happening at office environment.
5. Firmware version: iwlwifi-ty-a0-gf-a0-86.ucode
Best Regards
Zack
Zack1991
Sorry about the typo, the firmware version please refer to the screenshot.
JedG_Intel
Hi Zack1991,
Thank you for sharing this information. I will be investigating this matter and I'll get back to you as soon as possible.
Jed G.
JedG_Intel
Hello Zack1991,
I sent you an email to continue the support. Please check your inbox at your earliest convenience.
Best regards
Jed G.
JedG_Intel
Hi Zack1991,
I sent you another email to address your concern. Please check your inbox at the earliest opportunity.
Jed Allen G.
JeanetteC_Intel
Hello Zack1991,
I have received your latest response and am currently working internally to resolve the issue. I will provide an update as soon as it's available.
JeanetteC.
Zack1991
Hi Jed,
I have responded your email several times, and based on the emails that we have communicated  back and forth, I am sure my emails all sent out, you can't just pretend that you didn't receive my emails so that you can close this case and do nothing about it.  So is this how intel do the support work? If Intel can't fix the issue, just be honest with us!
BR.
