Wireless
8536 Discussions
BLE TX power on the AX200 and AX210
BartThoelen
Dear,
I'm looking for the BLE TX powers in dBm for both AX200 and the AX210, on the 1M/2M and coded phy.
Is there anyone who has access to the FCC test reports, or is there a document listing these powers?
Thanks in advance.
BartT
Mike_Intel
Hello BartThoelen,
  1. Are you designing a system with embedded AX200?
  2. Can you tell me more about the this inquiry?
  3. Are you asking on how to supply power for this card?
Michael L.
Mike_Intel
Hello BartThoelen,
Michael L.
BartThoelen
Hi Michael,
Sorry for the late reply.
Let me answer you questions:
    Yes. But the system is designed so it can embed an AX200 or an AX210.
    Of course. We are looking to improve the BLE connection performance. The AX200 is working in the system as the central. The peripheral is build around Nordics nRF52840, advertising with 8dBm. From a FCC document found online, I found out that  the AX200 is transmitting at 5dBm. So it makes sense that the AX200 "sees" the peripheral (the nRF52840), but cannot connect to it at a given large distance. So I was wondering at what power AX210 would transmit. If this is higher than the AX200, I could choose to use the AX210 instead of the AX200.
    Nope. I want to to know the BLE transmit levels on both the AX200 and AX210, and this for the 1M/2M and the coded-phy.
Mike_Intel
Hello BartThoelen,
I will do further research on this matter and post the response on this thread once it is available.
Michael L.
Mike_Intel
Hello BartThoelen,
I sent an e-mail to the e-mail address associated with your community profile regarding the information you are looking for, please check it out.
Michael L.
BartThoelen
Dear Michael,
I received the info, thanks.  But it was a little disappointing :(. I assumed, Intel could tell me the specs of their own products, but seems I was wrong. It is very strange I have to contact an organization other then Intel, to find out what the BLE TX power is of the Intel products.
I hope you agree. Maybe you can contact someone in Intel to find the info?
BartT
